Old 11-13-2008, 04:00 PM
lopezi's Avatar
Dealer : Gault Toyota Scion
2002 Toyota Tundra
Last Online: 08-17-2009 12:47 PM
lopezi is on a distinguished road.
lopezi's Photo Albums
Default Odd whirring noise, occurred overnight, any clues?
I have encountered an odd whirring noise on my '02 Tundra. During the previous day there were no noises or issues and then the next day I go to start it up and there is this odd whirring noise which sounds reminiscent of the noise you hear when you crank the steering wheel all the way to the left or right....but in my case it is there when I first start up the vehicle and doesn't change any when steering to the left or right, nor is the steering affected at all. The sound will go away when the vehicle has warmed up, usually a ride of 10 minutes and the sound has dissipated.
Any ideas/insights into what it might be?
I have replaced the serpentine belt before and I have had the timing belt done. The vehicle currently has 122,000 miles on it.
Thanks,
Ivan
2002 Toyota Tundra SR5
Eclipse 8443 Headunit
Eclipse 5962 In-dash 6 disc changer
Phoenix Gold ZX450
Sony XM1600GSD
Pioneer TS-C1653 - front
JL Audio TR650 Cxi - rear
JL Audio Stealthbox - sub
Q-Logic Subbox - Resonant Enginneering RE8's
Old 11-13-2008, 04:27 PM
UnSub's Avatar
Dealer : Toyota of Irving
2004 Toyota 4Runner,
2003 Toyota Tundra TRD Supercharged
Last Online: Yesterday 08:40 PM
Images: 6
UnSub will become famous soon enough. UnSub will become famous soon enough.
UnSub's Photo Albums
Default Re: Odd whirring noise, occurred overnight, any clues?
Thanks,
Ivan
You might be low on power steering fluid.
03 Stratosphere Mica Stepside, 4.7 L, Supercharger, TRD Package, TRD Exhaust,
Scion Head Unit 08600-21802,
Custom leather heated seats 2 tone with TRD LOGO, Moonroof, ARE LID, ZR3 Laser Shifter, Denso IK22 .4mm Iridium Plugs, Scan Gauge 2,
Rhino Liner, Die Hard Platinum P5 battery
5.7 Killer
Old 11-13-2008, 05:00 PM
TheGryme's Avatar
Supportive Supporter
Dealer : Valley-Hi Toyota
2004 Toyota Tundra,
- Other - 1992 Toyota 4Runner
Last Online: Yesterday 11:42 PM
Images: 23
TheGryme will become famous soon enough.
TheGryme's Photo Albums
When you had the T-Belt changed.....did the idler pulleys and H2O pump get changed too?
You could also take the Serp belt off and start it up to confirm that one of the serp belt driven accessories is making the noise....the belt comes off pretty easy....just put an arrow on it so you can put it back rotating the same direction (my 0.02!)
TheGryme Ummmm Beer Good.....Whiskey Better!
'04 Tundra DC
Grey....V8 SR5 4X4 TRD Off Road Suspension, LSD, Towing Package, Toyo Open Country A/T 265 75 16 ~ 8 Ply's, Magnaflowed (w/ Secret AirBox Mods!), UNIChipped, True~Flowed, DeBadged, ScanGaged, XM'ed.....Yeah!
'92 4Runner
Black, V6, Downey / Rancho suspension F&R, 3 inch sus lift, 1 inch body lift, SAW T-Barz, 4:88's, ARB (rear), 32X12.50 BS Dualers on AR 8X15 Wheelz, Power Slots and Pads, Downey headers, MagnaFlo Muff, K&N FIPK, Ported heads, 1 piece stainless valves...way too much money in it!
'04 YZ250F
Dr.D Header and Can, JD Jetting, P38 AP, UNI Flame Proof Air Filter, No Back Fire Screen, Carbon Fiber Carb Heat Shield, Renthals, ASV Controls....
'87 Nissan Pathfinder......gone but not forgotten.
Old 11-13-2008, 05:51 PM
LGL002's Avatar
Dealer : Rudy Luther's Toyota
2003 Toyota Camry SE ,V6, Nav,
- Other - 1969 Ford Torino GT,
2004 Toyota Tundra Limited A/C 4X4,
2000 Toyota Tundra SR5,TRD,AC 4X4
Last Online: Today 06:38 PM
Images: 16
LGL002 will become famous soon enough.
LGL002's Photo Albums
Thanks,
Ivan
Take a listen down by the heater fan motor below the glove compartment when it's cold. Not unusual for the motor to make some noise when cold with dry bearings.
Larry
2003 Camry SE V6 Navigation, Sirius, Lunar Mist
Optima 34R battery
Some people should not be allowed access to tools without books!!!
Old 11-14-2008, 08:39 AM
Dealer : Performance Toyota Memphis
2004 Toyota Tundra
Last Online: Today 12:52 PM
buglao is on a distinguished road.
buglao's Photo Albums
sound like ghost live in your truck.
Old 11-14-2008, 08:19 PM
lopezi's Avatar
2002 Toyota Tundra
Well, the fluid ended up being low, which now has me concerned that there might be a leak? But I still think it's odd that one day its fine and the next it's low?
At 122,000 miles is the power steering pump at a questionable point? I don't think you go through power steering fluid unless there is a seal leaking?
Any way to chase down or inspect for a leak?
Thanks,
Ivan
Phoenix Gold ZX450
Sony XM1600GSD
Old 11-14-2008, 09:56 PM
HOGWILD's Avatar
Dealer : American Toyota
2006 Toyota Tundra,
1993 Toyota Truck,
2007 Scion tC
Last Online: Today 10:36 AM
Images: 12
HOGWILD is a splendid one to behold. HOGWILD is a splendid one to behold.
HOGWILD's Photo Albums
Corvette Action Center Knowledgebase :: Service Bulletin: Fluid Leak Detection
Lotta parts stores sell this leak detection ya just pour into your power steering pump and hold a black light next to it to find leak! It's been around for long time and neither the light or the fluid are that expensive! what is a Whirring noise?
