  #16 (permalink)
Old 12-02-2008, 12:25 PM
Big_Al1's Avatar
veteran member
Dealer : Lake Charles Toyota
2005 Toyota Tundra,
2008 Toyota Sienna XLE
Last Online: Today 12:55 AM
Images: 16
Big_Al1 is on a distinguished road.
Send a message via Yahoo to Big_Al1 Big_Al1's Photo Albums My eBay
Default Re: New tires now low oil pressure?
Something is surely wrong mine never drops to zero never goes below 1'4 mark no matter what.Let us know what you figure out.
  #17 (permalink)
Old 12-02-2008, 12:52 PM
Remmy700P's Avatar
Dealer : Toyota of Riverside
2002 Toyota Tundra,
2003 Toyota 4Runner V6 Limited 4WD
Last Online: Yesterday 10:51 PM
Images: 18
Remmy700P has blessed us with their presence. Remmy700P has blessed us with their presence. Remmy700P has blessed us with their presence. Remmy700P has blessed us with their presence. Remmy700P has blessed us with their presence. Remmy700P has blessed us with their presence. Remmy700P has blessed us with their presence. Remmy700P has blessed us with their presence. Remmy700P has blessed us with their presence. Remmy700P has blessed us with their presence. Remmy700P has blessed us with their presence.
Remmy700P's Photo Albums
Gonna have to second this. What the OP is describing is exactly the opposite of what I experience as normal oil pressure gauge operation. It drops when RPMs are low, then climbs as RPMs increase, usually within a range of 1/4 to 3/4. The fact that the gauge is reading something leads me to believe that there is something amiss other than an electrical issue. I'd be a little worried...
2002 Tundra V8 SR5 2WD AC | Silver Sky Metallic | Step Bars | Kobalt LP Bed Box | FR: Daystar 2.5" Lift, RR: Wheeler's 1" Block
LT265/75R16 Nitto Terra Grapplers 119Q 8-ply | Wheeler's Poly Sway Bar Bushing/Bump Stop Set
Mobil-1 Syn 5W-30 | Mobil-1 Syn ATF | Magnefine ATF Filter 3/8" | NGK Iridium IX Plugs #BKR6EIX | Russell Speed Bleeders #639560
Josh's Billet Wing Window Latch Upgrade | CBMTA Member! | 3/1/2009: 49,693 miles
* * * I highly recommend Auto-Rx for your engine and transmission! * * *
* * * O2 Sensor Replacement DIY * * *
"I finally found an honest mechanic. He honestly doesn't know how to fix anything."
  #18 (permalink)
Old 12-02-2008, 03:56 PM
Last Online: 03-13-2010 12:23 AM
Ray Kane may have some regrets.
Ray Kane's Photo Albums
Well I am going to start with an oil change back to 5W30 and look up how to check the oil pressure sensor and guage. I went to Toyota today and the parts guy wasn't able to find an oil pressure sender part number {welcome to my world}
Ray Kane
If you don't try, nothing happens
  #19 (permalink)
Old 12-03-2008, 06:10 AM
Last Online: 03-19-2010 07:13 AM
p-car-tower may have some regrets.
p-car-tower's Photo Albums
When you change back to the 5W30 oil, also install a new filter. There could be something wrong w/ the filter you just put in (I'm assuming you installed a new filter when you put in the 10W30 oil), like a sticking bypass.
Jerome
'06 Tundra AC Ltd 4x2 - Phantom Gray
'89 Porsche 944 Turbo (track car / wallet deflator)
  #20 (permalink)
Old 12-03-2008, 06:34 AM
Dealer : Germain Toyota Scion of Sarasota
2003 Toyota Tundra,
2007 Toyota Corolla
Last Online: Yesterday 07:49 AM
PapaPS is a splendid one to behold. PapaPS is a splendid one to behold. PapaPS is a splendid one to behold. PapaPS is a splendid one to behold. PapaPS is a splendid one to behold. PapaPS is a splendid one to behold. PapaPS is a splendid one to behold. PapaPS is a splendid one to behold. PapaPS is a splendid one to behold. PapaPS is a splendid one to behold. PapaPS is a splendid one to behold.
PapaPS's Photo Albums
I had a sending unit on a 3.0 ford 6 cyl act up too............it fluctuated too high , too low, almost nuthin, the connection had grease/oil all over it, I cleaned it , tightened it up and it is still working...........long and short of this is, my guess is the sending unit it's self , or the connection to it.
as always my .02
  #21 (permalink)
Old 12-03-2008, 06:35 AM
Last night after driving the truck for 15 minutes in city traffic I left it running in the driveway to watch the guage.
It stayed between zero and the 1/4 line {I know it isn't really 1/4 but I use that term as a reference} but closer to the zero line.
I removed the oil filler cap while the engine was running and could see oil circulating. I saw tiny air bubbles in the oil from it being circulated - I assume that is normal?
Here is another problem i cannot find 5W30 anywhere! I do not see where using 10W30 would matter - am I missing something?
Ray Kane
  #22 (permalink)
Old 12-03-2008, 06:38 AM
as always my .02
Dang 6cyl engines!
I will check it with a mechanical guage while I am changing the oil - anyone know the specs for oil psi at idle and at rpms?
Ray Kane
  #23 (permalink)
Old 12-03-2008, 12:25 PM
Originally Posted by Ray Kane View Post
Dang 6cyl engines!
Here's what the factory service manual says for the V8:
Oil pressure:
At idle 29 kPa (0.3 kgf/cm
2, 4.2 psi) or more
At 3,000 rpm 294 - 588 kPa (3.0 - 6.0 kgf/cm2, 43 - 85 psi)
May be a stupid question, but you've verified the oil level?
Jerome
  #24 (permalink)
Old 12-03-2008, 04:37 PM
Oil pressure:
2, 4.2 psi) or more
Thanks for the numbers
Yes I checked the oil level - I wanted to make sure I wasn't a complete bonehead.
Does 10W30 and 5W30 make taht much of a difference? My old honda would take any 30 weight oil with no problems
Ray Kane
  #25 (permalink)
Old 01-10-2009, 11:46 AM
- Other - '92 4runner
Last Online: 01-10-2009 11:46 AM
DIRT CLOD may have some regrets.
DIRT CLOD's Photo Albums
ok...seen this problem. Don't know if its same cause but I'd seen similar problems. Did you add any kind of snake oil when you change the oil? Often these additives are so sticky and thick that they can move slowly through the oil journals therefore when you let off the gas the pressure the oil pump is trying to create is released back into the pan and res.. i'd go with the sending unit if you arent using ANY kind of additive. if these two dont seem to catch it up then check the oil pump pick up screen.( sorry you'll have to pull the pan.) Snake oil huh? Oil has all the neccessary additives it needs to perform at its peak performances. try a thinner oil with no snake oils. hope at least some of this rambling was helpful..lol
. Jeb
  #26 (permalink)
Old 01-10-2009, 03:26 PM
No snake oil used, but the problem seems to have "corrected" itself.
I will tell you what I did but first I have another question - Why does it take almost 7 quarts of oil {book says 5.5} to reach the proper mark on the dipstick? Whether the dealership changes my oil or I change it myself it has to be topped off.
I checked the fluids before a long trip and everything was at its proper levels. Cruising down the turnpike at 70mph the pressure was holding steady just under the 1/2 mark. I brought the speed up to around 85-90 for a few minutes and the pressure held steady just under the 3/4 mark.
Since then the pressure gauge has been responding normally.
Ray Kane
  #27 (permalink)
Old 01-10-2009, 11:24 PM
netrickyaz's Avatar
05' Tundra (Tun-Tun)
Dealer : Desert Toyota Scion Of Tucson
2005 Toyota Tundra
Last Online: Yesterday 11:16 PM
Images: 117
netrickyaz is a splendid one to behold. netrickyaz is a splendid one to behold. netrickyaz is a splendid one to behold. netrickyaz is a splendid one to behold. netrickyaz is a splendid one to behold. netrickyaz is a splendid one to behold. netrickyaz is a splendid one to behold. netrickyaz is a splendid one to behold.
Send a message via AIM to netrickyaz netrickyaz's Photo Albums My eBay
the 10w-30 and 5w-30 don't make that much of a difference no...toyota says you can use 10w if no 5w is available but at the next oil change they say to go back to 5w so your ok with using 10w at least once in a while when you can't find 5w. sometimes the auto stores sell out of my 5w but i usually look at other stores or ask if they have some in the back, never had to use 10w though so never seen how engine runs differently or anything like that. what gets me is they stock equal amounts of both, usually, and the 5w is used more commonly from what i have seen.
p.s. is the 5.5 with a filter change? or without? but that sounds like a weird issue idk what it takes to fill it because i have the maintanence program so toyota does the work and i just check fluids and they are always good so i can't help ya on that one.
2005 Toyota Tundra Blue Steel Metallic (SR5® Access 4.7L i-Force V8 with VVT-i)
( De-Badged, K&N 77 Series Intake With Painted Tube (Wrinkle Black), ScanGauge II, V-LEDS 5000k Hi/Lo Headlights, V-LEDS 5000k Fogs (as DRL), Blacked Out Headlights, Tinted Side Markers, Black LED Tail Lights, Black Side Molding, Black Billet Grille, Kenwood Deck, Infinity Speakers, Alpine 5-Channel Amp (Doors), 12" Infinity Sub(Custom Box), Infinity Mono Amp (Sub)
(Future: 3" Lift Kit, Magnaflow 22" Single-Dual Exhaust, Electric Fan Conversion, 17" Sport Tundra Rims/or/17" Limited Rims Powder Coated Black)
  #28 (permalink)
Old 01-11-2009, 06:43 AM
LGL002's Avatar
Dealer : Rudy Luther's Toyota
2003 Toyota Camry SE ,V6, Nav,
- Other - 1969 Ford Torino GT,
2004 Toyota Tundra Limited A/C 4X4,
2000 Toyota Tundra SR5,TRD,AC 4X4
Last Online: Yesterday 08:40 PM
Images: 17
LGL002 is on a distinguished road. LGL002 is on a distinguished road. LGL002 is on a distinguished road. LGL002 is on a distinguished road.
LGL002's Photo Albums
I think you may be looking at the Imperial measure not the US measure which is 6.5 qts with a filter change, I like some others find it takes 7 US qts with filter to hit the full mark on the dipstick.
Larry
2003 Camry SE V6 Navigation, Sirius, Lunar Mist
Optima 34R battery
Some people should not be allowed access to tools without books!!!
  #29 (permalink)
Old 01-11-2009, 09:13 AM
Larry
I just checked the book again and it states 5.5 US qts or 4.6 Imperial qts with oil filter change. For the 5VZ-FE
Like yours - mine takes almost 7 qts
MAYBE THERE WAS A DIPSTICK RECALL!!!
Ray Kane
  #30 (permalink)
Old 01-11-2009, 09:22 AM
netrickyaz's Avatar
2005 Toyota Tundra
Images: 117
maybe the 2003 manual just had a misprint? the 2 people with 2003 say it takes the same to fill but the manual says lower.
