Old 06-12-2009, 10:10 AM
tundratoy04's Avatar
Dealer : Brunswick Auto Mart
2004 Toyota Tundra,
1995 Toyota Camry LE Wagon (Family),
2001 Toyota Echo Coupe (Wifes Car),
- Other - 1992 Cadilac Sedan
Last Online: Today 02:43 PM
Images: 88
tundratoy04 will become famous soon enough. tundratoy04 will become famous soon enough.
Send a message via Yahoo to tundratoy04 tundratoy04's Photo Albums
Default pedal is dead for a split second
I have noticed that my truck accelerates with a slight delay.
It feels like a carburetor with a bad accelerator pump. The pedal is dead for a split second. When I hit it quickly to full throttle or half throttle or quarter throttle, it sounds like an exhale then the rpms climb.
ex: sthhhhhvvrrroooooooooommmmm! Tough to put in words. It has the sound of a carburetor with no air cleaner, and you dump the throttle linkage on the side and you hear the initial burst of air get sucked into it. Only I hear it from in the cab and I have no carburetor.
Since we don't have carburetors, what else would make such a feeling and sound?
Once it "exhales" it takes off like a bat out a hell. It is just half dead for a second.
SR5 Double Cab 4x4 De-Badged
Bilstein 5100 Adj Front Shocks Set at 1.3" Inside TRD Coils
1" Frt Diff Drop
Bilstein 5100 Rear Shocks
Front & Rear Timbens
Removed "Y" Pipe - Gibson Extreme Dual Exhaust
265/70/17 LTX MS Tires
K&N Air Filter
Old 06-12-2009, 01:47 PM
duffyatkinson's Avatar
Dealer : Toyota of Riverside
2002 Toyota Tundra,
2003 Toyota 4Runner V6 Limited 4WD
Last Online: Today 01:43 PM
Images: 17
duffyatkinson has much to be proud of. duffyatkinson has much to be proud of. duffyatkinson has much to be proud of. duffyatkinson has much to be proud of.
Send a message via Yahoo to duffyatkinson duffyatkinson's Photo Albums
Default Re: pedal is dead for a split second
Go through the steps:
1. Clean MAF Sensor
2. Clean throttle body and throttle plate
3. Clean/replace air filter
4. Check/clean/lube throttle cable return spring
5. Check for loose/damaged vacuum lines
6. Clean PCV valve
That "sucking sound" is, in my experience, just a sonic characteristic of the K&N filter.
Report back with results after the above.
2002 Tundra V8 SR5 2WD AC | Silver Sky Metallic | Chrome Step Bars | Kobalt Low Profile Bed Box
Daystar 2.5" Levelling Lift, 1" Rear Block
Mobil-1 5W-30 | Magnefine ATF Filter 3/8" | K&N AF #33-2144 | NGK Iridium Plugs #BKR6EIX
Russell Speed Bleeders #639560 | Josh's Billet Wing Window Latch Upgrade
11/1/2009: 48,050 miles
* * * I highly recommend http://www.auto-rx.com/ for your engine and transmission! * * *
* * * O2 Sensor Replacement DIY: http://www.tundrasolutions.com/forums/1197269-post2/ * * *
Old 06-12-2009, 03:52 PM
NHtoyman's Avatar
Dealer : Grappone Toyota
2004 Toyota Tundra
Last Online: Today 03:29 PM
Images: 4
NHtoyman is on a distinguished road.
NHtoyman's Photo Albums
1. Clean MAF Sensor
6. Clean PCV valve
I would deff do these first. I have the same year and mine is instant throttle responce. I have to act like I have an egg under the pedal it's that touchy. The tundra's atleast the 04's not sure about the earlier ones. They have no throttle cable. It's all electronic.
Give it a good cleaning and see if that helps.
My 2004 AC= 5100'S, Diff Drop, Weather tech Mats, Kenwood KDC-HD942U, Polk speakers. (Amped Soon)
MagnaFlow 11226 Muffler with 3 inch Tip.
Old 06-12-2009, 06:45 PM
2002 Toyota Tundra,
Images: 17
You are correct! Sorry, I misspoke. Check/clean the throttle plate spring!
Old 06-17-2009, 11:47 AM
2004 Toyota Tundra,
Images: 88
I went down the list and some things are done every oil change, the one thing I did was clean the throttle body and plate - that made a big difference, thanks.
Now it is back to normal - how often do you clean the throttle body and plate?
1" Frt Diff Drop
K&N Air Filter
Old 06-17-2009, 12:23 PM
NoKz's Avatar
Was I Speeding Officer?
Dealer : Penske Toyota
2005 Toyota Tundra
Last Online: 11-21-2009 05:05 PM
Images: 19
NoKz is a splendid one to behold. NoKz is a splendid one to behold. NoKz is a splendid one to behold.
Send a message via MSN to NoKz NoKz's Photo Albums
I had a similar problem. Turned out to be my cold air intake. I removed it and when back to stock with a drop in filter. Runs amazing!
www.OutlawOffroad.com
- Tell Them John w/the Tundra Sent You!
Car Domain: www.cardomain.com/ride/3304446
Old 06-17-2009, 12:50 PM
Dealer : Doxon Toyota
2002 Toyota Tundra mica green trd
Last Online: Today 12:55 PM
sr5mike will become famous soon enough.
sr5mike's Photo Albums
I clean my throttle body and MAF every 30k.
At least they have circled the problem.
Old 06-17-2009, 02:45 PM
Last Online: Today 12:25 PM
Jaynelson is on a distinguished road.
Jaynelson's Photo Albums
Drive by wire systems always have a noticeable delay in them....not sure if that's what you're thinking of tho.
