Old 06-25-2009, 01:43 PM
MATRDguy's Avatar
Dealer : Ira Toyota of Danvers
2002 Toyota Tundra
Last Online: 10-21-2009 09:41 AM
Images: 10
MATRDguy is on a distinguished road.
MATRDguy's Photo Albums
Default Bad Ball Joints AGAIN !!!
Had my ball joints on my 02 done under the recall....100,000 miles later they are bad AGAIN !! Has anyone had this experience?
What is the life of these joints?
I do 98% Hwy driving.
Any comments/ suggestions ? ( yeah I called the dealer who installed them and they said the warranty was only good for 1 yr so....)
Any Ideas would be appreciated. How difficult is it to change them out yourself?
02 SR5 Access Cab 4x4 TRD
Firestone Destination A/T's 265-70-17, FJ Cruiser Rims, JBA Cat Back and Y pipe,
Ivan Stewart TRD Grille, Clear Corners, True Flow CAI, Bilstines 5100's , Access Bed Cover ,
Tundra All Weather mats.
MAAP Nerf Bars, Toyota Skid Plate,
OE 6 Disc Changer
Bully Hitch Step, Vent Visors, Auto Dim Mirror w/ Compass, Tundra Sill Protectors, Toyota Bed Extender, Optima Red Top
Yesterday was the only easy day.........
Old 06-25-2009, 03:44 PM
2000 Toyota Tundra 4X4 SR5 AC 158,000
Last Online: Yesterday 07:06 PM
packeroni is on a distinguished road.
packeroni's Photo Albums
Default Re: Bad Ball Joints AGAIN !!!
What signs were you seeing to know you needed to take it in for eval?
Old 06-26-2009, 10:28 AM
5 Speed's Avatar
Dealer : Longo Toyota
Last Online: Today 02:47 PM
Images: 19
5 Speed will become famous soon enough.
5 Speed's Photo Albums
I did a DIY tutorial on here and if you can find it, it is really pretty easy. The only hard part was getting the rusted cotter pin out. The ball joint puller cost about ten bucks at harbor freight and putting new ones on gave me a nice peace of mind driving down the road. I think 100K for a set of ball joints ain't bad. If we could actually have a zerk fitting on them I think they might go longer but the sealed units are convenient in the beginning but usually don't live the long life.
Old 06-26-2009, 10:43 AM
MATRDguy's Avatar
2002 Toyota Tundra
Images: 10
There were no 'signs' I just happened to take it in to get the tires rotated and the guy told me one of my sway bar end links was misssing and my BJ were worn.
I reordered some new endlinks on flea bay, I'll get those in and do the lower BJ again w/ the help of the tutorial.
Still have to do my poly steering bushings too...OMG so much to do.
Probably snapped the endlink driving on the Mass Pike. Ive been on trail rides that werent as filled w/ potholes as the Pike is.
Thanks for the imput
OE 6 Disc Changer
Old 06-26-2009, 11:27 AM
ICON's Avatar
Dealer : Lia Toyota Of Northampton
Last Online: 11-06-2009 12:26 PM
Images: 7
ICON is on a distinguished road.
ICON's Photo Albums
100K out of ball joints isn't that bad. Chevy S10's, Blazers, Explorers and some F150's go through ball joints every 30K. My regular mechanic was seeing full sized ford vans(4wd) coming in w/15K needing new ball joints. Granted i got 115K on my '01 and everything is stock and tight. I'd check the ball joints myself to make sure they're indeed bad since i've had people tell me ball joints were bad but upon inspection they were just fine. Ones deffinition of "gone" can be different from person to person, especially if there's money to be made.
'01 Tundra Reg Cab SR5 V8
'05 Honda Foreman 500S 4x4
'04 Honda Shadow Sabre 1100
Old 06-26-2009, 11:52 AM
MATRDguy's Avatar
2002 Toyota Tundra
Images: 10
Yeah, I'll crawl under there to see what they look like, just put an offer in on Flea bay for some new ones...50.00 isnt bad. I have to replace the end links too ( as one id TOTALLY gone) snapped off. May as well do this too...I just bought my 1st house so I wont have too much time to work on the 'beast' so better do it before my g/f gets her hands on my spare $$.
OE 6 Disc Changer
Old 06-26-2009, 04:51 PM
DevinSixtySeven's Avatar
Leader of Group Evil
Dealer : Voss Toyota
Last Online: 11-06-2009 05:41 PM
Images: 22
Before you order new joints, borrow (or buy, they're cheap) a large 2-jaw puller from Autozone/Checker/Pep Boys/Etc...pop the stud out of the upper arm, and try to move the stud side to side in the cup, as it would when the suspension moves. If it's really, really easy...it might be "tight" as you're able to judge, but easy to move around...then it's time to replace the joint. If it's tight, and takes a bit of force to start moving, it's still fine.
The same applies to lower ball joints, tie rod ends, and in general any spherical bearing.
100k is good for joints...you could also just swap 'em and move on.
-Sean
GFX by FreedomEagle50
Manual Hubs
Old 06-29-2009, 11:47 AM
MATRDguy's Avatar
2002 Toyota Tundra
Images: 10
Yeah, figured I would just change them after 100K....I found some aftermakt ones on ebay pretty reasonable so I'll do that and the links @ the same time. I'll just have to pay for the alignment after that.
My 2 projects are that and doing the stering bushings...still have those and my stearing is a little slopy.
OE 6 Disc Changer
