  #46 (permalink)
Old 03-16-2009, 03:23 PM
Dealer : Heyward Allen Toyota Scion
2004 Toyota Tundra,
2008 Toyota Sequoia
Last Online: 11-11-2009 02:41 PM
kwhitley76 is on a distinguished road.
kwhitley76's Photo Albums
Default Re: Bilstein 5100 - which setting should I choose
watchdog...can you post some pics. I am interested in your exact setup..by the way what size tire did you go with?
  #47 (permalink)
Old 04-15-2009, 06:54 PM
GK GK is offline
Dealer : Jim Norton Toyota
2002 Toyota Tundra
Last Online: 06-29-2009 05:52 PM
GK is on a distinguished road.
GK's Photo Albums
I just got back from picking up my truck up from the shop, had the 5100's installed all the way around.
I've only been on them for about 10 miles of city driving so I can't provide a lot of feedback yet, but I'm going on a couple hundred mile trip this weekend that will include at least 30 miles of dirt/rock/double track roads. I should have a better report by next week.
There were five(5) height notches on the front shocks.
I have them installed on the MIDDLE (3rd) Position.
The rears increased the height over my stock originals by about an inch as well.
For the record, my truck is a 2002, 4WD V8 Limited with 123k miles.
Here are some pics.
Front Height
Rear height
tire size because I know someone will ask
  #48 (permalink)
Old 05-13-2009, 05:23 PM
2005 Toyota Tundra 2WD DC w/ SnugTop
Last Online: 11-17-2009 02:30 PM
obssc is on a distinguished road.
obssc's Photo Albums
Here are some pics.
Front Height
Rear height
Did you have to do a diff. drop in that position?
I am taking my truck in tomorrow to have them installed.
Thanks.
  #49 (permalink)
Old 05-13-2009, 05:45 PM
GK GK is offline
2002 Toyota Tundra
GK's Photo Albums
I didn't, I don't think most of the people are dropping the diff unless they're using the top setting.
but if you know different please let me know, I don't want to be causing any undo wear.
thanks
  #50 (permalink)
Old 05-13-2009, 06:05 PM
Dealer : Folsom Lake Toyota Scion
2004 Toyota Tundra 4x4 Limited
Last Online: 11-17-2009 07:47 PM
rockcrawler is on a distinguished road.
rockcrawler's Photo Albums
GK: What tire size did you go with?
Looks like you posted a picture with this info but it is not displaying in my browser.
I'm going with 285/75 r 16s so I'm curious how these will compare with your new set-up.
Thanks.
  #51 (permalink)
Thanks, and I will.
  #52 (permalink)
Old 05-13-2009, 07:38 PM
GK GK is offline
2002 Toyota Tundra
GK's Photo Albums
Thanks.
Nothing fancy on mine, BFG All-Terrains 265/75R16
  #53 (permalink)
Old 05-14-2009, 05:43 PM
Originally Posted by TundraSurfBum View Post
I got 2.5" on the highest setting, I'd say it is right on
A little help here.....the shop installing mine just called and said they have a 4" differential between the front and rear. The front were set to the 2nd notch from the top. Said the headlights were pointing straight up (exaggerated).
Something does not add up.
Anyone have some input.
Thanks.
  #54 (permalink)
Old 05-14-2009, 06:08 PM
2004 Toyota Tundra
Last Online: 10-18-2009 09:22 AM
Tom0895 is on a distinguished road.
Tom0895's Photo Albums
Sounds like they didn't install them correctly. The 5100s in the rear should not give you any lift. If they installed the fronts at 2nd notch from top, from what I've read here that would give you about 2 inches of rise in the front. I installed mine on top notch and got almost 3 inches.
I think the only way they could be that high is if they installed the spring perches upside down !!
  #55 (permalink)
Old 05-14-2009, 06:14 PM
Thanks Tom....I'll call over there and check.
  #56 (permalink)
Old 05-14-2009, 07:40 PM
Spring perches are in correctly...
If the shock length is roughly 2" longer than the OEM's being replaced, is that the difference? If so, if set on the lowest setting, the truck should be about level?
Geez, should be a simple install.
  #57 (permalink)
Old 05-14-2009, 09:36 PM
GK GK is offline
2002 Toyota Tundra
GK's Photo Albums
I think if you put it one the top level,(5th Position) you will be easily 1.5 to 2" higher than the rear.
Mine are on the 3rd, MIDDLE position and its almost perfect, about .5" lower in the front.
I wouldn't go above the 3rd position unless adding a lift of some sort to the rear.
JMHO...
  #58 (permalink)
Old 05-15-2009, 09:08 AM
I picked the truck up last evening and was surprised at the look of it.
After what the shop told men it looked and rode like, I told them to set the shocks on the lowest setting. The front is still about 2" higher than the rear. Looks pretty good and rides fine. I am a bit worried about extra stresses in the future because it is higher than expected.
Will post up some pictures in a bit.
  #59 (permalink)
Old 05-15-2009, 09:17 AM
GK GK is offline
2002 Toyota Tundra
GK's Photo Albums
if you're on the lowest setting it should be sitting at the stock height, if that isn't the case you either were shipped the wrong parts or the shop installed them incorrectly.
Post some pics of the install, On mine I can lay on the ground and see/feel which position the rings are mounted in..
  #60 (permalink)
Old 05-15-2009, 12:13 PM
OK....Just heading out to the hardware store and when I turn to get on the on ramp I hear a bang! Pull over and check the passenger side and the friggen c-clip let loose.
Spring perch is resting on the bottom of shock.
Any ideas on what went wrong...anyone seen this mess before?
Pissed.
