Old 01-30-2009, 11:40 AM
Last Online: 03-21-2009 06:41 PM
Beetle66 is on a distinguished road.
Beetle66's Photo Albums
Default Cold start no throttle response?
A little history 2002 Tundra V8 63,000 mi. Purchase new. I had a check engine code. Technician read code and was O2 sensor heator or something like that! He is a local mechanic and told me some sensors were difficult to remove (almost siezed) and would damage threads beyond repair if forced. He tried and said he could tell that it was going to be trouble if forced. I was having no driveability problems so we postponed repair until warmer weather. In the past month we have had a blast of cold weather. One morning I started it up no problem and as I went to apply gas, the pedal moved but the engine didn't respond? I had to push the pedal quite a ways down before the engine RPM's came up enough to make the truck move. Sensing something was wrong I shut it down and looked around visually and nothing seemed wrong. Started it up and it was fine.....completely normal. Has done it 3 times since each time a shut done and restart has cured the problem. Everytime was cold weather. My question with my check engine light already on from the O2 sensor I have no idea if it has thrown another code. Can someone tell me what might be my problem from my description? Thanks in advance!
Old 01-30-2009, 06:51 PM
'00 Tundy's Avatar
Dealer : Del Toyota
Last Online: Today 10:46 AM
Images: 10
'00 Tundy is on a distinguished road.
'00 Tundy's Photo Albums
Default Re: Cold start no throttle response?
not quite sure of your problem, but about how long do you let it warm up before trying to take off?
2000 Toyota Tundra A/C- 4.7
-Magnaflow dual exhaust -K&N cold air intake
-Scangauge II -"Line of Fire"
-15% tint all around -Tail light tint
-10 inch JL sub and 1000 watt amp -Drop Tint
-Future mods
-Spidertrax
-Headers
-Lift
-Tires
Old 01-30-2009, 07:03 PM
Dealer : Apple Valley Toyota
Last Online: Today 12:07 PM
400exboy2 is on a distinguished road.
400exboy2's Photo Albums
not sure if your is the same, but with mine i accidently unhooked the connector one day that goes to the throttle positon senor, it did the same thing as you described. The only thing is when i accidently disconnected mine it did it when it was cold and warm. So it could be something that controls the tps.
Old 01-30-2009, 09:13 PM
vincenzo's Avatar
Dealer : Dan Deery Toyota
Last Online: Today 04:09 PM
Images: 2
vincenzo is on a distinguished road.
vincenzo's Photo Albums
Most likely if you check codes again, you will get code 1121 for the Accelerator Pedal Position Sensor. Pricey little part. Mine has acted up a couple times over a few years. I have not replaced yet. Been a while since it has screwed up... now watch... it'll happen tomorrow.
Old 01-30-2009, 09:26 PM
Two times that it has happened with a long warm up as I cleaned windshields and such. Other couple of times was start up an let idle for only a minute or two.
Old 01-31-2009, 01:41 PM
single's Avatar
Mech. Engr. / Mechanic
Dealer : Riverside Toyota Tulsa
2006 Toyota Tundra SR5 DC
Last Online: 11-19-2009 06:56 PM
Images: 21
single will become famous soon enough.
single's Photo Albums
Go to your local autozone, NAPA, O'reileys or other automotive parts store. Most of them will scan your vehicle for free and give you the trouble codes. Or, buy a scangauge and check them yourself.
White 06 SR5 DC - Westin Nerf bars
Blinglights bedlights - Pop A Lock tailgate lock
TRD aftermarket LSD - Custom Back Up Lights
ScanGaugeII+X - Factory Fogs added
Hellwig 7700 - Firestone Sport Rite Air Springs
Old 01-31-2009, 06:37 PM
It happened again this morning at 6 degrees. I shut it off to restart for the usual fix...........was very hard to restart. Started a couple of times at a very slow idle and died. Cycled the key to off and on again and started and all was fine. I'm afraid one of these days it will decide it has had enough. My luck it will happen with my wife driving.
Old 02-15-2009, 08:52 PM
2000 Toyota Tundra SR5 Ext Cab 4WD
Last Online: 11-16-2009 05:43 PM
roces_81 is on a distinguished road.
roces_81's Photo Albums
I own a 2000 Tundra, live in the artic cold of Alaska, and have experienced the very same problem. Like one of the previous posters mentioned, your problem is the accelerator pedal position sensor and it should throw codes 1120 and 1121. The kicker is the part costs about $500 and I have only been able to find it available through Toyota.
Count your blessings though. I have had the opportunity of experiencing the pedal going unresponsive while in motion. I pulled over and restart the truck which took care of the problem, but it was a little more nerve racking. Good luck.
Old 02-16-2009, 02:36 AM
Cali D's Avatar
Dealer : Bingham Toyota Scion
2002 Toyota Tundra
Last Online: 02-27-2009 01:20 AM
Cali D is on a distinguished road.
Cali D's Photo Albums
If problem is o2 sensor, toyota will replace sensor and manifold up to 90k, that's what they did for me. Call toyota with vin and see if this applies to your rig.
2002 Limited 4WD TRD access cab
Rockford Fosgate front&rear K&N FIPK2 Series 57
Extreme Flow 3" cat-back 4"D 14"L rolled slant chrome tip
N.R.A. hitch plug Aftermarket lighting
Some people live an entire lifetime and wonder if they have ever made a difference in the world, but the Marines don’t have that problem.
—President Ronald Reagan
Old 02-17-2009, 06:25 PM
Tones's Avatar
Dealer : Gullo Toyota Scion of Conroe
2001 Toyota Tundra AC V8
Last Online: 10-10-2009 09:59 PM
Tones is on a distinguished road.
Tones's Photo Albums
On the O2 sensor, tell him not to force it. Just work it back and forth, spraying liberally with PB Blaster or WD40. It will eventually come out.
