Old 11-27-2008, 08:10 PM
Dealer : Village Toyota Scion
Last Online: 07-17-2009 04:07 PM
johnnt 7's is on a distinguished road.
johnnt 7's's Photo Albums
Default tricks to install front bilsteins
i will be putting the new bilsteins hd strut on tomorrow. the originals fell out.will the new bilsteins be harder to get the bottom bolts in. and start with the three bolts and nuts on top is that right. and if the bottom hole does'nt line up after the three on top are in place can the bottom of the strut be turned . thanks john
Old 11-28-2008, 12:21 AM
- Other -,
Last Online: Today 04:34 PM
adamjt is on a distinguished road.
adamjt's Photo Albums
Default Re: tricks to install front bilsteins
You will need a good spring compressor. I had trouble getting the typical two screw rental spring compressors on the TRD springs. It wouldn't fit between the outer coils and on the inner coils it didn't pull the spring far enough together. My neighbor luckily had a heavy duty one piece spring compressor that worked.
Once I got the top three bolts in I had to use a pry bar to force the bottom end of the shock to end up in the right place to get the bolt through. It was a pain in the butt, but the second one will be easier once you get it down.
Old 11-28-2008, 10:56 AM
Dealer : Piercey Toyota Scion
Last Online: 11-18-2009 09:27 PM
kerykj is on a distinguished road.
kerykj's Photo Albums
Here's my tip - I took the shock/spring assembly and front rotors to my mechanic. He swapped the shocks, turned the rotors and asked for $20. I gave him $50 (this was last Christmas).
Old 11-29-2008, 02:30 AM
caramel's Avatar
2006 Toyota Matrix
Last Online: 12-17-2008 09:31 PM
caramel is on a distinguished road.
caramel's Photo Albums
Wow, you give very generous tips, kerykj!
I'm looking forward to taking my spring assembly to the shop too this weekend. Anyone have an idea how it will cost?
Old 11-29-2008, 06:27 AM
thanks to everyone that helped me. I did'nt want to wait to monday because of the holiday so i went to auto zone yesterday and rented the spring compressor. its was real easy.I really like working on my own truck.just like the old days.well all four bilsteins are in and the tires all have nitrogen.with my other addition of a new exhaust cat back,i had a great afternoon bring back the sp. compressor.what a great ride.like a new truck have a great Christmas again john
Old 11-29-2008, 08:56 AM
Tundradrenalin's Avatar
Assistant Administrator
Last Online: Today 09:35 AM
Images: 205
Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family.
I'd bet you pay half hour ($45) to one hour's ($90) worth of labor, those are the rates in my area. If they charge much more than that, they might as well install the darn things.
Under the Hood: AMSOIL Synthetic Lubes all around, AMSOIL Ea Air Filter, Doug Thorley Headers, Magnaflow Exhaust, Semi-RAMair airbox mod
Suspension & Tires: 285/75-16 BFG T/A'ko, Fabtech Coils, 1.5" Wheeler's blocks, Toytec Diff Drop, 1.25" Spidertrax [front], 1.5" Goeske Wheel Adapters [rear]
Handling: TC Poly Steering Rack Bushings, Downey HD End Links, Wheeler's Anti-Sway Kit, Hellwig 7700 Swaybar, Timbren Rear SES
Electrical: URD MAF Sensor Calibrator, Superlift Truspeed Speed Sensor Re-Calibrator, ScangaugeII, Full LED Conversion
Stereo: Alpine CDA-9886, Alpine & Phoenix Gold amps, Q-Logic box w/RF subs, eDead
Cosmetic: Line-X Bedliner, Custom N-Fab Steps, Rear Diff Breather Extension, F103N Fumoto Oil Drain Valve, Debadged (partially), Bell Truck Trunk, Access Vanish Tonneau
Old 11-29-2008, 08:58 AM
Images: 205
Congrats John, I know your feeling.
Nitrogen in your shocks and your tires, sounds like a good combo!
