Oil Change Procedure
+ Reply to Thread
Page 1 of 2 12 LastLast
Results 1 to 15 of 26
Thread: Oil Change Procedure
  1. #1
    Supporter Togman's Avatar
    Join Date
    Mar 2009
    Location
    Va Bch
    Posts
    413
    Liked
    5 times
    Thanks
    0
    Images
    3
    Rep Power
    10
    Default Oil Change Procedure
    What is the best course of action when changing out the oil filter since it leaks all over the skid plate. Anyone got this down to a science yet?
    2003 Tundra SR5 4wd TRD Metallic Gray Paint
    Line X Bed Liner
    Hellwig Anti-Sway
    TC Poly Steering Rack Bushings
    Wheeler's Anti-Sway Kit
    K&N Drop in Filter
    Bilstein Shocks
    Hitch Scan Back Up Sensor
    Michelin LTX M/S2 Tires
    ARE Cab Hi Cap
    Firestone Ride Rite Air Springs
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Supporter UnSub's Avatar
    Join Date
    Mar 2007
    Location
    Mesquite, TX
    Age
    63
    Posts
    992
    Liked
    1 times
    Thanks
    0
    Images
    6
    Rep Power
    38
    Default Re: Oil Change Procedure
    Most people just remove the skid plate each time. Some that don't, use baggies to catch the filter and mess, while others cut an access hole in the skid plate.
    03 Stratosphere Mica Stepside, 4.7 L, Supercharger, TRD Package, TRD Exhaust,
    Scion Head Unit 08600-21802,
    Custom leather heated seats 2 tone with TRD LOGO, Moonroof, ARE LID, ZR3 Laser Shifter, Denso IK22 .4mm Iridium Plugs, Scan Gauge 2,
    Rhino Liner, Die Hard Platinum P5 battery
    5.7 Killer
  4. #3
    Join Date
    Jan 2007
    Location
    Prov, RI
    Posts
    213
    Liked
    5 times
    Thanks
    0
    Rep Power
    861
    Relocation of the oil filter with a remote kit is another option.
  5. #4
    Veteran Member 2000tundra2wd's Avatar
    Join Date
    Dec 2007
    Location
    New Orleans
    Age
    24
    Posts
    525
    Liked
    2 times
    Thanks
    0
    Images
    14
    Rep Power
    8
    this has been discussed plenty of times. use the search. but for now: usually i just remove the skid plate. i think its only 4 12mm hex bolts. i used to just let it get all over the skid plate until i found out, its pretty easy to remove.
    2000 Tundra 2wd 4.7L
    5% tint all around
    Viper 5901 2-way with Remote Start
    BILSTEIN 5100's all around with Front on second notch
    TRUE DUAL MAGNAFLOW exhaust with X pipe and turndown over rear axle
    Denso HID ballast.
    Philips 4,300k d2r HID bulb
    H4 to D2R Adapter
    20 inch Toyota TSS wheels with 265/50r20 Toyo Tires
  6. #5
    Hall of Fame Member Mr. Creosote's Avatar
    Join Date
    Apr 2006
    Location
    Posts
    32,593
    Liked
    1526 times
    Thanks
    0
    Rep Power
    268069
    I cut a hole on the driver's side of the skid plate. Now I can reach in and unscrew the filter without crawling under the truck or removing the skid plate.
  7. #6
    Junior Member apurazzo's Avatar
    Join Date
    Feb 2003
    Location
    New Port Richey, FL
    Age
    54
    Posts
    369
    Liked
    31 times
    Thanks
    0
    Images
    4
    Rep Power
    6026
    i remove the skid plate each time.
    you can get far in life with a nice word and a gun than with a nice word...... Friends help you move. Real friends help you move dead bodies.
  8. #7
    Veteran Member Marauder's Avatar
    Join Date
    Jan 2007
    Location
    Mission Viejo, CA
    Posts
    831
    Liked
    3 times
    Thanks
    0
    Images
    35
    Rep Power
    669
    I remove my skid plate. It only takes a couples minutes to remove, 5 bolts in total, 3 on the front and two in back.
    I have to change my oil this weekend too, the maintenance light is flashing again.
    2006 Tundra Access Cab V8 - TRD
    16x8 Konig Countersteer w/Nitto TerraGrapplers 285/75R16
    Bilstein 5100 front/rear, Wheelers 1.5" rear blocks
    Dynomax cat-back w/Cherry Bomb Pro muffler
    Pioneer headunit w/Alphasonic amp and Sochse speakers
    HID retrofit, Acura TL bi-xenon projectors w/BMW ZKW lenses
    Truxedo Truxport / Trail FX black steps bars / Line-X Xtra
  9. #8
    Join Date
    Feb 2008
    Location
    miami
    Posts
    202
    Liked
    0 times
    Thanks
    0
    Rep Power
    8
    if you don't do off road ,only city , you may want to take it out and and store it somewere in your garage.
  10. #9
    Join Date
    Sep 2007
    Location
    MA
    Posts
    808
    Liked
    110 times
    Thanks
    0
    Rep Power
    16225
    I think, much easier than taking out the skid plate, is from above, just take 3-4 of the plastic grocery bags and triple/quadruple them up and put them right around the oil filter so that when you both unscrew the oil filter and the oil drips/drains out, it goes in the bag, easy. 95,000 miles and 19 oil changes, never had my skid plate off once, easy.
  11. #10
    Veteran Member stevekx's Avatar
    Join Date
    Apr 2007
    Location
    home
    Posts
    609
    Liked
    0 times
    Thanks
    0
    Rep Power
    13
    Bags never worked for me, also tried a cut up 2 ltr coke bottle but it was hard to work with. Now I just have a small and low square plastic container I slide under the filter, then just take the filter out. The oil drips into the plastic container.
    bug deflector/side fender turn signal/went shades/back rack/tool box/rear strip light/nerf bars/top light bar/front alternating flashers/rear strobes in turn & stop lights/bedmatt & linert/all badges removed/Helwig sway bar
  12. #11
    Supercharged Member HOGWILD's Avatar
    Join Date
    May 2006
    Location
    Albuquerque
    Posts
    3,510
    Liked
    7 times
    Thanks
    0
    Images
    12
    Rep Power
    577
    Remove the skid plate This is not new they have them as far back as my 93 pick up and i take it off every oil change!
  13. #12
    Veteran Member benbeaux's Avatar
    Join Date
    Feb 2006
    Location
    Plano, TX
    Posts
    634
    Liked
    0 times
    Thanks
    0
    Images
    2
    Rep Power
    10
    Quote Originally Posted by Togman View Post
  14. #13
    Join Date
    Mar 2009
    Location
    Va Bch
    Posts
    413
    Liked
    5 times
    Thanks
    0
    Images
    3
    Rep Power
    10
    Thread Starter
    Quote Originally Posted by benbeaux View Post
    Now this is what I am tallking about, getting it down to a Science! Great photos!!
    Line X Bed Liner
    Hellwig Anti-Sway
    K&N Drop in Filter
    Bilstein Shocks
    ARE Cab Hi Cap
  15. #14
    Veteran Member hofkamp83's Avatar
    Join Date
    Sep 2007
    Location
    Fort Smith, AR
    Age
    31
    Posts
    567
    Liked
    9 times
    Thanks
    0
    Images
    102
    Rep Power
    310
    could just take it to the dealership or somewhere else
    costs me about 28 bucks for me to get it done at the dealership while about 40 at jiffy lube.
    i'm lazy though
    Andrew
    2012 Ford Raptor - 2008 Ford F250 - 1984 Toyota Pickup - 2008 Yamaha Raider .................................................. ................. Sold - 2005 Toyota Tundra AC LimitedNitto Terra Grapplers LT325/60/20 on 20" Rev Commando's, Bilstien 5100's on Top Notch, 3/8" Spacer, 3" Body Lift, Camburg UCA's, 1.5" Rear Blocks, Rough Country Rear Shocks, RevTek Diff Drop, Total Chaos Steering Rack Bushings, Downey HD End Links, CV Boot Mod, Unichip PnP, K&N CAI, Headers, Y-Pipe, Borla Split Side Exit Exhaust, Removed Resonator, Summit Nerf Bars, Bullett Bull Bar, KC Highlights Long Range Slim Lights, 1.25" Spidertraxx Adapters, Blacked Fender Flares, Mouldings and Badges, Herculiner Roll On Bed LinerFull LED Conversion with HIDS, Panasonic CQ-VW100U, Panasonic CA-PANSC1U, Sirius SC-C1, Infinity 6022i, Infinity 6020CU, Q-Logic QL-C1TTX208, Kicker ZX400.1, Rockford Fosgate P2D28 x2, Cobra 9540, Scanguage 2
  16. #15
    Supporter Tundraman10's Avatar
    Join Date
    Sep 2007
    Location
    East Liverpool, Ohio
    Age
    28
    Posts
    1,077
    Liked
    0 times
    Thanks
    0
    Images
    5
    Rep Power
    15
    Genius: I should have thought about that before.
    2000 Toyota Tundra SR5 Access Cab 4x4 Black
    Cardomain Member
    Sold the Tundra for $5,000 without the wheels 12/10/2011
Quick Reply Quick Reply
Register Now
Log-in
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
