HELP with EFI / Engine problem
+ Reply to Thread
Results 1 to 6 of 6
Thread: HELP with EFI / Engine problem
  1. #1
    TS
    Join Date
    Jun 2002
    Location
    MALA
    Age
    33
    Posts
    579
    Liked
    1 times
    Images
    2
    Rep Power
    14
    Default HELP with EFI / Engine problem
    Hey guys, I have a real doozy on my hands...
    Started when I was winching the truck off an incline. The battery died down and engine killed, which is somewhat typical when winching.
    I tried to jump the car off with no luck and towed it home. I found my EFI-1 and EFI-2 fuses blown, check engine light on, ABS light on, VSC light on.
    I replaced the two EFI fuses and reset the P-0446, p0455, p0455 lights figuring the truck starved for fuel and cut out due to the angle. (yes I checked the gas cap!).
    After charging the battery all night, I started the car up, it rode fine. Started it up a second time, killed out and blew EFI-1 (replaced), started it up again and blew EFI-2 only. Now sometimes it blows 1, sometimes it blows 2. Sometimes it starts sometimes not. Fuel guage sometimes shows 100% sometimes 0%.
    The only other similar problem I have had is that it bogged down a couple times making a right turn, as if VSC had to take over and killed the acceleration- not a fast right turn either. Once before I had the same codes pop up, I tightened the cap and cleared them and never saw them again.
    Also, it may be worth noting that I need new brake rotors and pads, but didn't have the time to replace them yet.
    I looked under the car to see if anything looked strange, but the only thing odd was one wire was crispy as if once the insulation melted. I chased it down in the dark and it rides the passenger side, has a loom it is wrapped in, then looks like it crosses within the chassis to the fuel tank.
    Any guess will help. thanks guys. BTW, the problem is on a 2004 Sequioa, but I figured the truck is the same chassis, pump, wiring ect. I will post it on the Seq. forum too but know there is less traffic. Will merge them and delete this one later.
    Tundras: 02 AC - Gone, 07 DC - Gone, 04 DC - Gone
    FJ BRUISA! - Got
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Supporter Remmy700P's Avatar
    Join Date
    Jan 2008
    Location
    Inland Empire, CA
    Age
    49
    Posts
    8,393
    Liked
    3189 times
    Images
    47
    Rep Power
    162921
    Default Re: HELP with EFI / Engine problem
    It sounds like you had a power surge/imbalance, i.e. you had electrical power demands placed on the system by the winch above what the stock wiring could handle, and either it fried one or more leads, or you had an issue when you tried to jump it, and you had shorting. These are a bugger to fix sometimes because the wiring and fusing is so extensive. I'd bet that you're going to need an experienced automotive electrician to find the extent of the damage
    2002 Tundra V8 SR5 2WD AC
    1C7-Thunder Gray Metallic | Bilstein 5100s | Wheeler's Progressive 3-leaf AAL w/ OL Leaf
    LT265/75R16D1 Nitto Terra Grapplers | Wheeler's Poly Sway Bar Bushing/Bump Stop Set
    eBay T304 SS Headers | Percy's #66080 Header Gaskets | Remflex #8015 Collector Gaskets
    13WL Caliper Upgrade | Hawk Quiet Slot Rotors | Hawk LTS Brake Pads
    Mobil 1 Syn 5W-30 | Mobil 1 Syn ATF | Mobil 1 Syn 75W-90 Gear Oil | Magnefine ATF Filter 3/8"
    Denso #K20R-U Plugs | Russell Speed Bleeders #639570 (7mm)
    Ham Radio: KJ6OPA | CB Radio/Handle: Midland 75-822/"Marksman"
    * * * O2 Sensor Replacement DIY * * *
    "I came into this world covered in someone else's blood and screaming...I'm not afraid to leave it in the same way."
  4. #3
    TS
    Join Date
    Jun 2002
    Location
    MALA
    Age
    33
    Posts
    579
    Liked
    1 times
    Images
    2
    Rep Power
    14
    Thread Starter
    Thanks Duffy, I dont understand how the wiring connectected to the battery directly would melt a wire that is on the other side of the circuit and protected by a fuse. I wonder where I find an automotive electrician
    FJ BRUISA! - Got
  5. #4
    Supporter nytrousboy's Avatar
    Join Date
    Jul 2006
    Location
    Tucson, AZ
    Age
    45
    Posts
    270
    Liked
    5 times
    Images
    46
    Rep Power
    78
    maybe I can explain the p0446 and p0455, evap emissions can be anything from a loose gas cap, vacuum line or crack in a line or case to a sensor or circuit, in this case to me anyway, you said your efi 1 and 2 fuse blew, and your gas gauge did not work then did so on and so on.
    evap monitors run on start up, (under 80 deg fahrenheit) so if your gas guage did not work on 2 or more start ups you could get the evap codes.
    however you said you have (burnt wires maybe) the code p0446 Evaporative Emission System Vent Control Circuit is just that A CIRCUIT, and as duffy said if you have wiring problems which I agree with duffy on it could cause this code.
    the vent control is most likely stuck closed which would cause the other code p0455 Evaporative Emission System Leak Detected (gross leak/no flow)
    in this case no flow because the conrtol circuit is not getting power and stuck closed.
    dont worry about those codes for now, check the wiring first, sounds like you overheated something when winching
    2004 Tundra stepside.
    6" RCD lift, Camburg UCA, 4:56 front & rear, arb air locker, arb Sahara bar with 12000 bulldog winch, custom exhaust, 315/75r/16 km2 mt's
    stubbs sliders, ARE shell, ORS Hub kit.:rockon:
  6. #5
    Hall of Fame Member Mr. Creosote's Avatar
    Join Date
    Apr 2006
    Location
    Posts
    32,593
    Liked
    1527 times
    Rep Power
    269355
    Quote Originally Posted by Dixie4x4 View Post
    There may have been surges at some point. A given electronic component may use transient suppressors to prevent the surges from causing damage to the circuitry further inside that component. Depending on the design, some suppressors sacrifice themselves to absorb the surge so that the remaining circuit is protected. When suppressors get "struck by lightning" they can become leaky or even present a dead short, which would explain the fuse blowing symptoms you mention.
  7. #6
    Supporter Crazy Ivan's Avatar
    Join Date
    May 2007
    Location
    Landrum SC
    Age
    37
    Posts
    2,829
    Liked
    96 times
    Images
    64
    Rep Power
    54226
    Most of the times if EFI fuses blow, check your CO2 sensors Bank1 sensor 1, or Bank2 sensor1 (they are directly connected to EFI system) If they have short (meaning sensor wires on sensor it self), then fuse will blow.
    2006 Toyota Tundra DC SR5 4x4 - TRD supercharged, TRD BBK, TRD exhaust, 7009 navi w/custom JBL wire harness + OEM XM/Sirus radio, and many other mods.
Quick Reply Quick Reply
Register Now
Your postal zip code.
Where you live.
Log-in
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
