Old 12-16-2008, 02:20 PM
stevekx's Avatar
Dealer : Johnstons Toyota Scion of Middletown
2003 Toyota Tundra
Last Online: Yesterday 02:13 PM
stevekx is on a distinguished road. stevekx is on a distinguished road.
stevekx's Photo Albums
Default 93 octane or not
My 2003 (with 100k miles) filled with 93 Octane runs better than with 89 octane. Same MPG, but my seat of the pants feeling that the engine runs smoother and quieter. Am I dreaming or what?
bug deflector/side fender turn signal/went shades/back rack/tool box/rear strip light/nerf bars/top light bar/front alternating flashers/rear strobes in turn & stop lights/bedmatt & linert/all badges removed/Helwig sway bar
Old 12-16-2008, 07:27 PM
Highwaylizard's Avatar
Dealer : Butler Toyota Scion
2004 Toyota Tundra Limited DC 4.7 4spd
Last Online: Yesterday 08:52 PM
Images: 66
Highwaylizard creates their own distinguished roads. Highwaylizard creates their own distinguished roads. Highwaylizard creates their own distinguished roads. Highwaylizard creates their own distinguished roads. Highwaylizard creates their own distinguished roads. Highwaylizard creates their own distinguished roads. Highwaylizard creates their own distinguished roads. Highwaylizard creates their own distinguished roads. Highwaylizard creates their own distinguished roads. Highwaylizard creates their own distinguished roads. Highwaylizard creates their own distinguished roads.
Highwaylizard's Photo Albums
Default Re: 93 octane or not
A lot will depend on the brand of gasoline that you use. It is my practice and personal belief that a tank of Shell V-Power (93 Octane) every thousand miles is a good thing.
To learn more about gasoline quality check out these websites:
Big names fail to make gasoline grade
and
Top Tier Gasoline
Running a top tier high octane gas, like Shell V-Power can help smooth things out and run quieter for awhile. A lot of guys just run a bottle of quality fuel injector cleaner (Lucas is pretty good) with every oil change. For those who are running extended oil change intervals then the fuel injector cleaner probably should be run every three to five thousand miles.
Highwaylizard 2004 Tundra Double Cab Limited Edition 4.7 liter V8, four speed automatic, four wheel drive, testing platform for fuel economy, self designed cold air intake using ram air principle, Fitch Fuel Catalyst, Aero Turbine, "Foolie Exhaust" from Aero Turbine back, True Flow Intake with True Flow foam filter, Mobile 1 in the engine, Wixx oil filter, Royal Purple in the differentials. 3:91 gears in the front (Thanks Cajuntundra!) and rear (Thanks Nytrousboy!) differentials, Toyo H/T Open Country tires
183,288 miles on the odometer Tundra Fuel Economy Blog
Old 12-16-2008, 08:29 PM
USAFTUNDRA's Avatar
Dealer : Northcutt Toyota
2005 Toyota Tundra,
- Other - 2006 Honda CRV SE
Last Online: 05-17-2010 07:27 PM
Images: 107
USAFTUNDRA is on a distinguished road. USAFTUNDRA is on a distinguished road.
USAFTUNDRA's Photo Albums
Unless you are getting some prattling or pre-ignition knock I'd run as low octane as I could. I had a Ford ranger that prattled on hills unless I ran 93. Made me made as crap! I'd do like was said above. Run something like a good shell or chevron and I would go as low a grade as I could.
Old 12-17-2008, 06:08 AM
Dealer : John Weiss Toyota City
2009 Toyota Rav4 V-6 FWD,
2000 Toyota Tundra SR5 TRD 4X4
Last Online: Yesterday 11:45 AM
Images: 1
INDYMAC is on a distinguished road. INDYMAC is on a distinguished road.
INDYMAC's Photo Albums
My truck runs better on 93 too. It always has. The owner's manual says to run 87 or higher. I'm sticking with the higher.
Old 12-17-2008, 10:35 AM
Dealer : Germain Toyota Scion of Sarasota
2003 Toyota Tundra,
2007 Toyota Corolla
Last Online: Yesterday 07:30 AM
PapaPS is a splendid one to behold. PapaPS is a splendid one to behold. PapaPS is a splendid one to behold. PapaPS is a splendid one to behold. PapaPS is a splendid one to behold. PapaPS is a splendid one to behold. PapaPS is a splendid one to behold. PapaPS is a splendid one to behold. PapaPS is a splendid one to behold. PapaPS is a splendid one to behold. PapaPS is a splendid one to behold.
PapaPS's Photo Albums
I run mid grade (89) in all my engines.....lawnmower,atv's....saws....truck and the corrolla too..........it is just a "good"? thing that I do for all my engines........do they need it? well that is debatable, but,thats the way I was raised.......maintain your equipment.........oil, good gas, air cleaner .........I have never lost an engine.......I have 115,000 on my 03 and have no issues with knock at all........and it is driven like I stole it sometimes.........
Old 12-17-2008, 11:51 AM
Crazy Ivan's Avatar
Crazy Ivan that travels a lot!
Dealer : Toyota of Greer
2001 Toyota Tundra,
- Other - 03 Nissan Maxima SE
Images: 64
Crazy Ivan has done just about everything...and then some. Crazy Ivan has done just about everything...and then some. Crazy Ivan has done just about everything...and then some. Crazy Ivan has done just about everything...and then some. Crazy Ivan has done just about everything...and then some. Crazy Ivan has done just about everything...and then some. Crazy Ivan has done just about everything...and then some. Crazy Ivan has done just about everything...and then some. Crazy Ivan has done just about everything...and then some. Crazy Ivan has done just about everything...and then some. Crazy Ivan has done just about everything...and then some.
Crazy Ivan's Photo Albums
Originally Posted by PapaPS View Post
I run mid grade (89) in all my engines....and it is driven like I stole it sometimes.........
I always drive mine like its stollen
2001 Toyota Tundra SR5 4x4 - JBA Ceramic Headers, Walboro 255LPH Fuel Pump, 1UZ Rods, IPT valve body, 20" x-sp enkei wheels, 7009 navi w/custom JBL wire harness + OEM XM/Sirus radio, drive by wire, and many other mods.
Thanks to RCsTundra (see his signature for Toyota Tundra service manuals)
2003 Nissan Maxima SE
- (Platinum Edition), 3.5L (VQ35DE Engine), 4 speed auto, w/ factory Navigation, Xenon Headlights, Heated Steering Wheel/Seats, + way too many other options. Pretty quick for family car. (Nissan FSM http://www.nicoclub.com/FSM/)
Old 12-17-2008, 12:44 PM
Dealer : Al Hendrickson Toyota
2005 Toyota Tundra
Last Online: 07-27-2010 11:11 AM
GORILLA has a brilliant future. GORILLA has a brilliant future. GORILLA has a brilliant future. GORILLA has a brilliant future. GORILLA has a brilliant future. GORILLA has a brilliant future. GORILLA has a brilliant future. GORILLA has a brilliant future. GORILLA has a brilliant future. GORILLA has a brilliant future. GORILLA has a brilliant future.
GORILLA's Photo Albums
hi, it isn't neccessary to run any octane over 87. but it seem's to run better with higher octane, once the ECU unit adjust's for it.
also according to what i have read, higher octane burns cleaner.
also if you have modified your tundra than there is a suggestion to run higher octane, such as 91 or higher.
i used to use 87, than after all the mod's especially the UNICHIP, i only used 93octane.
but than i tried a experement slowly decreasing my octane to 87.
i never had any cell code's or any codes at all.
but i did notice a difference in performence at lower octane.
now since gas has gone more than double the price down from 450+ for 93 octane to 195, i switched back, and haven't looked back.
the moral of the story is , if you don't have any mod's, than in my opinion you are wasting your money buying 91 or higher octane. but if you like it and you feel ,your tundra run's better, than go ahead, and make yourself happy.
gorilla
Old 12-17-2008, 12:45 PM
RMassaro's Avatar
Dealer : Sloane Toyota
2006 Toyota Tundra,
2008 Toyota Sienna
Last Online: 05-27-2010 01:13 PM
RMassaro may have some regrets.
RMassaro's Photo Albums
I've run Amoco/BP 93 in my truck since I got it.
2006 Tundra Limited Spectra Mica Blue
TRD Exhaust
Front Skidplate by Skid Plates
2008 Sienna XLE
Old 12-17-2008, 04:42 PM
HOGWILD's Avatar
Dealer : American Toyota
2006 Toyota Tundra,
1993 Toyota Truck,
2007 Scion tC
Last Online: Yesterday 07:25 PM
Images: 11
HOGWILD is a splendid one to behold. HOGWILD is a splendid one to behold. HOGWILD is a splendid one to behold. HOGWILD is a splendid one to behold. HOGWILD is a splendid one to behold. HOGWILD is a splendid one to behold. HOGWILD is a splendid one to behold. HOGWILD is a splendid one to behold. HOGWILD is a splendid one to behold. HOGWILD is a splendid one to behold. HOGWILD is a splendid one to behold.
HOGWILD's Photo Albums
Nice article took me a few minutes to understand it but makes since!
Octane Ratings - Premium vs Regular Gas: What’s The Difference?
I say NOT unless your engine is tuned to burn it !
Old 12-17-2008, 05:05 PM
OntheRox's Avatar
Proprio una storia vera
2007 Toyota Tundra,
- Other - 2003 Subaru Leg GT
Images: 65
OntheRox has a brilliant future. OntheRox has a brilliant future. OntheRox has a brilliant future. OntheRox has a brilliant future. OntheRox has a brilliant future. OntheRox has a brilliant future. OntheRox has a brilliant future. OntheRox has a brilliant future. OntheRox has a brilliant future. OntheRox has a brilliant future. OntheRox has a brilliant future.
Send a message via AIM to OntheRox OntheRox's Photo Albums
For my Subaru, I cannot use a higher octane fuel...it burns to hot and to fast.
Some engines will not burn all the fuel and can send unburned excess fuel into the catalytic convertor and cause damage to the emissions system.
2007 Tundra DC 4.7 SR5 TRD 4X4
Garmin Nuvi 1300T
Stubby antenna
Clear Bra,
ARB Bumper,
Line-X,
325/60/18 Nitto Terra Grapplers,
18" KMC XD Hoss Black,
ARE CX Series Topper,
KC Rally 800 long range lights,
Tinted windows,
Wet Okoles Frt & Rear,
Weather Tech rain deflectors,
Weather Tech floor liners frt/rear,
Ready Lift 2.4"
Bel Vector 995 Radar Detector,
Wilson cellular booster,
Cobra 75 WX ST Compact/Remote CB,
Sirius Satellite Radio,
S&W .38 Spl Laser grip (hot pink),
TRD sway bar (black widow style),
Debadged except TRD sticker,
Roxy Sticker
TS Tank Top
____________________________
Wish list:
Horn Blaster train horn, ARB rear bumper (if they ever make one) or line-x rear bumper, Color matched fender flares, Underseat storage of some sort, Winch (if i can ever afford one), Sun roof! Going broke thinking about it.
__________________________________________
I need a new word of the month people!
Old 12-17-2008, 05:55 PM
USAFTUNDRA's Avatar
2005 Toyota Tundra,
Images: 107
Good article! Here is another one:
HowStuffWorks "What does octane mean?"
Old 12-17-2008, 06:33 PM
shall36's Avatar
Dealer : Central Florida Toyota Scion
2003 Toyota Tundra
Last Online: 07-24-2010 02:38 PM
shall36 is on a distinguished road. shall36 is on a distinguished road.
shall36's Photo Albums
High octane burns slower but cleaner...it allows the computer to put more timing in. When boosting or running a high compression engine, high octane is required. Not sure if your pants seat is properly calibrated...probably not. Many people claim idle quality goes up with "high" octane. 93 octane is a joke...back in the day, you could get 108. You can buy 100 CAM4, but that would be a real waste in a Tundra. 100LL is available at the local small airport, but don't get caught putting it in your street ride...yes, I'm buying this for my airboat....and don't use it in a vehicle with cats as you will promptly trash them.
Rule of thumb for iron-head engines: 10 octane points per point of compression.
Aluminum heads let you run more compression on same octane.
Chevy iron heads are more forgiving than many others. You can stretch the top rule.
FYI...some of the hi-po engines from the muscle car era...think '67 L88...required 108 octane from the factory. I had a 400 WT Pontiac with 10.5:1 compression that would ping on 93. It really needed 100 octane to be happy.
Pigs will eat cheesecake and my Tundra will be happy on 87.
http://www.daveramsey.com/
Must See Video: Drive Free Cars for Life
Old 12-17-2008, 10:08 PM
OntheRox's Avatar
2007 Toyota Tundra,
Images: 65
Hers some more info along those lines:
http://www.rockettbrand.com/techsupp...ationships.pdf
Garmin Nuvi 1300T
Stubby antenna
Clear Bra,
ARB Bumper,
Line-X,
Tinted windows,
Ready Lift 2.4"
Roxy Sticker
TS Tank Top
Wish list:
Old 12-19-2008, 06:44 PM
Tones's Avatar
Dealer : Gullo Toyota Scion of Conroe
2001 Toyota Tundra AC V8
Last Online: 12-06-2009 12:03 PM
Tones may have some regrets.
Tones's Photo Albums
You feel it runs better because knock sensor does not retard the timing as much. However, these engines are not really tuned for it. There is not enough performance gained. There also aren't any more detergents than in RUG as far as I know, so why waste the money?
Old 12-20-2008, 09:00 AM
Dealer : Longo Toyota
Last Online: 12-26-2009 08:46 AM
gsxrsquid may have some regrets.
gsxrsquid's Photo Albums
When I got my 2000 I ran 93 for a couple years then dropped to 97. It runs every bit as good.
As has been said, more octane slows down the flame spread to avoid detonation so if you don't have a detonation problem the lower octane will give you great power.
What makes the difference is the quality of fuel. I run chevron because techron has been shown to be one of the best detergents. Years ago I ran shell but found out it was a dirty gas. I never go into a no name station unless I am going out of town and desperate cause you have no clue what you are using.
171k on mine and when I put my foot in it, it goes
Sponsored Links
