I have a 2004 Tundra DC (2WD, TRD, Borla, Moonroof) that I bought used about a year ago. This past December my remote (I only had one at that time) quit working. I figured the battery died, so I installed a new one. Remote still would not work. I located programming instructions for my remote (ELVAT1B) on this forum (the instructions called for turning the key on and off 7 times then holding the lock button, etc.) This worked on the first try. I decided to order a 2nd remote from
ebay.
Before it arrived, I went out to the truck at work to retrieve my glasses. I pressed the unlock button twice (to open the passenger side door) and it opened fine. As I was walking away from the truck I pressed the lock button and nothing happened (it did not lock). I pressed the unlock, then the lock button again (nothing happened either way). So, I figure the remote must be bad; good thing I have another on the way from
ebay. A couple days later the new remote arrived. I went through the programming steps again (several times) and it will not program. Now I have 2 remotes that don't work and I can't program either of them. Any suggestions?
