Re: Brake sound. 03 Tundra
This is likely the pad warning tab. It is on the back pad. Look closely at this pad, if you still think you have plenty of life left, pull the pad out and take a look at the tab. This is a metal scraper that hangs off the edge of the pad. It may be bent in to close and rubbing . Bend it out to a reasonable amount.
If this is not it let us know there are other possibilities, this is just the most likley.
Mike
“The significant problems we have cannot be solved at the same level of thinking with which we created them” (Albert Einstein)
Moderator Brake Forum
