Old 03-21-2009, 05:10 PM
Last Online: 03-21-2009 07:57 PM
TT2000-2WD is on a distinguished road.
TT2000-2WD's Photo Albums
Default Tundra won't start
Hi, I am new and I am here to tell you the dumb trick I pulled over the last week. First of all, I got home one day, parked my truck and somehow didn't close the door all the way. Come out next day - my battery is drained since that lamp was on all night. In dark I hustle my wife's Nissan to the truck, frantically hook it up to jump start. I hook it up, jump in the seat and turn the key - nothing. At this moment cold sweat hits me as I jump out to double check my hook-up - sure enough, I connected negative lead to positive battery port and positive lead to the engine block. F***! Now I am not getting anywhere fast, lol. I open the Fuse box to make sure - sure enough the Main 120A Fuse toast. That day went to local Toyota dealership and ordered a fuse. Got it today, hook it up, try to jump start with a proper set-up this time - it's turning but won't start. Feels like either no spark or no fuel. Just keeps turning. Before I go messing with either, I thought I would ask what else gets affected/blown when you hook up the jump start the wrong way.
Also, this truck is my first V6 - and I started looking for a distributor to check it (I had few issues with a loose distributor on my old Mazda B2200 that would turn and won't start). I couldn't find one so it dawned upon me that V6 don't even use one. I looked around and noticed something that looks like a computer a chip that says "Igniter". Is the whole ignition computerized in Tundras (starting 2000)?
Anyway, my question is - what could be the reason my Tundra not starting after all the debacle that went on over the last few days.
I appreciate any input.
Old 03-21-2009, 05:18 PM
Sanosuke's Avatar
Dealer : High River Toyota
2007 Toyota Tundra SR5 w/4x4
Last Online: 11-17-2009 05:50 PM
Images: 8
Sanosuke is a superior contributor. Sanosuke is a superior contributor. Sanosuke is a superior contributor. Sanosuke is a superior contributor. Sanosuke is a superior contributor. Sanosuke is a superior contributor. Sanosuke is a superior contributor. Sanosuke is a superior contributor.
Send a message via ICQ to Sanosuke Send a message via AIM to Sanosuke Send a message via MSN to Sanosuke Send a message via Yahoo to Sanosuke Sanosuke's Photo Albums
Talking Re: Tundra won't start
Have you tried pressing the accelerator to the floor a bit while turning the key to clear out the flood of fuel in the intake? I'm sure the manual recommends this -- read the owners manual!
And the 1st gen Tundras do not have a distributor, instead they have coils on top of every spark plug instead!
Sanosuke!
Old 03-21-2009, 05:27 PM
Default Re: Tundra won't start
Yes I did "pump" the throttle to no avail. Had my wife to rev-up the Nissan to increase the supply a bit - still just keeps turning and no start.
Old 03-21-2009, 05:37 PM
Puffnstuff's Avatar
2006 Toyota Tundra,
- Other -
Last Online: 11-19-2009 02:46 PM
Images: 19
Puffnstuff will become famous soon enough.
Puffnstuff's Photo Albums
I'd check the rest of the fuses to make sure that nothing else blew. At least you didn't get smoking like some other people have seen when they did that.
My DC has: Python 990 Alarm System, Eclipse AVN5500 Navigation System w/80gb ipod & eclipse speakers, Kenwood KAC-X20 Amp, Car Audio Factory Sub box w/Kicker CVT8 subs, UWS Black Deep Toolbox, Nasta SS Nerf Bars, Rugged Liner Bed Liner, AVS chrome bug shield, EGR in channel vent visors, Goodyear Fortera Tripletreds, Hellwig #7700 rear sway bar, Sears Diehard Platinum P1 Battery
Old 03-21-2009, 06:00 PM
duffyatkinson's Avatar
Dealer : Toyota of Riverside
2002 Toyota Tundra,
2003 Toyota 4Runner V6 Limited 4WD
Last Online: Today 07:07 PM
Images: 17
duffyatkinson has blessed us with their presence. duffyatkinson has blessed us with their presence. duffyatkinson has blessed us with their presence. duffyatkinson has blessed us with their presence.
Send a message via Yahoo to duffyatkinson duffyatkinson's Photo Albums
Check all the fuses... you might have blown the fuel pump/relay fuse...
2002 Tundra V8 SR5 2WD AC | Silver Sky Metallic | Chrome Step Bars | Kobalt Low Profile Bed Box
Daystar 2.5" Levelling Lift, 1" Rear Block
Mobil-1 5W-30 | Magnefine ATF Filter 3/8" | K&N AF #33-2144 | NGK Iridium Plugs #BKR6EIX
Russell Speed Bleeders #639560 | Josh's Billet Wing Window Latch Upgrade
11/1/2009: 48,050 miles
* * * I highly recommend http://www.auto-rx.com/ for your engine and transmission! * * *
* * * O2 Sensor Replacement DIY: http://www.tundrasolutions.com/forums/1197269-post2/ * * *
Old 03-21-2009, 06:21 PM
Thanks for all the replies, I checked every fuse and 15amp EFI Fuse was out and 15amp Dome (dome light I suppose) Fuse was out. I replaced the EFI fuse with the handy replacement attached to the Fuse Box Cover, but can't check to start it as my wife is out my her Nissan. Have to wait till she gets home. Argh...
Old 03-21-2009, 07:56 PM
Thanks to all those who posted, it was the EFI fuse. I tried to jump start again and started right up. Whew. Left it running to charge the battery a little.
Tags
fuse , ignition , start , starter
