  #16 (permalink)
Old 01-29-2009, 12:26 AM
Matador98's Avatar
Dealer : Toyota of Santa Maria
- Other - 1987 Land Cruiser,
1999 Toyota Land Cruiser UZJ100,
Last Online: Today 11:54 AM
Images: 20
Matador98 is on a distinguished road.
Send a message via AIM to Matador98 Matador98's Photo Albums
Default Re: Bilstein 5100 - which setting should I choose
Originally Posted by TundraSurfBum View Post
having rake doesn't change the load on an axle. My 5100s haven't settled at all and they have been on for just over 6 months. 5100s are shocks not springs! you are using your oem springs (if they are going to settle they most likely already have), if you are getting settling (especially an inch!) then you may have faulty shocks.
The 5100s lift the truck by altering the pre-load on the spring by moving the spring seat. Therefore removing it from it's OEM setting. Also, if you CHANGE rake, your changing the angle of the truck about the CG of the truck, therefore changing the load on each axle. Probably negligible, but it'll change it nonetheless.
Did you measure your fender? Are you sure nothing settled? I did, and I had about 3/8 to 1/2 in after about 1500 miles and one month. And yes, of course I drove the truck for a bit before I measured. I'm not JACKass, I'm an aerospace engineer, thanks for the lesson on how camber and caster change after you jack an IFS.
2006 Tundra DC, 80K, K&N Drop-in, Spintech Truck/RV Muffler, BedRug, Bilstein 5100s, VSE Sub
Previously 2000 Tundra, 94K, K&N Drop-in, Spintech Truck/RV Muffler, Hellwig, Bilstein 5100s, 2005 Sequoia Center Console Installed and looking awesome! - TOTALLED
1999 UZJ100 Land Cruiser, 225K, new carpet, no major Mods planned; it's the wifeys
1987 FJ60 Land Cruiser, 209K, K&N Drop-in, Jacobs Ignition, Jacobs Wires, Dynomax Muffler and Hi-Flow Cat, Electric Fuel Pump Conversion, Rebuilt Carb, Rebuilt Combination Manifold, SS EGR Tube, Someday...A Lift
Proud Member of the CBTMA
  #17 (permalink)
Old 01-29-2009, 06:22 AM
TundraSurfBum's Avatar
Dealer : Wesley Chapel Toyota
Last Online: 03-09-2009 07:27 AM
Images: 5
TundraSurfBum is on a distinguished road.
TundraSurfBum's Photo Albums
don't think anyone called you a jackazz, although didn't aerospace engineers "engineer" the shuttles that blew up? lol. I said you probably have faulty shocks. the change of COG from .5 - 1.5" rake is as you said NELIGIBLE if at all. Yes I am sure. I took measurements at install, a month later, and after reading this post.... ALL are the same. additionally no one even mentioned camber and castor in relation to IFS... of course it changes.
2006 DC SR5
Bilstein 5100s F&R
Wheelers 1.5" AAL
285 Nittos on OEM Alloys
Flowmaster Delta 40
LUND Genesis Tri-Fold Tonneau
WADE in-Channel Visors
Lil Boom under the seat compliments of RF
Full LED conversion
Nothing too fancy, just better than stock!
  #18 (permalink)
Old 01-29-2009, 05:50 PM
Dealer : Folsom Lake Toyota Scion
2004 Toyota Tundra 4x4 Limited
Last Online: Today 05:03 PM
rockcrawler is on a distinguished road.
rockcrawler's Photo Albums
Originally Posted by Tjheitz View Post
I have an access cab (which is lighter than yours), but I have mine set on the middle setting with an add-a-leaf and 5100s in the rear. There is slight forward rake, I beat on these shocks pretty hard and they take it well
I am confused about the 5100's in the rear. I thought that if you used the 5100's up front and wanted to also raise the rear you could use the 5100 rear shocks OR install AAL's. But you installed rear 5100 AND AAL's. Is that necessary?
If you use 5100's in the front only and AAL's in the rear do you need to also install a longer shock due to the AAL?
  #19 (permalink)
Old 01-29-2009, 07:10 PM
2005 Toyota Tundra
Last Online: 11-16-2009 08:02 AM
watchdog is on a distinguished road.
watchdog's Photo Albums
Rockcrawler,
I'm also a little confused. I was hoping putting 5100's in the rear wouldn't raise it at all or at most just a bit.
My plans unless I hear a compelling reason not to is to go with the 3rd or 4th notch on the front 5100s and leave the rear springs alone and just replace the rear shocks with 5100s. I just trying to lift the front just about 1 - 1.5 inches to make my bull bar not look like they are nearly dragging the ground. I'm would also like to keep a slight downward front slope if I can.
  #20 (permalink)
Old 01-29-2009, 07:28 PM
dsrtrcr01's Avatar
2005 Toyota Tundra Doublecab TRD 2wd,
2001 Toyota Celica 17" Rims, TRD Bumper,
1995 Toyota Truck Pre Runner
Last Online: Today 04:02 PM
Images: 11
dsrtrcr01 has blessed us with their presence. dsrtrcr01 has blessed us with their presence. dsrtrcr01 has blessed us with their presence. dsrtrcr01 has blessed us with their presence.
dsrtrcr01's Photo Albums
Changing the rake DOES change the weight on each axle. When you lift the front it moves the weight towards the rear which would Lighten the front weight making the springs hold Less weight. It changes how the truck handles and steers. You will not notice it on a street truck much but on My Desert truck you can really feel how it changes when you have it sitting pre-runner (nose high) and then stink bug. In the desert the truck handles much better with the stink bug rake putting more weight on the front axle so it steers in the dirt much better and handles the bumps better.
After ALL that there should be NO settling when you install the 5100's. You are running the stock spring which should have been on your truck up until now so it has already settled when you bought the truck and put all those miles on it. The shock DOES NOT hold up the truck just the spring does. The shock has different positions to put the spring at and you just move the spring higher on the shock body to lift the truck. Now the spring WILL SAG if you do more off roading and beat the spring up which some people may do after installing the 5100 because it will handle better.
'05 Tundra DC TRD 2 WHL: The TOW truck, Spectra Mica Blue, with Kenwood H/U, Kenwood Amp and crossover. Infinity 6010cs, 10" Rockford SUB, 6 disc CD Changer mounted in Center console, SWI-X to retain steering wheel controls, 7" TV with DVD. Tinted Windows, Three chamber Flowmaster, Painted front chrome strip
  #21 (permalink)
Old 01-29-2009, 07:29 PM
dsrtrcr01's Avatar
Images: 11
Originally Posted by watchdog View Post
Rockcrawler,
Installing 5100's on the rear of the truck WILL NOT lift it at all. It is just a shock. The front end is held up by the spring and the rear is held by the leaf springs. NOT the shocks. To lift the back you need Blocks, AAL, New leafs or something OTHER then jsut shocks.
Hope that helps some
  #22 (permalink)
Old 01-29-2009, 07:40 PM
Images: 5
well it's a good thing we are talking about a street truck then
2006 DC SR5
Bilstein 5100s F&R
Wheelers 1.5" AAL
Flowmaster Delta 40
Full LED conversion
  #23 (permalink)
Old 01-29-2009, 07:48 PM
So the front 5100's provide lift but the rear 5100's don't? That's odd.
I was convinced that the rear 5100's also provided an adjustable amount of lift. I guess I need to do more research.
  #24 (permalink)
Old 01-30-2009, 07:11 AM
Images: 5
correct. the fronts have an adjustable spring perch. The rears just accommodate lift. menaing they have more travel than stock.
2006 DC SR5
Bilstein 5100s F&R
Wheelers 1.5" AAL
Flowmaster Delta 40
Full LED conversion
  #25 (permalink)
Old 01-30-2009, 11:11 AM
dsrtrcr01's Avatar
Images: 11
You will notice it on a street truck if you drive it hard. Most people do not drive a Lifted truck hard on the turns but the truck will plow more once you shift the weight to the rear. BUT once lifted you usually add bigger wider tires to look better which have a wider foot print and help out a little in the cornering. but you will notice it plow if you hit turns faster once lifted. Plus if you tow with a nose high vehicle the sag will be more and then plowing and stopping will be affected.
As surfBum said the 5100's on the rear are just shocks and the leaf springs do not mount to the shock the way the coil spring does on the front so there is no higher setting to set it at. in the rear they are just shocks.
  #26 (permalink)
Old 01-30-2009, 11:35 AM
Images: 5
I drive mine like I stole it.... guess i just don't pay much attention to it
2006 DC SR5
Bilstein 5100s F&R
Wheelers 1.5" AAL
Flowmaster Delta 40
Full LED conversion
  #27 (permalink)
Old 01-30-2009, 11:43 AM
Marauder's Avatar
Last Online: 11-22-2009 09:55 PM
Images: 16
Marauder is on a distinguished road.
Marauder's Photo Albums
Just like the others said. Since the fronts, the coil sits on the shock (coilover), the adjustable spring perch gives you lift. In the rear, the shocks mount seperately, since the springs in the rear are leaf springs (not coil springs).
So to lift the rear you either need new leaf springs, or lifting blocks.
the 5100 rear shocks give you a longer travel and allow for a lifted rear without changing the shock performance. That's why they advertise a certain lift on the rear shocks, meaning its meant to work with a lifted rear end.
2006 Tundra Access Cab V8 - TRD
16x8 Konig Countersteer w/Nitto TerraGrapplers 285/75R16
Bilstein 5100 front/rear, Wheelers 1.5" rear blocks
Dynomax cat-back w/Cherry Bomb Pro muffler
Pioneer headunit w/Alphasonic amp and Sochse speakers
HID retrofit in the works, Acura TL bi-xenon projectors w/BMW ZKW lenses
Truxedo Truxport
Trail FX black steps bars
  #28 (permalink)
Old 01-30-2009, 02:21 PM
2005 Toyota Tundra
You guys are great, that clears up a lot of questions I had. Looks like I'll be taking the plunge with the 5100's sometimes next week when I get a chance to tackle them.
Thanks again.
  #29 (permalink)
Old 01-30-2009, 03:38 PM
Images: 5
you won't be sorry
2006 DC SR5
Bilstein 5100s F&R
Wheelers 1.5" AAL
Flowmaster Delta 40
Full LED conversion
  #30 (permalink)
Old 02-02-2009, 01:45 PM
2005 Toyota Tundra
To those of you that installed the Bilstein 5100 up front of your double cab 2WD Tundras, was the lift you achieved greater than the average which Bilstein states in the paperwork included with the shocks?
I noticed the 3rd settings is stated as having 1.3 " average lift, but I was wonder if most owners found that to be a little over or under stated?
