How to clean broken glass from defroster vents?
+ Reply to Thread
Results 1 to 11 of 11
Thread: How to clean broken glass from defroster vents?
  1. #1
    Join Date
    Jan 2009
    Location
    Charleston WV
    Posts
    3
    Liked
    0 times
    Rep Power
    0
    Default How to clean broken glass from defroster vents?
    My previously broken windshield left quite a mess in the front of my dashboard. Any easy way to reach in and vacuum out the vents? (hard to reach with the small vent lines right below the windshield) Is the dash easy to remove? The windshield is still out and didn't want to install a new one until the mess is cleaned up. Any advice would be greatly appreciated.
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Veteran Member Marauder's Avatar
    Join Date
    Jan 2007
    Location
    Mission Viejo, CA
    Posts
    831
    Liked
    3 times
    Images
    35
    Rep Power
    669
    Default Re: How to clean broken glass from defroster vents?
    I've never had to do that. Only had a window replaced once, but the company that did it cleans up all the broken glass when they do it, including removing any panels to get at all the glass.
    2006 Tundra Access Cab V8 - TRD
    16x8 Konig Countersteer w/Nitto TerraGrapplers 285/75R16
    Bilstein 5100 front/rear, Wheelers 1.5" rear blocks
    Dynomax cat-back w/Cherry Bomb Pro muffler
    Pioneer headunit w/Alphasonic amp and Sochse speakers
    HID retrofit, Acura TL bi-xenon projectors w/BMW ZKW lenses
    Truxedo Truxport / Trail FX black steps bars / Line-X Xtra
  4. #3
    Join Date
    Aug 2007
    Location
    DEERFIELD BEACH
    Posts
    3,958
    Liked
    66 times
    Rep Power
    3316
    hi, when the windshield is off it is easy to vaccume up & out the glass, since thy can gain easy access to the vent's. how that the windshield is back on, it is impossible without removing the whole dash.
    yes, anyone who did the job should have done the job properly, including a good clean up. unless, safelite glass, they use cheap thin & wavey glass. & no clean up. but a new windshield from them is like 200. big differnce in many way's.
    gorilla
  5. #4
    Veteran Member BamZipPow's Avatar
    Join Date
    Feb 2007
    Location
    College Station, TX
    Posts
    689
    Liked
    60 times
    Images
    5
    Rep Power
    4041
    Being that it's a safety issue...have the people who did the install clean up the broken glass. It's part of the deal when they install the glass.
  6. #5
    Join Date
    Jan 2009
    Location
    Charleston WV
    Posts
    3
    Liked
    0 times
    Rep Power
    0
    Thread Starter
    Thanks for the replies. I bought the truck with a broken windshield. The defroster vent is quite small and getting inside with a vacuum is nearly impossible. Any other solutions? I am going to install the new windshield by the way. I was hoping there would be an easy (er) way to do this...
  7. #6
    Join Date
    Aug 2007
    Location
    DEERFIELD BEACH
    Posts
    3,958
    Liked
    66 times
    Rep Power
    3316
    hi,
    if the vaccume hose is to thick,which it is.
    try to get a thinner pipe, or straw, or something like that, and tape it onto the end of the hose.
    now you can get it into the vent's. if you can get something thin and bendable, you are in like flin.
    it might work, since there is no windshield to block you.
    good luck,
    gorilla
  8. #7
    Lurking Member Sox 19's Avatar
    Join Date
    Mar 2007
    Location
    Beecher, IL
    Posts
    48
    Liked
    1 times
    Rep Power
    9
    I'm in need of a windshield as well, and the cheapest I found was Safelite @ $193. This is my second windshield in a year, the first I got for $120, however that company is out of business. Does anyone know of a nationwide company that is better than Safelite?
  9. #8
    Veteran Member Boosted27606's Avatar
    Join Date
    Mar 2008
    Location
    Raleigh, NC
    Posts
    1,071
    Liked
    6 times
    Images
    12
    Rep Power
    1045
    It's easy to remove the glass out of the vent. Simply turn truck upside down, shake and voila ! all the debris are gone................
    All kidding aside, only a vacuum cleaner with a small tool tip can reach down there. Not sure how to remove the ventilation hose from below unless you remove the whole dash assembly.
    Enjoying the awesome 5.7 L engine
    TRD rear Sway Bar, Billet Grille, Heated Seats, Westin Bull Bar and Skid Plate, HELLA driving Lights, Chrome handles and mirrors,
  10. #9
    Join Date
    Feb 2007
    Location
    College Station, TX
    Posts
    689
    Liked
    60 times
    Images
    5
    Rep Power
    4041
    Another option would be to use the vacuum in conjunction with an air hose so it can break the glass free and the vac sucks it up. Or use some wire with sticky tape on it. Just make sure yer wearing yer safety glasses and mask when yer doing all of this.
  11. #10
    Join Date
    Aug 2007
    Location
    DEERFIELD BEACH
    Posts
    3,958
    Liked
    66 times
    Rep Power
    3316
    hi safelite is a cheap way to go, but like i said, there glass is thin, weak, & wavey.
    and usually will brake in time, wether it is cause's by a rock, or a stress crack in a corner.
    maybe that's why they went out of business.
    i used to see them here in florida. i honestly thought i seen a truck not to long ago.
    i bet the dealership oem glass, is 700+.
    good luck,
    gorilla
  12. #11
    E PLURIBUS UNUM FUNGUS's Avatar
    Join Date
    Apr 2003
    Location
    WA
    Age
    36
    Posts
    2,247
    Liked
    57 times
    Rep Power
    25263
    Before you get a cheap windshield.....just FYI
    2008 Tundra Windshield Fire
Quick Reply Quick Reply
Register Now
Log-in
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
