Old 09-13-2008, 06:29 PM
Dealer : Miller Toyota
2005 Toyota Tundra DC Phantom Gray
Last Online: 11-19-2009 10:28 PM
Images: 11
dibble9012 will become famous soon enough.
dibble9012's Photo Albums
Default Permanent Sirius Antenna 1st Gen Tundra
Thanks to pedro66's write-up, I was able to find the parts and get over the stress of drilling into my roof. Here is the write up. I got tired of my OEM glass mount antenna cutting out constantly so for a while I was using a magnetic antenna. This is a MUCH better looking antenna, no wires seen either.
I didn't get as many pictures pedro's write-up because it was about to rain. I figured if it started pouring I would just cover the hole with tape As far as the wiring went, I did it slightly different than he did. I cut off the connector that did NOT have the black plastic piece and soldered that to my old antenna lead. Now it just snaps together with the OEM mercedes connectors.
Yes, these are all cell phone pictures, I didn't want to risk dropping my good camera.
Used the same part number he did for the antenna, got it for 11 bucks on ebay, brand new. Part Number:B6 7 83 0014
The drill bit I used, DO NOT try this with a normal drill bit, you will dent/bend the sheet metal!! The black stuff you see is from my sound deadening.
To be able to reach the underside of the roof, I had to remove both rear grab handles, the 3 round pressure clips in the headliner, and the small bolt that is behind the SRS panel.
The Mercedes connectors
Solder joint to my old antenna cable. I tested signal strength before I drilled the roof, so my connection did not change the signal for the worse.
23" is center from the INSIDE of the black trim on the roof. It is "9.25 from the edge of the tail lamp. If you drill any closer you will hit the headliner support mesh.
The point of no return
Well if you're gonna drill a hole in your roof, drill a big one! This hole is about 20mm like mentioned above.
I did not get a photo of the metal bushing installed, here's what it looks like though. Pull white paper off, mounts on bottom of roof with silver part flush with top of roof.
Installed base part, there is a weather sealing foam under the metal plate.
Plastic cover installed with secondary weather seal on edges
Finally done (except for interior wire routing)
What I finished just in time for
Old 09-13-2008, 07:23 PM
hndymn's Avatar
No job too small.
Dealer : Mark Toyota
2006 Toyota Tundra SR5 AC Salsa Red,
2003 Toyota Matrix Blue XR,
- Other - 92 Toyota LB 1-ton
Last Online: 11-17-2009 01:26 PM
Images: 16
hndymn has a brilliant future. hndymn has a brilliant future. hndymn has a brilliant future. hndymn has a brilliant future. hndymn has a brilliant future.
hndymn's Photo Albums
Default Re: Permanent Sirius Antenna 1st Gen Tundra
You are a brave man, dibble. Nice install.
I only recently learned the tape trick for marking finished surfaces for a cut. It's one of the best tips ever.
Spray-On bedliner :: Century commercial cap :: Replaced ball joints (recall) :: Replaced RR fender molding (damaged) :: Hellwig anti-sway bar :: Plugged the piezo :: Gentex compass/temp. rearview mirror :: 56 LED center brake light in cap :: Scangauge II :: Back up camera ::: Someday: Mr. Fusion :: Flux Capacitor ...
"Muhammad Ali [...] had a way with words, but it helped enormously that he could also punch guys in the face." - Maher
Old 09-13-2008, 07:51 PM
Images: 11
The tape method is not only great for marking finished surfaces, but also for protecting the edge from chips.
I just went for a drive where it normally cuts out. Excellent reception, only cut out a couple times under heavy tree cover/rain. No leaks whatsoever.
Old 09-13-2008, 08:52 PM
Tundrav8yamaha's Avatar
Banned
Images: 100
can you do my navi ant and Xm too ...
Old 09-13-2008, 08:57 PM
Images: 11
I don't think navigation antenna's are available in permanent styles like this (at least ones that would work with an aftermarket unit.)
This same antenna will work with XM.
Old 09-13-2008, 09:18 PM
Banned
Images: 100
This is one of the areas I would like to fab. My Parent's new accord has a built in wave ant with XM and Navi on the rear of there 2 door car. I would like to see this provided from the aftermarket sector but haven't seen anything yet. I have consired purchasing this from Oem Honda but haven't looked into this as of yet.Dibble if you look at the conector aftermarket or not it's still the same design used or retained.
Erik
Old 09-22-2008, 10:13 PM
Images: 11
Is this what you are looking for?
Worklog - Road RagE II (2007 Tundra)
Old 09-23-2008, 01:16 PM
Banned
Images: 100
dibble you should have waited the 2009 Tacoma one look's better and colored keyed Oem Toyota colors
Toyota finally add Xm antenna 2009 Tacoma(mod to Tundra)
Old 09-23-2008, 01:19 PM
Images: 11
Interesting, looks nice. Let me know how it mounts, chances are I could replace the mercedes one if I ever wanted to. Either by making the hole in my roof larger, or adding a washer to make it smaller. The one I have is a little bigger, but it works and looks clean. I could have painted the cover to match my paint if I wanted to, but with metallic paint I heard it can decrease signal strength.
Old 09-23-2008, 01:22 PM
Banned
Images: 100
Interesting, looks nice. Let me know how it mounts, chances are I could replace the mercedes one if I ever wanted to. Either by making the hole larger, or adding a washer to make it smaller. The one I have is a little bigger, but it works and looks clean. I could have painted the cover to match my paint if I wanted to, but with metallic paint I heard it can decrease signal strength.
You know i've been told that too even if you tint with a metallic Tint the coverage is very bad. Dibble they do make this in your color too. I'll be posting my mod when the part comes in coarse mine is super Toyota white.
ERik
Old 10-28-2008, 07:53 PM
Banned
Images: 100
Dibble,
couple of question my Vais wiring came in today so this weekend I am going to drill the hole into the roof like you did. What bit should i buy? I have to make one large hole and one small hole.Oh yea signal stength went up high quality wiring and plug's made that a good buy...
These are the pictures. Wiring is vais F plug used on the Lexus Ls and baby Is intended for aftermarket Xm.
Old 10-28-2008, 08:09 PM
UnSub's Avatar
Dealer : Toyota of Irving
2004 Toyota 4Runner,
2003 Toyota Tundra TRD Supercharged
Last Online: 11-16-2009 09:59 PM
Images: 6
UnSub will become famous soon enough. UnSub will become famous soon enough.
UnSub's Photo Albums
Dibble,
Hi Erick. Go to Home Depot and get a Unibit. It drills the metal very nicely in steps. It won't get away from from you when you go through like a regular bit will. They are made in different step sizes. Just pick the appropriate one. Too bad you are not in Dallas or I would either drill it for you or loan you the bit. I have several. I could mail it to you but I know you won't wait.
03 Stratosphere Mica Stepside, 4.7 L, Supercharger, TRD Package, TRD Exhaust,
Scion Head Unit 08600-21802,
Custom leather heated seats 2 tone with TRD LOGO, Moonroof, ARE LID, ZR3 Laser Shifter, Denso IK22 .4mm Iridium Plugs, Scan Gauge 2,
Rhino Liner, Die Hard Platinum P5 battery
5.7 Killer
Old 10-28-2008, 08:26 PM
Images: 11
Yup, that's what I used, a unibit. They can be expensive, but well worth it as it makes the hole perfectly, and I've already used it for several small projects. Good tools are always worth it
Nice looking antenna. I might get that one later on just because it has a smaller profile than the one I used. The signal strength is amazing though for these types of antennas. I can listen to Sirius radio in the garage with the door down, that was a far and distant dream with the magnetic antenna.
Do you have a picture of the bottom of the antenna?
Old 10-28-2008, 08:41 PM
Dealer : Hellman Toyota
2005 Toyota Tundra
Last Online: Today 08:03 PM
Images: 4
sic402 is on a distinguished road.
sic402's Photo Albums
Now your only problem is gonna be if what happens to you happens to me, i was in an underground lot, it was close but i got in and was able to move around and park no problem, however coming out because of the hangle i clipped my sirius antenna which i has just wired through the back wall then up and through the cargo light to the top, if i had done it this way..... there would more than just my antenna hanging down behind my window
Old 10-28-2008, 08:42 PM
Images: 11
Wow, that's REALLY close, hahaha. Good thing you didn't have your sunroof tilted!
