Old 05-06-2009, 10:06 AM
schromik's Avatar
Last Online: 11-07-2009 12:32 PM
schromik is on a distinguished road.
schromik's Photo Albums
Default Check Engine Light and High Oil Pressure
Hello, I have a 2003 Tundra with 49k Miles.
The check engine light comes on now, and the oil pressure goes almost all the way to the 3/4 line when I turn the truck on. After driving it down the street, it comes down to slightly below half. I don't remember this previously happening. If I accelerate fast, it will go back up to near the 3/4 line.
I have heard to tighten the gas cap, and I have tried that method. Does anyone have any idea what could be wrong? Thanks in advance!
Old 05-06-2009, 11:18 AM
duffyatkinson's Avatar
Dealer : Toyota of Riverside
2002 Toyota Tundra,
2003 Toyota 4Runner V6 Limited 4WD
Last Online: Today 03:41 PM
Images: 17
duffyatkinson has much to be proud of. duffyatkinson has much to be proud of. duffyatkinson has much to be proud of. duffyatkinson has much to be proud of.
Send a message via Yahoo to duffyatkinson duffyatkinson's Photo Albums
Default Re: Check Engine Light and High Oil Pressure
The CEL and the oil pressure have nothing to do with each other. Your oil pressure is operating exactly like it's supposed to. Even the owner's manual (you have one, don't you?) shows the operating range as indicated by the oil pressure gauge, i.e. ~1/4 @ idle to ~3/4 under throttle.
2002 Tundra V8 SR5 2WD AC | Silver Sky Metallic | Chrome Step Bars | Kobalt Low Profile Bed Box
Daystar 2.5" Levelling Lift, 1" Rear Block
Mobil-1 5W-30 | Magnefine ATF Filter 3/8" | K&N AF #33-2144 | NGK Iridium Plugs #BKR6EIX
Russell Speed Bleeders #639560 | Josh's Billet Wing Window Latch Upgrade
11/1/2009: 48,050 miles
* * * I highly recommend http://www.auto-rx.com/ for your engine and transmission! * * *
* * * O2 Sensor Replacement DIY: http://www.tundrasolutions.com/forums/1197269-post2/ * * *
Old 05-06-2009, 11:28 AM
Dealer : Al Hendrickson Toyota
2005 Toyota Tundra
Last Online: Today 04:01 PM
GORILLA is a splendid one to behold. GORILLA is a splendid one to behold.
GORILLA's Photo Albums
hi, go to autozone, or similar and have them put on a scanner to test what code it is throughing. might be the o2senor. many of these have gone. now if thats it there are 2 type's. i forget which 1 is better or cheaper. there is a certain autoparts store people have mentioned, because it is alot cheaper there.
good luck,
as far as oil pressure it's just fine, & like it was already said it's normal, for a stock tundra. mine has changed. no more does it go to the 3/4 line. only a little past 1/2.
gorilla
Old 05-06-2009, 11:52 AM
Last Online: 05-30-2009 01:19 PM
roundwheels is on a distinguished road.
roundwheels's Photo Albums
Yep, the two are unrelated....
The check engine light throws an error related to the EVAP and emissions systems.
Belief me I know!~ LOL...
Old 05-06-2009, 09:12 PM
HOGWILD's Avatar
Dealer : American Toyota
2006 Toyota Tundra,
1993 Toyota Truck,
2007 Scion tC
Last Online: Yesterday 02:50 PM
Images: 12
HOGWILD is a splendid one to behold. HOGWILD is a splendid one to behold.
HOGWILD's Photo Albums
x2 oil pressure is not your issue, your issue is with the filler neck on the fuel filler tube! It was a TSB if it set your CEL on during warranty period if not it's on you and shall36 wrote a nice tutorial on R&R of the assy so give him a shout out! Some folks have changed to a new cap to fix issue and it's cheaper to do that but highly possible it's going to come back unless you do the filler tube replacement! Good Luck! Defect is where the cap seal hits the throat and it just will not seal since it is deformed!
File Type: pdf Fuel%20Fill%20Tube%20Replacement[1].pdf (702.7 KB, 26 views)
Old 05-06-2009, 09:27 PM
2005 Toyota Tundra DC Limited 4x4
Last Online: 08-12-2009 10:01 PM
mitsu matt is on a distinguished road.
mitsu matt's Photo Albums
That is really bad information to be giving if you do not even know what the code is.
Please post what the code is (most any Autozone can get it for you) and that will help narrow down the possibilities.
Matt Burns
05 Tundra Double Cab Limited 4x4 TRD with Nav
04 Mitsubishi Lancer Evolution RS - 11.1@132
Old 05-06-2009, 10:08 PM
2000tundra2wd's Avatar
Dealer : Ray Brandt Toyota of Metairie
Last Online: 11-07-2009 02:23 AM
Images: 14
2000tundra2wd will become famous soon enough.
2000tundra2wd's Photo Albums My eBay
theres a possibility that your oil pressure may not be right....
click this link and it should give you a answer to your possible problem
Engine Oil Bypass Kit - $49.95 : KaleCoAuto, Hard to find automotive items!
2000 Tundra 2wd 4.7L
5% tint all around
Magnaflow part 14326
14 inch Single In/Out Open Muffler
Denso HID ballast.
Philips 4,300k d2r HID bulb
H4 to D2R Adapter
20 inch Toyota TSS wheels with 265/50r20 Toyo Tires
Old 05-06-2009, 10:43 PM
bamafire's Avatar
Dealer : Hoover Toyota Scion
2002 Toyota Tundra,
- Other - 66 chevelle zz430
Last Online: Today 03:50 PM
Images: 8
bamafire is on a distinguished road.
bamafire's Photo Albums
Like everyone else has said, get the code first. The two may or may not be related. If they are, the first thing I would suspect would be a faulty oil pressure sending unit/sensor.
Your actions speak so loudly, I can't hear what you're saying.
Old 05-06-2009, 11:53 PM
HOGWILD's Avatar
2006 Toyota Tundra,
1993 Toyota Truck,
2007 Scion tC
Images: 12
Sorry you find my idea to be bad info, since he did not post a code and mentioned his fuel cap, he gave me the impression he thought it was his filler tube/cap. He does need his code pulled and then maybe you can fix his issue! I find it hard to imagine oil pressure that is reading normally could cause this issue but i have been wrong before!
Old 05-10-2009, 12:46 PM
HOGWILD's Avatar
2006 Toyota Tundra,
1993 Toyota Truck,
2007 Scion tC
Images: 12
UPDATES? more info? SO i guess you have read your owners manual ? what code was your truck throwing BTW?
Old 05-10-2009, 09:10 PM
Highwaylizard's Avatar
Dealer : Butler Toyota Scion
2004 Toyota Tundra Limited DC 4.7 4spd
Last Online: 11-17-2009 06:13 PM
Images: 64
Highwaylizard is a name known to all. Highwaylizard is a name known to all. Highwaylizard is a name known to all. Highwaylizard is a name known to all. Highwaylizard is a name known to all. Highwaylizard is a name known to all. Highwaylizard is a name known to all.
Highwaylizard's Photo Albums
I have to say that your oil pressure is exactly where it should be. Mine is exactly the same - 3/4 under throttle, 1/2 at cruise, and 1/4 at idle.
I'll eat my tail if your CEL is related to anything having to do with your oil pressure.
Highwaylizard 2004 Tundra Double Cab Limited Edition 4.7 liter V8, four speed automatic, four wheel drive, testing platform for fuel economy, self designed cold air intake using ram air principle, Fitch Fuel Catalyst, Aero Turbine, "Foolie Exhaust" from Aero Turbine back, True Flow Intake with True Flow foam filter, Mobile 1 in the engine, K&N oil filter, Royal Purple in the differentials. 3:91 gears in the front (Thanks Cajuntundra!) and rear (Thanks Nytrousboy!) differentials, Toyo H/T Open Country tires.
testis amotio per pera
150,620miles on the odometer Tundra Fuel Economy Blog
19+ MPG on the Highway at 75 MPH in a DC with a four speed automatic and a bad O2 sensor - not too shabby!
Old 05-10-2009, 10:25 PM
yspert's Avatar
Dealer : Rice Toyota
Last Online: 10-30-2009 10:49 PM
yspert is on a distinguished road.
yspert's Photo Albums
Exclamation Re: Check Engine Light and High Oil Pressure
oil pressure sounds normal.
all other bets are off until you post a code.
could be because you put atf in the diff.
or seafoam in the engine. yspert
Graduated from Y to Z status.
Old 07-16-2009, 06:11 PM
schromik's Avatar
I went to AutoZone, and they ran the free diagnostic. What it seems to be is the Oxygen Sensor. Here is what the printout looks like:
OEM Number to Cross: P0051
OEM Brand: Toyota
Definition
BBOxygen sensor heater control circuit low- bank 2
BBsensor 1
Probable Cause
BB1.- Open or short circuit condition
BB2.- Poor electrical connection
BB3.- Failed oxygen sensor
BB4.- EFI relay fault
Anyone know if this points to a specific Oxygen sensor? Thanks!
Old 07-16-2009, 06:38 PM
kerryman71's Avatar
Dealer : Harr Toyota
2002 Toyota Tundra SR5 AC V8 4X4 TRD
Last Online: Yesterday 11:09 PM
Images: 27
kerryman71 has done just about everything. kerryman71 has done just about everything. kerryman71 has done just about everything. kerryman71 has done just about everything. kerryman71 has done just about everything. kerryman71 has done just about everything. kerryman71 has done just about everything. kerryman71 has done just about everything. kerryman71 has done just about everything. kerryman71 has done just about everything. kerryman71 has done just about everything.
kerryman71's Photo Albums My eBay
Bank 2 Sensor 1 should be the pre-converter sensor on the
passenger side. I don't remember the Denso part #, but
you should be able to find it somewhere. I bought mine from
amazon.com pretty cheap. You'll also need an O2 sensor
tool to remove it. Basically it's a extra deep socket with a side
cutout. The sensor is threaded into the pipe.
Also, your oil pressure seems fine to me. Good luck.
John
The fools, the fools the fools! They have left us
our Fenian dead, and while Ireland holds these
graves, Ireland unfree shall never be at peace!
Padraig Mac Piarais (Patrick Pearse)
Old 07-16-2009, 06:39 PM
dyogim's Avatar
SAS'ed #5
2000 Toyota Tundra,
1998 Toyota Camry
Images: 88
dyogim's Photo Albums
It's the pass. side mounted to the exhaust manifold right before the connector.
This should help.
http://www.tundrasolutions.com/forum...on-comp-1-.pdf
Mike
http://dyogim.blogspot.com
