Old 09-26-2008, 08:25 PM
duffyatkinson's Avatar
Dealer : Toyota of Riverside
2002 Toyota Tundra,
2003 Toyota 4Runner V6 Limited 4WD
Last Online: Today 04:04 AM
Images: 17
duffyatkinson has blessed us with their presence. duffyatkinson has blessed us with their presence. duffyatkinson has blessed us with their presence. duffyatkinson has blessed us with their presence.
Send a message via Yahoo to duffyatkinson duffyatkinson's Photo Albums
Question '02 Tundra V8 SR5 Power Inverter Project Help!
I posted this in the Electrical forum, but no response, so I thought I'd give it a shot here.
I would like to run A/C power to the aluminum bed box in my 2002 Tundra V8. I need help figuring out the best wiring/mounting solution.
I'd like to have access to A/C power for low-wattage lights, radios, small air pumps, cell-phone recharger, and maybe a coffee machine. No blenders, hair dryers, TVs, or other high-torque motors etc would be used.
Here's my ideal specs:
1. Inverter mounted externally
2. Not sure about min size (800W? 1500W?)
3. At least two A/C outlets accessible from inside the bed box (maybe cut outlet holes in the box for the plugs with waterproof covers??)
4. Cutoff switch to disconnect the inverter from the battery
5. Power available without the engine running
Q: I've read members recommending installing the larger inverters in the engine compartment close to the battery due to heat buildup issues in the cab, but wouldn't the high ambient heat generated by the engine be an issue as well?
Q: If the inverter IS mounted close to the battery, is it possible to run a cable to carry the 110-120V from the inverter back to the bed box to a waterproof junction box to mount the power plugs in?
Would this address my requirements? It has thermal protection, low battery shutoff sensor, and some sort of ethernet-based remote on/off system: Northern Industrial 1500 Watt Inverter — Model# 11150 | Modified Sinewave | Northern Tool + Equipment
Any recommendations as to inverter brand, size, mounting options, and wiring solutions would be greatly appreciated.
Thanks all!
2002 Tundra V8 SR5 2WD AC | Silver Sky Metallic | Chrome Step Bars | Kobalt Low Profile Bed Box
Daystar 2.5" Levelling Lift, 1" Rear Block
Mobil-1 5W-30 | Magnefine ATF Filter 3/8" | K&N AF #33-2144 | NGK Iridium Plugs #BKR6EIX
Russell Speed Bleeders #639560 | Josh's Billet Wing Window Latch Upgrade
11/1/2009: 48,050 miles
* * * I highly recommend http://www.auto-rx.com/ for your engine and transmission! * * *
* * * O2 Sensor Replacement DIY: http://www.tundrasolutions.com/forums/1197269-post2/ * * *
Old 09-26-2008, 09:34 PM
Dealer : Toyota of Muncie
2003 Toyota Tundra,
- Other - 2000 Accord
Last Online: 10-13-2009 01:11 AM
lukewaterhouse is on a distinguished road.
lukewaterhouse's Photo Albums
Default Re: '02 Tundra V8 SR5 Power Inverter Project Help!
Thanks all!
If you want small electric devices to run on this, an 800W inverter should be fine. But if you are going to go through the trouble why not go all out just in case you need it.
You will need deep cycle batteries as well as your starter battery to do this right. Otherwise you will have a very short window of run time on your setup without your motor running. One RV/Marine Deep cycle battery in your bed box should do it for 800W inverters, two batteries in parallel for 1500W inverters.
A cutoff switch is required so you don't have a constant drain on your battery(s) from the inverter. Use a high current capable, double pole, three way switch to switch your deep cycles from inverter to charging. You will need heavy gauge wires to go from the deep cycles to the inverters. They will be carrying up to 125 amps when running full throttle. A lighter gauge wire can be used for the charging circuit side.
On a side note, I would charge the deep cycles with a trickle charger or such after heavy use before switching them back to the trucks charging circuit. I'll bet that the truck won't like a big draw on the electronics while its running.
This should get you started. Help from an electrician would be best. Remember electronics run on smoke, once the smoke gets out, it's broke.
Roads are for people without 4x4
2003 Tundra Sr5
4x4
4.7L Iforce
90,000 miles
Tonneau Cover
Tow Hitch
.45 Taurus 24/7 hidden under the front console tray
Old 09-27-2008, 12:37 AM
2002 Toyota Tundra,
Images: 17
Thanks for your reply Luke.
The more I started to piece it together in my mind, the more I figured that I would need a dual battery system, maybe a deep-cycle mounted in the space over the passenger side front wheel well. I would have to consult with a vehicle electrician to properly install the isolator/combiner that would be required as well. I just don't know enough to be sure of doing it right.
Q: Do you think that the inverter could (or should) be mounted under the hood so as to keep the cable from the battery to the inverter as short as possible?
Q: Could I run the A/C supply line from the inverter back to a box with the 110/120V outlets?
Q: I figured the minimum gauge from the battery(s) to a 1500W inverter is #4 AWG. Correct?
Thanks for your help.
Duffy
Old 10-21-2008, 11:08 PM
Dealer : Kendall Toyota Scion
2004 Toyota Tundra
Last Online: 10-30-2009 10:06 PM
muvico is on a distinguished road.
muvico's Photo Albums
I had that same dilema before and there are several ways of doing it but they all are time consuming and expensive, My solution was I bought a little battery inverter 1500 w in one little box , i got at home depot for 200 $ and it works fine , you can even recharge it from a 12v port from your truck. it is called power 1500.has two 120 outlets and one 12v output, you can even starter jump your truck from it if you need to.
'02 Tundra V8 SR5 Power Inverter Project Help!-100_2567.jpg   '02 Tundra V8 SR5 Power Inverter Project Help!-100_2566.jpg
Old 10-22-2008, 02:20 PM
eallen62's Avatar
Tundra owner for LIFE!
Dealer : Yokem Toyota
Last Online: 10-23-2008 11:27 AM
eallen62 is on a distinguished road.
eallen62's Photo Albums
I used a Hellroaring dual battery isolator / combiner in my truck. There use to be a link in this forum on how its done. The hardest part was getting to the Positive cable on the starter. Since mine did not have ABS I just mounted a battery plate on the passenger side wheel well. It looks like it came from the factory like that.
Fab Tech Coil Over Front Shocks up 1.75" & Rear Performance Shocks | TRD IS Rims with Remington Mud Brute 305/70R16 (33's) | 50 Series Flowmaster Dual Exhaust | K & N Air Filter | Warn Trans4mer Front Bumper | Front Receiver Hitch | Warn 9000i Multi-Mount Winch | Blue & Yellow Top Optima Batterys| Hellroaring dual battery isolator / combiner | Double Sprayed Rhino Bed Liner | Plasma Ultra White Headlights | Husky Floor Liners | Viper Security System w/ Remote Starter | Rear Seat Mod. | 12v Aux Power Plugs Mod. | TRD add a Leaf | Fumoto Engine Oil Drain Valve | All Synthedic Fluids | Front Window Tint | Skid Row Skid Plate | Home Made Light bar w/ Hella 500's | XM Radio (Roady) | Pullrite SuperGlide 5th Wheel Hitch (REMOVABLE) |Transmission Temp Mod | KZ Sportsman 5th Wheel Trailer
www.eallen62.com
Old 10-22-2008, 07:22 PM
2002 Toyota Tundra,
Images: 17
Hey Eric! How about some pics of your installation?!!!!
Old 10-23-2008, 11:25 AM
eallen62's Avatar
I had pictures on here at one time, but they are gone. Here is the information that was posted a few years back from this guys site.
Welcome to the home for Tundra Solid Axle Swap info
Enter the site & look for the link on the left : Dual Battery Setup
I mounted my switch just above the e-brake release. One thing I wish I would have added was a separate volt meter. The dual battery's have save me many times! And helped me abuse my winch & lights on many a mud trip.
Hope it helps.
www.eallen62.com
Tags
battery , inverter , power
