  #31 (permalink)
Old 10-06-2009, 03:43 PM
duffyatkinson's Avatar
Dealer : Toyota of Riverside
2002 Toyota Tundra,
2003 Toyota 4Runner V6 Limited 4WD
Last Online: Today 07:06 PM
Images: 17
duffyatkinson has blessed us with their presence. duffyatkinson has blessed us with their presence. duffyatkinson has blessed us with their presence. duffyatkinson has blessed us with their presence.
Send a message via Yahoo to duffyatkinson duffyatkinson's Photo Albums
Default Re: Change To Synthetic Motor Oil Or Not
Originally Posted by GORILLA View Post
hi quick info. if you bought a used tundra, and you can get the info as to what oil was used. use that.
if your vehicle used reg. oil for 30,000 miles continue to use reg. oil. if it used syn. oil continue to use that.
never go back & forth.
or change after alot of miles.
i got this info from several different performence shop's.
how good is this info, i'm not to sure. but i only use reg. oil, but i change it every 2000 to 2500miles.
oil gets dirty from the dirt in the air passing through & into the engine.
so the cleaner the oil the less dirt in your oil.
so continue to use what ever they used before.
unless it's brand new. than use what you want, but do not change.
gorilla
Hey Gorilla~
I think I'm gonna have to disagree with your conclusion here. Other than the potential for a light seepage by switching away from dino to syn (if the leak was already there, btw...), then there is nothing wrong with using synthetic, switching back and forth, mixing dino and synthetic (at the same v-rating of course...), etc. As long as the engine has sufficient volume of proper viscosity lubrication, all is fine.
Duff
2002 Tundra V8 SR5 AC | Silver Sky Metallic | Chrome Step Bars | Kobalt Low Profile Bed Box
Daystar 2.5" Levelling Lift, 1" Rear Block
Mobil-1 5W-30 Truck & SUV | Magnefine ATF Filter 3/8" | K&N AF #33-2144 | NGK Iridium Plugs #BKR6EIX
Russell Speed Bleeders #639560 | Josh's Billet Wing Window Latch Upgrade
11/1/2009: 48,050 miles
* * * I highly recommend http://www.auto-rx.com/ for your engine and transmission! * * *
  #32 (permalink)
Old 10-06-2009, 05:25 PM
Dealer : Al Hendrickson Toyota
2005 Toyota Tundra
Last Online: 11-17-2009 03:30 PM
GORILLA is a splendid one to behold. GORILLA is a splendid one to behold.
GORILLA's Photo Albums
everyone has there own opinion.
i'll stick with the way i do my oil changes.
i'll stick with the pro's opinion's every time.
gorilla
  #33 (permalink)
Old 10-06-2009, 05:47 PM
Dealer : Butler Toyota Co.
2004 Toyota Tundra
Last Online: 10-29-2009 10:16 AM
bill3508 will become famous soon enough.
bill3508's Photo Albums
gorilla
Please state the name of said "pro's" so the people here know who not to take their vehicles to for service. That old tale of not switching to synthetic oil/using the same oil has been around for ages and it started when synthetic came out. It holds no merit, other than watching for leaks with Syn. No real pro told you that either.
04 TRD AC 4X4,JBA headers,True Flow intake w/K&N drop-in, Spintech Sportsman Street XL muffler, NGK TR6ix plugs, new Denso 234-4209 o2 sensors,Mobil 1 Syn 0W-40
  #34 (permalink)
Old 10-06-2009, 05:58 PM
Greenie's Avatar
Dealer : Hoover Toyota Scion
Last Online: Yesterday 06:52 PM
Greenie has done just about everything. Greenie has done just about everything. Greenie has done just about everything. Greenie has done just about everything. Greenie has done just about everything. Greenie has done just about everything. Greenie has done just about everything. Greenie has done just about everything. Greenie has done just about everything. Greenie has done just about everything. Greenie has done just about everything.
Greenie's Photo Albums
Some folks won't walk under a ladder and will go the opposite direction when confronted by a black cat too!
More's Law: If more's good then too much is just right.
CBTMA member
  #35 (permalink)
Old 10-06-2009, 06:19 PM
2004 Toyota Tundra
Your sig holds the truth.
  #36 (permalink)
Old 10-06-2009, 11:02 PM
hybridtoys's Avatar
2005 Toyota Tundra,
1993 Toyota 4Runner my ladys toy
Last Online: 11-18-2009 01:06 AM
Images: 11
hybridtoys is on a distinguished road.
hybridtoys's Photo Albums
Well either way you go pick one and stick with it,its hard on motors to switch around, think of oil as tiny little balls to fill the gaps between the "race" -the out side of the bearing- and the actual "bearing". But be aware full synthetic is notorious for causing leaks.....
Well not really "causing" but being so slippery it sneaks threw the cracks...
Personally im not a fan in engines,to many spots to leak, and to spendy for a daily driver. Just trannys and diffs for me....
  #37 (permalink)
Old 10-07-2009, 11:51 AM
BobbyB's Avatar
Last Online: 11-05-2009 04:39 PM
Images: 35
BobbyB is on a distinguished road.
BobbyB's Photo Albums
I've used Royal Purple in my truck and my truck seems to like it better than anything else.
  #38 (permalink)
Old 10-07-2009, 11:04 PM
Puffnstuff's Avatar
2006 Toyota Tundra,
- Other -
Last Online: 11-19-2009 02:46 PM
Images: 19
Puffnstuff will become famous soon enough.
Puffnstuff's Photo Albums
Well all sae rated oils should have the proper additives to condition the seals so you should be able to swap if you so desire.
My DC has: Python 990 Alarm System, Eclipse AVN5500 Navigation System w/80gb ipod & eclipse speakers, Kenwood KAC-X20 Amp, Car Audio Factory Sub box w/Kicker CVT8 subs, UWS Black Deep Toolbox, Nasta SS Nerf Bars, Rugged Liner Bed Liner, AVS chrome bug shield, EGR in channel vent visors, Goodyear Fortera Tripletreds, Hellwig #7700 rear sway bar, Sears Diehard Platinum P1 Battery
