Old 03-03-2009, 08:18 PM
Dealer : Thousand Oaks Toyota
Last Online: 11-16-2009 05:50 AM
Robnsteel is on a distinguished road.
Robnsteel's Photo Albums
Default 00 A/C Problem
So i got my 2000 Tundra about 6 months ago A/C didnt work when i bought it but its that time of the year where its starting to get hot so need to fix this.
I start my Truck and turn my fan on and hit the A/C button it turns on for about 5 seconds and shuts off and the light on the a/c button starts to flash. Ive tried filling the lines with 134a but there full so i know theres no leak. ive inspected the lines to look for damage but noting. I have no idea what could be causing it to shut off after it starts any ideas would help or things i can check
Edit:
Truck only has 78k miles on it engines looks to be in perfect condition no leaks of any sort i keep my engine wiped down and clean to be able to tell if theres leaks.
Thank You.
Old 03-03-2009, 08:23 PM
Marauder's Avatar
Last Online: 11-22-2009 09:55 PM
Images: 16
Marauder is on a distinguished road.
Marauder's Photo Albums
Default Re: 00 A/C Problem
It might not be that's its leaking, but it could be just not at the right pressure difference. The whole system might have to be recharged professionally. Either that, or a actual component, like the compressor needs replacing.
2006 Tundra Access Cab V8 - TRD
16x8 Konig Countersteer w/Nitto TerraGrapplers 285/75R16
Bilstein 5100 front/rear, Wheelers 1.5" rear blocks
Dynomax cat-back w/Cherry Bomb Pro muffler
Pioneer headunit w/Alphasonic amp and Sochse speakers
HID retrofit in the works, Acura TL bi-xenon projectors w/BMW ZKW lenses
Truxedo Truxport
Trail FX black steps bars
Old 03-03-2009, 09:29 PM
duffyatkinson's Avatar
Dealer : Toyota of Riverside
2002 Toyota Tundra,
2003 Toyota 4Runner V6 Limited 4WD
Last Online: Today 03:59 AM
Images: 17
duffyatkinson has much to be proud of. duffyatkinson has much to be proud of. duffyatkinson has much to be proud of. duffyatkinson has much to be proud of.
Send a message via Yahoo to duffyatkinson duffyatkinson's Photo Albums
Agreed. If you don't know what you're doing, you can get the lines all screwed up with improper pressures, air pockets, etc. Best to have it professionally analyzed. Hopefully it's just a discharge/recharge done the right way.
2002 Tundra V8 SR5 2WD AC | Silver Sky Metallic | Chrome Step Bars | Kobalt Low Profile Bed Box
Daystar 2.5" Levelling Lift, 1" Rear Block
Mobil-1 Synthetic 5W-30 | Mobil-1 Synthetic ATF | Magnefine ATF Filter 3/8" | K&N AF #33-2144
NGK Iridium IX Plugs #BKR6EIX | Russell Speed Bleeders #639560 | Josh's Billet Wing Window Latch Upgrade
11/1/2009: 48,050 miles
* * * I highly recommend http://www.auto-rx.com/ for your engine and transmission! * * *
* * * O2 Sensor Replacement DIY: http://www.tundrasolutions.com/forums/1197269-post2/ * * *
Old 03-03-2009, 09:36 PM
Last Online: 09-25-2009 11:22 PM
motech is on a distinguished road.
motech's Photo Albums
a blinking ac light means the compressor is commanded on but has no rotation detected by the sensor try swaping the ac relay with the horn relay to test the relay this is not common on this vehicle or model but sounds like the problem
Old 03-03-2009, 10:53 PM
Where is the Horn Relay and the A/C Relay i took off the relay cover but none are labeled A/C or Horn ive tried searching around on google but no luck finding the location any help is appreciated thank you
Old 03-03-2009, 11:17 PM
sorry the relay for the ac is labled m/g clutch and the horn is labled horn the locations are on the bottom of the cover
Old 03-03-2009, 11:22 PM
yeah i dont have anything under my relay cover labeled like that i know the heater relay should be my a/c but no horn relay This is what mine is ToyoDIY.com
Old 03-03-2009, 11:46 PM
Ok i had my models confused it is the heater relay the best way to cheak this model is to turn the ac switch on and see if you get voltage to the magnetic clutch wire on the compressor also i didnt mention erlier that a blinking light can also mean a locked up compressor.
Old 11-03-2009, 03:10 AM
mcfrazier's Avatar
Last Online: 11-03-2009 03:15 AM
mcfrazier is on a distinguished road.
mcfrazier's Photo Albums
Look for a loose ground wire at top of compressor (gold metal plate with 8mm hex bolt at center). Mine was loose....appears to have been stripped after service.
Old 11-03-2009, 09:22 AM
buckwheat's Avatar
Last Online: Today 12:16 AM
buckwheat is on a distinguished road.
buckwheat's Photo Albums
If the compressor is not running how would you know that the refrigerant level is full? If you added refrigerant on a static system chances are it was low incredible low. But you may have over charged the system which could cause liquid flooding back to the compressor and take out the valves. A quick trip to a pro is going to be a lot cheaper then a new compressor.
