Shitfter / transmission issue
Truck: 2002 Tundra V8 116k miles Automatic transmission
Problem: Very difficult to shift from Park to Reverse, Reverse to Drive, Drive to Park, etc.
Transmission fluid level correct and condition good. Visual inspection of transmission found no leaks, everything dry as a bone. Shift cable on side of transmission (driver's side) clean and free of anything abnormal. No check engine light.
This problem came out of nowhere. I was driving on a slight downhill, around 25mph. Heard and felt a bang/shudder, which seemed to kick the brake pedal back at me. After that it was normal. Didnt run anything over, it was broad daylight. So shortly after the bang/shudder, I pulled into park and noticed, for the first time ever (I put all 116K miles on it) that it was difficult to put in Park, and same thing for going from Park to Drive or Reverse. Took it straight home and when I parked the next time the problem was worse. Havent started it since. My Haynes Manual doesnt really address the issue.
Any help is appreciated.
Best regards,
Wes
