I have new brake pads on my 03 Tundra. When I first touch the brake pedal, it goes nearly to the floor and doesn't slow down very well, then the 2nd and future pumps the pedal is normal height and it stops fine. What do you guys think the trouble could be.
Thanks,
Paul
It's normal because when you just installed new pads, your piston is pushed all the way back. You gotta give it a few pumps for it to be back to normal. Adjusting the rear brake shoes also made a big difference after changing the front pads for me.
Just what exactly is the procedure to adjust the rear shoes so as to have them properly adjusted and even from passenger side to driver side? I am still dealing with braking issues after a week of gnashing teeth and mandatory double and triple pumping to get the brakes to work. There is also a maddening "popping" or "tapping" noise from the rear while braking which we think is an out of round drum.
Highwaylizard 2004 Tundra Double Cab Limited Edition 4.7 liter V8, four speed automatic, four wheel drive, testing platform for fuel economy, self designed cold air intake using ram air principle, Fitch Fuel Catalyst, Aero Turbine, "Foolie Exhaust" from Aero Turbine back, True Flow Intake with True Flow foam filter, Mobile 1 in the engine, K&N oil filter, Royal Purple in the differentials. 3:91 gears in the front (Thanks Cajuntundra!) and rear (Thanks Nytrousboy!) differentials, Toyo H/T Open Country tires. testis amotio per pera
(pbukowski) My first question to you is...did you buy OEM or aftermarket pads? I've seen aftermarket pads who's lining is a little lower than OEM giving you a soft pedal. If they are OEM, did you have the drums turned? I've also seen some drums that develope a ridge on the inside so that the new linings don't meet flush with the drum also giving you a soft pedal. (Highwaylizard) the popping noise's you hear have a 50/50 chance of going away for an out of round drum by having them turned. If they are too outta round, then new drums should solve your problem.
I bought aftermarket pads (Raybestos). I'm thinking maybe the brake lines just need to be bled. Actually, I'm thinking of bringing it in to the dealer and ask them to replace the brake fluid, as it's never been done. It's almost time for the timing belt, so might as well have them fix it all.
