Trouble Code P1126?
+ Reply to Thread
Results 1 to 10 of 10
Thread: Trouble Code P1126?
  1. #1
    Join Date
    Feb 2009
    Location
    Sonoma County
    Posts
    31
    Liked
    0 times
    Rep Power
    7
    Default Trouble Code P1126?
    My 2001 Tundra V8 has been throwing a Check Engine light on and off for a few days. Seems to run and drive normal. I hooked up a coworkers OBDII scan tool and came up with P1126=Manafacurer fuel and air measurement. But when looking up P1126 in the search function of this forum, I would see Magnetic motor or TPS? Would the P1126 from the scan tool be the same trouble code as Toyota? Runs great otherwise!
    2001 Toyota Tundra V8 accesscab 2wd
    2005 Toyota 4runner Sport V6 4wd
    1992 Ford Mustang 560rwhp
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Join Date
    Mar 2009
    Location
    Marlborough MA
    Posts
    24
    Liked
    0 times
    Rep Power
    7
    Default Re: Trouble Code P1126?
    From Alldata:
    Magnetic clutch is mounted between the throttle motor and the valve, and it connects the throttle motor with the throttle valve. Therefore the throttle motor opens and closes the throttle valve through the magnetic clutch.
    If the electric throttle control system has a malfunction, the magnetic clutch separates the throttle motor from the throttle valve so that the throttle motor cannot operate the throttle valve.
    If this DTC is stored, the ECM cuts the power for the throttle motor and the magnetic clutch, and the throttle valve is fully closed by the return spring. However, the opening angle of the throttle valve can be controlled by the accelerator pedal through the throttle cable.
    That doesn't help you much for the diagnosis, but it does tell you what is going haywire.
    The first thing I would do is measure the resistance between pins 3 and 4 of the magnetic clutch circuit. The resistance should be between 4.2 and 5.2 ohms. If it is either open or shorted, there is your problem.
  4. #3
    Join Date
    Feb 2009
    Location
    Sonoma County
    Posts
    31
    Liked
    0 times
    Rep Power
    7
    Thread Starter
    So when the malfunction occurs I would not feel anything wrong? I honestly do not notice any difference, feels normal. Later this afternoon the check engine light turned off, but still receive the code p1126. I cleared the code and will check tomorrow.
  5. #4
    Join Date
    Feb 2009
    Location
    Sonoma County
    Posts
    31
    Liked
    0 times
    Rep Power
    7
    Thread Starter
    Quote Originally Posted by mitsu matt View Post
    From Alldata:
    Thanks for explaining! Will measure tomorrow!
  6. #5
    Join Date
    Feb 2009
    Location
    Sonoma County
    Posts
    31
    Liked
    0 times
    Rep Power
    7
    Thread Starter
    Still no check engine light. Hooked up the scanner anyway just to check and there is no codes so far.
  7. #6
    Join Date
    Jan 2009
    Location
    USA
    Posts
    231
    Liked
    5 times
    Rep Power
    472
  8. #7
    Join Date
    Apr 2004
    Location
    jacksonville, fl
    Posts
    3
    Liked
    0 times
    Rep Power
    0
    Ditto me having intermittent code P1126, but truck not being placed into limp-home mode on my 2000 Tundra with 4.7L. Wondering if this is a sign the ECU is bad? Costly troubleshooting in this arena!
  9. #8
    Join Date
    Aug 2007
    Location
    DEERFIELD BEACH
    Posts
    4,036
    Liked
    94 times
    Rep Power
    3320
    hi, since i joined i have seen so many codes.
    is there a web site, a book, etc,
    where we all can get them, for our specific toy?
    just wondering.
    i surely know 1 thing, that everyone of us, that has a or has had a code,
    we thankyou all, for the knowledge of what that specific code is for.
    gorilla
  10. #9
    Join Date
    Dec 2012
    Location
    florida
    Posts
    1
    Liked
    0 times
    Rep Power
    0
    P1126 Code For Toyota Tundra Limited
  11. #10
    Join Date
    May 2010
    Location
    California
    Posts
    92
    Liked
    0 times
    Rep Power
    6
    I have code P1126 on a 2001 Sequoia Limited. The pins on the electrical connection measured 5.5 ohms - upper limit is supposed to be 5.2 ohms. There is a oscilloscope wave pattern that will diagnose it, but home mechanics usually don't have the equipment. Adding Techron gas additive extinguished the MIL light - I discovered this by chance. It still shows as "pending", but there are no performance issues. A smog tech said additional malfunctions in the throttle system could put the vehicle into "limp" mode - basically the car will not respond to the throttle in that mode - dangerous if in heavy traffic, etc. I also wondered if the ECU isn't self diagnosing properly. For the time being, I will drive it and see what happens next.
Quick Reply Quick Reply
Register Now
Your postal zip code.
Where you live.
Log-in
Human Verification
  1. 10-01-2011, 05:39 PM
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
