What bolt size can be used to remove brake drums?
+ Reply to Thread
Results 1 to 14 of 14
Like Tree1Likes
  • 1 Post By Goody51
Thread: What bolt size can be used to remove brake drums?
  1. #1
    Join Date
    Sep 2007
    Location
    Chandler, AZ
    Posts
    30
    Liked
    5 times
    Rep Power
    317
    Default What bolt size can be used to remove brake drums?
    This morning I decicded to remove the wheels from my 2005 two-wheel drive Tundra so that I could check the condition of the brake pads and brake shoes. I had no problem looking at the disc brake pads, but both drums are stuck on. With this model truck there is a guard around the outer edge of the rear brake drums and there is no way to grab the drum and pull it off or tap the edge with a hammer. The drums are rusty at the hub which makes the problem worse. In my Haynes manual it shows that there are two threaded holes in each brake drum where I can screw in bolts to help remove the stuck drums. But it does not say what size bolt to use. I assume that it will be a metric bolt size. Does anyone know what bolts I need that can be threaded into the tapped holes in the brake drums to allow me to unstick the drums so that I can remove them and examine the brake shoes?
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Junior Member Rotts's Avatar
    Join Date
    Jan 2007
    Location
    Monroe
    Age
    42
    Posts
    54
    Liked
    0 times
    Images
    6
    Rep Power
    9
    Default Re: What bolt size can be used to remove brake drums?
    Not sure of the bolt size, but you may have to back off on the adjustment of the brake shoes then pull of the drum. The shoes may be holding it.
    2005 Tundra DC TRD 4WD "Silver Sky"
    Fabtech Dirt Logic 2.5 with 2" aal in the rear
    American Racing 16x9's with 285/75/16
    Firestone Destination M/T, LSD, TRD Dual Exhaust, Westin nerf bars, Linex, Toyota bug guard, Husky floor mats, Prodigy brake controller,
    window tint, debadged
    2000 4-Runner SR5 4WD "Jade"
    31x10.50 Bridgestone Dueler A/T Revo's
    Stampede bug guard, Husky floor mats, brake controller, window tint
  4. #3
    Join Date
    Sep 2005
    Location
    Hockessin, DE
    Posts
    186
    Liked
    0 times
    Rep Power
    10
    as above poster stated, back off the shoes. then spray the hubs with a rust cutter and let it soak. you can then tap the drum with a hammer.
    Don't use the bolt holes. if the hub is stuck, you will bend the face of the drum.
    ask me how I know. I ruined a set of drums on a 4runner.
  5. #4
    Supporter Goody51's Avatar
    Join Date
    Feb 2009
    Location
    El Cajon, CA.
    Age
    63
    Posts
    25
    Liked
    1 times
    Rep Power
    7
    I read somewhere the bolt size is 8mm X 1.25, but I haven’t tried it yet….
    tundra3400 likes this.
  6. #5
    Supporter Remmy700P's Avatar
    Join Date
    Jan 2008
    Location
    Inland Empire, CA
    Age
    49
    Posts
    8,382
    Liked
    3166 times
    Images
    47
    Rep Power
    162921
    Just a stupid, quick question: Did you make sure that you released the e-brake before trying to pry them off? (don't ask me why I'm asking this question!!)
    2002 Tundra V8 SR5 2WD AC
    1C7-Thunder Gray Metallic | Bilstein 5100s | Wheeler's Progressive 3-leaf AAL w/ OL Leaf
    LT265/75R16D1 Nitto Terra Grapplers | Wheeler's Poly Sway Bar Bushing/Bump Stop Set
    eBay T304 SS Headers | Percy's #66080 Header Gaskets | Remflex #8015 Collector Gaskets
    13WL Caliper Upgrade | Hawk Quiet Slot Rotors | Hawk LTS Brake Pads
    Mobil 1 Syn 5W-30 | Mobil 1 Syn ATF | Mobil 1 Syn 75W-90 Gear Oil | Magnefine ATF Filter 3/8"
    Denso #K20R-U Plugs | Russell Speed Bleeders #639570 (7mm)
    Ham Radio: KJ6OPA | CB Radio/Handle: Midland 75-822/"Marksman"
    * * * O2 Sensor Replacement DIY * * *
    "I came into this world covered in someone else's blood and screaming...I'm not afraid to leave it in the same way."
  7. #6
    Supporter ThomasE's Avatar
    Join Date
    Feb 2002
    Location
    San Jose, CA
    Posts
    371
    Liked
    1 times
    Rep Power
    14
    I still have the package from the bolts I bought to remove the rear drums, it's M8x30 pitch 1.25. I think the 30 is the length, you can use that or longer.
    TRUCK: 2001 2WD V8 AC MODS: JBA headers! Magnaflow muffler, TRD 4x4 coils & shocks, Wheeler's AAL's, Truxedo bed cover, Bridgestone Dueler AT LT265/75/16, Surepull hitch, Drawtite convertor box, MAPP nerf bars, Toyota bed mat
  8. #7
    Join Date
    Nov 2004
    Location
    Saylorsburg, PA
    Posts
    176
    Liked
    1 times
    Rep Power
    1184
    I had to back the star adjusters way off before the drum covers would come off with the bolts. Once I backed them off enough, the covers popped right off with the bolts. You'll be able to tell if the adjusters are not backed off enough - the bolts will move the drum cover out easily a short distance, then it will hang up on the wear ridge.
    You'll know you're adjusting the star adjuster in the wrong direction if you aren't able to turn the drum by hand any longer (pushing the pads into engagement).
    - Chris
    2005 Tundra V8 4x4 regular cab, Phantom Gray, Line-X, Jeraco cap, 245/75-16 Goodyear Wrangler SilentArmors, 245-75R16 Firestone Winterforce snows in winter - nickname: "Gaspig"
  9. #8
    Supercharged Member HOGWILD's Avatar
    Join Date
    May 2006
    Location
    Albuquerque
    Posts
    3,510
    Liked
    7 times
    Images
    12
    Rep Power
    578
    Inside this pdf should explain what ya need to know! hope it helps!
    Attached Files Attached Files
  10. #9
    Join Date
    Dec 2014
    Location
    Jersey City
    Posts
    6
    Liked
    0 times
    Rep Power
    0
    Size is 8mm X 1.25.
    Mine still stuck because brake pads were expanded try turning the star wheel adjustor as well.
    Later found out the problem was the ridge of rust that built up on the wheel.
    As long as the wheel turns the brakes pads are not too expanded to pull off the drum.
    Just had to let it soak overnight with rust remover.
  11. #10
    Supporter Stone_Blue's Avatar
    Join Date
    Mar 2012
    Location
    NY
    Posts
    2,152
    Liked
    874 times
    Images
    4
    Rep Power
    42261
    Quote Originally Posted by Shane1962 View Post
    Size is 8mm X 1.25.
    Then you need to turn it the other way.
    See my post on the other thread.
  12. #11
    Join Date
    Aug 2007
    Location
    DEERFIELD BEACH
    Posts
    3,996
    Liked
    79 times
    Rep Power
    3318
    hi 5lb or 10lb Sledge Hammer. gorilla lol tats wah i used rotflmao
  13. #12
    Join Date
    Mar 2012
    Location
    NY
    Posts
    2,152
    Liked
    874 times
    Images
    4
    Rep Power
    42261
    ^^ Gorilla, you made me cringe, reading that...
    Rubber mallet has always worked wonders for me...That way, you can whack that b!tch as hard as you want.. Even for the worst rust that western NY can turn out, has never stopped my mallet from getting them OFF!!...With ZERO damage to parts...(and fingers, and old, arthritic joints, as well... )
  14. #13
    Join Date
    Nov 2006
    Location
    Hanahan, SC
    Age
    34
    Posts
    265
    Liked
    32 times
    Rep Power
    3144
    8 x 1.25 - been there before with my 2006---fun times
  15. #14
    Join Date
    Dec 2014
    Location
    Jersey City
    Posts
    6
    Liked
    0 times
    Rep Power
    0
    After finishing found out my brake pads were not adjusted right the Emergency Brake was not working.
    Should have left the rear suspended on the jack stands and tried out the Emergency Brake to get the adjustment right. Read to expand star wheel brake adjustment until tire wouldn't move then contract 8 clicks. Problem is the clicker does not make the clicking noise when contracting the brakes. Should have made the adjustment while truck was still on the jacks which would have made things a lot easier.
    Thanks EVERYONE for all the input.
    I almost gave up and took it to a mechanic but I'm too much of a hard head to give up on anything.
    A lot of aggravation but still have my pride.
Quick Reply Quick Reply
Register Now
Log-in
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
