my '04 has a bit of clicking coming from the left (driver's side) part of the engine. it sounds like my old chev when a valve was shot.
1. How do I diagnose?
2. Where can you buy aftermarket engine parts?
3. If it is a valve issue, could I have potential piston/cylinder damage.
Unfortunately I've been running with this "Clicking" for a while now, so I'm a little concerned it there's some potential problems with that cylinder.
Thanks.
Are you sure the clicking you hear isn't a sticking fuel injector? Try some chevron techron or b12 chemtool in your next tank of gas and see if it stops. If it doesn't then go from there.
My DC has: Python 990 Alarm System, Eclipse AVN5500 Navigation System w/80gb ipod & eclipse speakers, Kenwood KAC-X20 Amp, Car Audio Factory Sub box w/Kicker CVT8 subs, UWS Black Deep Toolbox, Nasta SS Nerf Bars, Rugged Liner Bed Liner, AVS chrome bug shield, EGR in channel vent visors, Goodyear Fortera Tripletreds, Hellwig #7700 rear sway bar, Sears Diehard Platinum P1 Battery
Probably the manifold. Look at the EVAP canister as well (black box with rubber hoses running into). I had a hose come off of the EVAP once, and the truck sounded like a 74 Coupe de Ville.
Your actions speak so loudly, I can't hear what you're saying.
alot of us have the clicking issue. mine happens under partial accel after i am at cruising speed. VERY annoying. isnt the manifold though. i put headers on and that should have fixed it.
if you find out PLEASE let me know
2005 Silver Sky Texas Edition DC SR5 w/moonroof, 20" rims, Magnaflow Catback, Doug Thorley Headers, Tuned Unichip, Downey FSB Endlinks w/ES Bushings, Downey HD Off Road Skid Plate, Hellwig RSB, Total Chaos Steering Rack Bushings, TRD Springs, Bilstein 5100 x 4, ASP Underdrive Pulley, Bazooka VSE, Panasonic CQ-C8803U w/bluetooth/Sirius, Polk 6750, Polk 675, 6000K H/L HID, 6000K HID Fog Lights, Sanded Out Gauge Cluster, LED Cool White Bulbs up top and blue down low, All LED Exterior Bulbs, TRD Mesh Grille Insert, Scangauge II.
2005 Lunar Mist Camry LE, Custom Leather, TRD Strut Bar, TRD Rear Sway Bar, SS Ultra Beams, K&N AF,
JVC KW-AVX720 w/Sirius, Polk 690
my 03 has some valve noise at start up, is not bad when warmed up. it has 122k miles,my 04 has some valve noise all the time. it has 58k. Im not worried, syntetic oil helps a lot.
Also look at where the steering shaft comes through the firewall. It has boot that will rip and let in a lot of engine noise. The best way to see it is from underneath the truck. Search this site and you can find a lot of info on this. This is a known problem.
Here is a picture- 05 Tundra Steering Wheel boot Ripped
half a can of seafoam 100 miles before the next oil change might help.
03 black tundra AC, rare stepside, 4wd, trd limited slip, perfect truck for me, 60Kmi, 17mpg@65mph.
02 civic cpe, blue, 36mpg@75mph, 45Kmi.
my ave combined economy is right at 30mpg using the truck only Sat/Sun, so i feel greener than uncle sam (27cafe?).
3 forced induction jetski's for weekend play so i guess i'm not so green after all. dav_dman@yahoo.com
