Old 05-28-2009, 06:45 PM
bezwickk's Avatar
2006 Toyota Tundra Reg Cab 4.0L V6
Last Online: Yesterday 06:59 PM
bezwickk is on a distinguished road.
Send a message via AIM to bezwickk bezwickk's Photo Albums
Default loud clunk from front end..
i have an 06 reg cab tundra 2wd and whenever i pull out of my driveway i hear a clunk noise from my front end, and when i go over speedbumps i hear a clunk from my rear end as if the tailgate is loose. i checked other threads and they mentioned the transmission crossmember and the sway bar. well i checked those and nothing is missing and i re torqued some of the bolts and made sure everything was fine. i didnt check the sway bar though. i took it for a test drive and it made the noise again pulling into my driveway.
as for the rear end i went over a speed bump and it made the noise too.
it is becoming more common now.. it never used to do it as much. idkk what it could be.
should i still be driving it?
Stock 06' Tundra Reg Cab V6 4.0L
Old 05-28-2009, 06:47 PM
Dealer : Toyota of Killeen
2004 Toyota Tundra,
1999 Toyota Land Cruiser,
2008 Toyota Camry-Solara SLE Convertible
Last Online: Today 10:26 AM
labountyphoto is on a distinguished road.
labountyphoto's Photo Albums
Default Re: loud clunk from front end..
look at your shocks
Old 05-28-2009, 06:49 PM
bezwickk's Avatar
i have but i dont know alot about suspension so idk what to look for. i only know most about the engine than anything else on the car.
Old 05-28-2009, 07:01 PM
duffyatkinson's Avatar
Dealer : Toyota of Riverside
2002 Toyota Tundra,
2003 Toyota 4Runner V6 Limited 4WD
Last Online: Today 09:52 AM
Images: 17
duffyatkinson has blessed us with their presence. duffyatkinson has blessed us with their presence. duffyatkinson has blessed us with their presence. duffyatkinson has blessed us with their presence.
Send a message via Yahoo to duffyatkinson duffyatkinson's Photo Albums
The rear end noise is probably either the leaf spring bushings or one or both of the rear upper shock mounts.
2002 Tundra V8 SR5 2WD AC | Silver Sky Metallic | Chrome Step Bars | Kobalt Low Profile Bed Box
Daystar 2.5" Levelling Lift, 1" Rear Block
Mobil-1 5W-30 | Magnefine ATF Filter 3/8" | K&N AF #33-2144 | NGK Iridium Plugs #BKR6EIX
Russell Speed Bleeders #639560 | Josh's Billet Wing Window Latch Upgrade
11/1/2009: 48,050 miles
* * * I highly recommend http://www.auto-rx.com/ for your engine and transmission! * * *
* * * O2 Sensor Replacement DIY: http://www.tundrasolutions.com/forums/1197269-post2/ * * *
Old 05-28-2009, 11:01 PM
bezwickk's Avatar
hmmm and how would i go about fixing something like that? is it something i can do myself or something the dealer would have to look at.. unfortunately the warranty ended
its passed 37,000 miles and it has almost 3 years
Old 05-28-2009, 11:14 PM
2005 Toyota Tundra DC 4x2
Last Online: Today 05:49 AM
hash browns is on a distinguished road.
hash browns's Photo Albums
check your front upper shock mounts too
Old 05-28-2009, 11:28 PM
bezwickk's Avatar
i dont wanna sound retarded but i dont even know what the **** that is. like i said i only know about the engine.
Old 05-28-2009, 11:58 PM
2002toytundra's Avatar
Dealer : Jim Norton Toyota
2002 Toyota Tundra Black SR5 2WD Access
Last Online: 09-22-2009 02:15 PM
2002toytundra is on a distinguished road.
2002toytundra's Photo Albums
look under the bed and you will see the shock mounts, check the top of the mount between the bed and the frame make sure it is tight. You can use a adjustable cresent wrench to hold the post from turning while adjusting the upper shock mount nut if need be.
look at your ball joints and tie rod ends in the front end, if the boots for the ball joints are split, top and bottom of the spindle, good chance the joints are gone. You can jack it up and see if there is any play in the wheels, grab the top of the tire and wiggle it toward you, shouldnt be any play.
the tie rod ends are off the rack and pinion, attaching to the spindle, where the brake rotor and wheel are attached. grab it and wiggle should be no play there either.
Old 05-29-2009, 12:41 AM
bezwickk's Avatar
thankyou ill check it out tomorrow morning
Old 05-29-2009, 08:03 PM
bezwickk's Avatar
i checked the play in the tires and there isnt any play.. idkk about the rear end though. i dont hear the front end now as much.. mainly the rear end. i havent checked the upper shock mounts yet.. i will tomorrow
Tags
06 tundra , clunk
