Unichip.com
Old 11-13-2008, 02:29 PM
n8g n8g is offline
Last Online: 01-13-2009 06:03 PM
n8g is on a distinguished road.
n8g's Photo Albums
Smile Icon Coilovers
I will be installing icon 2.5 " leveling system and need some advice on some tire sizes. I will be installing 17 x 9 rims...can i run a 285/70r17 or do i need to go smaller? I don't want any rubbing at all and anyone have any advice on gas mileage difference when you change your tire size? Does anyone have any pics of their truck with the icons and rims and tires installed? Thanks
Old 11-13-2008, 03:57 PM
Dealer : Lynch Toyota of Auburn
2005 Toyota Tundra 2wd Double Cab
Last Online: 06-27-2009 11:50 AM
AGR1755 is on a distinguished road.
AGR1755's Photo Albums
Default Re: Icon Coilovers
try the search option...there are MANY threads on this exact same topic with pics and write ups and all the info you could ever want
good luck to ya and let us know how it turns out
2005 2wd Double Cab Tundra
Chrome nerf bars
John Deere Toolbox
JBL Stereo System (Factory Upgrade)
Old 11-13-2008, 05:20 PM
teraflx623's Avatar
2003 Toyota Tundra,
2002 Lexus IS300
Last Online: 05-12-2009 10:55 PM
Images: 7
teraflx623 is on a distinguished road.
teraflx623's Photo Albums
Im running 285/70/17's with 3"s of lift and I have no rubbing.
2003 Black AC -3" spacer lift,285/70/17 Wrangler MTR's,clear corners,gibson exh,8" subs,k&n fipk intake,remote start & 6,000k HID's.
Old 11-13-2008, 07:12 PM
Dealer : Tustin Toyota
Last Online: Today 04:27 PM
Tundra Truck Driver is on a distinguished road.
Tundra Truck Driver's Photo Albums
I have the DRs set at 2.5 or a little bit higher I'm not too sure. I had to cut part of the pinchweld and I still rub some on turns compressed running on 285/70/17 Revos. I would crank higher but my already-dead UBJ will be absolutely decapitated if you get my point.
2006 Toyota Tundra DC SR5
Old 11-13-2008, 09:59 PM
n8g n8g is offline
n8g's Photo Albums
Question Re: Icon Coilovers
Does anyone have any pics of what their truck looks like with 285/70r17? What kind of gas mileage should be expected? Will I need a differential drop kit when I install these coil overs?
Old 11-13-2008, 10:26 PM
Hugemoose's Avatar
Dealer : Performance Motors Toyota
Last Online: Yesterday 10:03 AM
Hugemoose will become famous soon enough. Hugemoose will become famous soon enough.
Send a message via AIM to Hugemoose Hugemoose's Photo Albums
Heck, if you just want to level your truck and don't really wheel it a lot I'll trade you my Bilstein 5100 lifting shocks for your Icons!!!
But really, your gas mileage may go down a bit, but it will be hard to properly calculate because your speedometer and odometer will be running slightly slower. You can fix this by getting a Truespeed. I just deal with it for now...
You could use the diff drop, but it probably isn't necessary. They don't do a whole lot and they prevent you from running a good skid plate unless it's modified. They do bring down the CV angle slightly....but it isn't much.
It is likely that your inner CV's will start to spit grease. This happens a lot. If they aren't torn, just take the stock clamp off and use two hose clamps per side (the screws on opposite ends to counterweight each other) and tighten them down. This holds the boot on slightly tighter. Search for the CV boot mod. This is what they are talking about.
David~2001 Toyota Tundra 4X4 TRD SR5~SSautochrome headers~Single 2.5" exhaust w/ Flowmaster 50 series delta flow muffler~K&N FIPK intake system w/True-flow filter~ASP underdrive pulley~Hellwig Anti-Sway Bar(removed)~Powertrax No-slip~Bilstein 5100 front and rear w/ Deaver 10 pack~Diff breather mod~255/85 BFG M/T on Wheelers Black Steelies Type B~Custom Rocksliders~Skid Row front skid plate~Custom Transfer case skid plate
Old 11-14-2008, 08:43 AM
TundraSurfBum's Avatar
Dealer : Wesley Chapel Toyota
Last Online: 03-09-2009 06:27 AM
Images: 5
TundraSurfBum is on a distinguished road.
TundraSurfBum's Photo Albums
no wheel spacers? interesting.... I have the same wheels but have been holding off on 285s.
2006 DC SR5
Bilstein 5100s F&R
Wheelers 1.5" AAL
285 Nittos on OEM Alloys
Flowmaster Delta 40
LUND Genesis Tri-Fold Tonneau
WADE in-Channel Visors
Lil Boom under the seat compliments of RF
Full LED conversion
Nothing too fancy, just better than stock!
Old 11-14-2008, 09:01 AM
DevinSixtySeven's Avatar
Leader of Group Evil
Dealer : Voss Toyota
Last Online: 07-02-2009 04:27 PM
Images: 22
DevinSixtySeven has blessed us with their presence. DevinSixtySeven has blessed us with their presence. DevinSixtySeven has blessed us with their presence.
I want a flashing image like those ads at the top of the screen on Yahoo etc, the ones like...
"YOU ARE TEH 100,000,000th PERSON TO ASK THIS QUESTION! THIS IS NOT A JOKE, YOU HAVE WON A NEW TOASTER OVEN!!1!"
Yeppers, definitely get after the search feature, anybody here can hook you up with instructions and keywords...we been lifting these trucks since 2000 .
Dunno if you picked 17s for any particular reason, but you can use 16s...gives you just a little more sidewall. 17s are better for handling, not as good for sneaking around on the rocks, at least not until you get in to 37"+ tires. Many of us ran 285/75/16 tires on 16x8 rims for years, I've been running 315/75/16 (roughly 35x12.5) on 16x8s for three or four years now.
It'll look really nice once it's done. I have plenty of photos but they're not up since we recycled the photo gallery .
285/70/17 should fit, that's the largest you can go with that lift, and be aware it may still rub during turns in reverse and some turns with flex going forward. Just the nature of it...until you trim the wheel well, the largest tire which will fit at full compression in a turn is 265/75/16.
If you plan to go 4WD with this on anything relatively rough, you'll be much better off running the original rims with 255/85/16 tires...they'll fit better, less trimming required.
If you're going at speed across the desert, you can run the 33s...less need for compression in a turn.
Gas mileage on the highway stays about the same, in town it'll drop 1-2mpg depending on how you drive.
Make sure the truck is aligned using DJ's method. The high caster draws the tire away from the back of the wheel well.
-Sean
GFX by FreedomEagle50
Manual Hubs
Old 11-14-2008, 11:39 PM
msr1011's Avatar
Dealer : Findlay Toyota Scion
2004 Toyota Tundra,
- Other - 05 Acura TL w/Navi
Last Online: Yesterday 03:41 AM
msr1011 is on a distinguished road.
msr1011's Photo Albums
I also have the Icon coilovers with 285/70 series BFG's. I hear a slight rubbing noise when the wheels are locked out while making a u-turn. Your mileage will go down, but I just bought a tru-speed unit.
Check this link here for pics:
New toys
04 Tundra D/C SR5 2WD
Mods:
Icon coilovers/Pro-Comp add a leaf w/shocks
American Racing ATX Mojave 17" Wheels/BFG All-Terrian's
Limo Tint/Compustar Alarm
Flowmaster Muffler/Clear corner covers/TRD Grille w/powder coated mesh
Debadged/Color-matched tailgate handle & mirror covers
Kenwood AM/FM/Sirius deck/Ipod interface
Kenwood drop-down monitor w/DVD player
Clear LED third brake light
05 Limited front bumper cover w/foglights
Cobra Cb radio/Console Vault
N-fab running boards
Custom Deifant light bar w/three Procomp H11 lights
Future mods: Camburg UCA's & custom rear bumper
