Old 09-16-2008, 12:27 PM
Dealer : Jim Coleman Toyota
2005 Toyota Tundra 05 DC Tundra Blue,
2004 Toyota Camry SE, 3.3ltr, Dk Grey
Last Online: 11-11-2009 08:36 AM
h7009 is on a distinguished road.
h7009's Photo Albums
Default Almost time for new tires, different size?
Hey to all, I've got a 2005 DC 4WD, it presently has 265/70/17's on it.....I am thinking about going to a 245/70/17....not talking brands here.
Has anyone tried this size and if so what are your opinions? ride and or possible gas mileage difference (more narrow and weight) thanks, CSM-H
Old 09-16-2008, 01:45 PM
Sizematters75's Avatar
Dealer : Toyota Scion of Stuart
2005 Toyota Tundra,
2007 Lexus IS250 -other-,
2006 Toyota RAV4 -wife's family car-
Last Online: 11-19-2009 04:53 PM
Images: 6
Sizematters75 is on a distinguished road.
Sizematters75's Photo Albums
Default Re: Almost time for new tires, different size?
Running a smaller tire is pretty much a personal choice. It will affect ride and make sure you look at the load handling on the tire. I know on mine I was going to go to a smaller tire but when they put them on and lowered the truck down the tires egged at the bottom. The same air pressure as I had in my old tires just a little more narrow of a tire.
2005 Tundra Dbl Cab Desert Sand
20" Enki Deep Six w/ 305/55R20 Cooper Zeon LTZ A/T
Flowmaster 50 Series Cat Back Dual Exhaust
Airaid Cold Air Intake
Airaid Throttle Body Spacer
Alpine w505 InDash Navigation w/ Blackbird
Kicker Comp VR12 Solobaric in custom over seat box
Kicker 1000.1 ZX Mono Amp
ARE Fiberglass Topper
XenonWorks 8,000k UltraWhite H.I.D.'s.
Hertz Mille' MLK 2 Components Hertz Mille' ML1600's 6.5's
Bilstein 5100's set a 2.0" in front
Wheeler's 1" lift blocks, Rancho RS9000XL in rear
Recon Bed Lights
Old 09-16-2008, 07:26 PM
Hey thanks for the response, I don't see the lowering problem as on tirerack.com they are the same diameter at 31.6....basicall a little narrower and lighter....again thanks, CSM-H
Old 09-17-2008, 11:20 AM
TundraSurfBum's Avatar
Dealer : Wesley Chapel Toyota
Last Online: 03-09-2009 07:27 AM
Images: 5
TundraSurfBum is on a distinguished road.
TundraSurfBum's Photo Albums
you aren't going to notice improved gas mileage.... you will probably suffer in the ride department.
2006 DC SR5
Bilstein 5100s F&R
Wheelers 1.5" AAL
285 Nittos on OEM Alloys
Flowmaster Delta 40
LUND Genesis Tri-Fold Tonneau
WADE in-Channel Visors
Lil Boom under the seat compliments of RF
Full LED conversion
Nothing too fancy, just better than stock!
Old 09-17-2008, 11:23 AM
Hey thanks for the response.......I am still hoping someone who has actually done this will respond. There is a difference in weight and price.....CSM-H
Old 09-17-2008, 12:26 PM
spennrocks's Avatar
Dealer : Team Toyota
2003 Toyota Tundra
Last Online: 11-20-2009 03:29 PM
Images: 2
spennrocks is on a distinguished road.
spennrocks's Photo Albums My eBay
going to a tire with a shorter height would raise the power band of your vehicle. i.e. rpm's will increase because of the diffrence. likely eating more gas. but, you will probably like the power increase.
if i want to save gas on my vehicle, and not compromise anything else (horsepower, driveability etc) go check out the vehicle spec tag on the drivers side door, and use the tire size it says on it.
or buy yourself a good pair of walking shoes.
Old 09-17-2008, 02:08 PM
spennrocks, thanks for the response...but I am not going to a shorter tire.....narrower, not short, they are both 70 series only the width is different 265 down to 245..... and actually the 265/70/70 (on the truck) is taller than stock which is a 265/65/17 tire......again thanks, CSM-H
Old 09-17-2008, 02:37 PM
Dealer : Ferris Toyota
2005 Toyota Tundra
Last Online: Yesterday 08:44 PM
skinny2 will become famous soon enough.
skinny2's Photo Albums
I've not done it...and wouldn't as I'm not willing to give up any handling. That's where you'll see the biggest change by losing that width. You'd probably see a similar fuel savings by going back to the shorter OEM size as you'll gain back some gearing. I went with 265/70's when I replaced OEM tires but I think I'm going back to 265/65's this next time. I went to the 70's mainly because was it was $50 cheaper (and they looked a little better) but my mpg dropped by 1....which = $320 in fuel over the 25k miles I've had them.
'05 Tundra DC 4x4 (my DD)
'05 Honda Odyssey (her DD)
'03 Ram 3500 Cummins 6-speed dually (for haulin)
Old 09-17-2008, 02:59 PM
spennrocks's Avatar
2003 Toyota Tundra
Images: 2
the width dimension (265/245) does have an effect on sidewall height.
use a metric calculator if you don't believe me.
Old 09-17-2008, 03:00 PM
skinny2, thanks for the response....Now your comments do make sense and I will take a look at possibly going back to stock...the 265/70's were on the truck when I bought it and I don't like the ride as it is.....thanks, CSM-H
Old 09-17-2008, 03:02 PM
In most cases I would agree, But as I mentioned before the diameter of the tires is the same as 31.6......so it's a moot point. again thanks for your earlier response, CSM-H
Old 09-17-2008, 03:41 PM
2005 Toyota Tundra
I didn't notice a change in ride going from 65 to 70. Typically you'd expect the ride to improve going to a taller tire, but I think the suspension will effect this more on a truck than anything else. Tundra is tuned very nice in my book...not too mushy or teeth rattling.
Old 09-17-2008, 03:50 PM
skinny2, for the most part I would agree on going taller [with a little width] improving your ride, obviously not too wide.....But you are probably on to something in the going back to 265 and there by not having to go into "it" as deep to get this heavy truck (DC 4wd) going.....
For my part I just think it is tread design of the tires I don't like.......but after 57 cars and trucks in my life (so far) I've got a reasonable handle on it.... ya I know I need a support group for having so many vehicles.....CSM-H
Old 10-11-2008, 05:03 PM
Dealer : Valenti Toyota
2005 Toyota Tundra
Last Online: 09-20-2009 06:14 AM
dougg is on a distinguished road.
dougg's Photo Albums
I would not go smaller. your gvaw (weight carrying capability) will go down and may even be illegal. doug
Old 10-11-2008, 05:45 PM
dougg, welcome to the board. Just so you know there are three tires sizes available for the Tundra; 265/70/17 is an optional larger tire, 265/65/17 and beliveve it or not the 245/75/16....So I don't think the size I am looking at would be a problem. CSM-H
