Old 06-29-2009, 08:55 PM
kriscarlysle's Avatar
Last Online: 11-03-2009 02:07 PM
kriscarlysle is on a distinguished road.
kriscarlysle's Photo Albums
Default Suspension height difference after 1" block install
I'm hoping you guys can help me diagnose a problem that I have found after installing 1" rear blocks the other day. My first mistake was that I didn't measure my driver and passenger side height before installing them. But after installation, there's about a 3/8" difference in height from side to side.
What I have already checked:
- Measures from multiple points on the truck: bottom of wheel, center of hub, the ground
- Tire pressure
- The blocks to make sure they fit right and were pulled together tightly
- Leaf springs to make sure there was no difference or broken leaf
From there, the only thing I can think of is that the gas tank is on the driver's side, and that the weight of the fuel may make that side sag. Any ideas would help!
Old 06-30-2009, 09:46 AM
hofkamp83's Avatar
Dealer : Billion Motors
2005 Toyota Tundra
Last Online: Today 06:13 PM
Images: 49
hofkamp83 is on a distinguished road.
hofkamp83's Photo Albums
Default Re: Suspension height difference after 1" block install
i would drive it around for a awhile and then recheck everything and see what it looks like then. something may settle and level out.
Andrew
2005 Toyota Tundra Access Cab Limited
Goodyear Wrangler Silent Armor LT285/70R17, Bilstien 5100's, 1" Rear Blocks, Rough Country Rear Shocks, RevTek Diff Drop, Total Chaos Steering Rack Bushings, Downey HD End Links, CV Boot Mod, K&N CAI, Borla Split Side Exit Exhaust, Removed Resonator, Summit Nerf Bars, Bullett Bull Bar, KC Highlights Long Range Slim Lights, 1.25" Wheel Spacers, Herculiner Roll On Bed Liner
Full LED Conversion with HIDS, Panasonic CQ-VW100U, Panasonic CA-PANSC1U, Sirius SC-C1, Infinity 6022i, Infinity 6020CU, Q-Logic QL-C1TTX208, Kicker ZX400.1, Rockford Fosgate P2D28 x2, Cobra 9540, Scanguage 2
Old 06-30-2009, 10:28 AM
Thanks. I've driven it for a couple days now and it is the same. It's enough of a difference that I can now see it, and it it's driving me nuts!
Hopefully it will work itself out....
Old 07-02-2009, 02:04 AM
hofkamp83's Avatar
2005 Toyota Tundra
Images: 49
you could just get some 3/8 steel plate, notch it and put it above or below the block to level it out
Andrew
Old 07-02-2009, 06:46 AM
Tundradrenalin's Avatar
Assistant Administrator
Last Online: Today 09:46 AM
Images: 204
Tundradrenalin has done just about everything. Tundradrenalin has done just about everything. Tundradrenalin has done just about everything. Tundradrenalin has done just about everything. Tundradrenalin has done just about everything. Tundradrenalin has done just about everything. Tundradrenalin has done just about everything. Tundradrenalin has done just about everything. Tundradrenalin has done just about everything. Tundradrenalin has done just about everything. Tundradrenalin has done just about everything.
Leaf spring nuts all torqued to spec and showing near even stud length?
Take them out and measure it again? That may be the only way to see if the diff was there all along.
Under the Hood: AMSOIL Synthetic Lubes all around, AMSOIL Ea Air Filter, Doug Thorley Headers, Magnaflow Exhaust, Semi-RAMair airbox mod
Suspension & Tires: 285/75-16 BFG T/A'ko, Fabtech Coils, Toytec Diff Drop, 1.25" Spidertrax [front], 1.5" Goeske Wheel Adapters [rear]
Handling: TC Poly Steering Rack Bushings, Downey HD End Links, Wheeler's Anti-Sway Kit, Hellwig 7700 Swaybar, Timbren Rear SES
Electrical: URD MAF Sensor Calibrator, Superlift Truspeed Speed Sensor Re-Calibrator, ScangaugeII, Full VLED's Conversion
Stereo: Alpine CDA-9886, Alpine & Phoenix Gold amps, Q-Logic box w/RF subs, eDead Sound Deadener
Cosmetic: Line-X Bedliner & Mirror covers, Custom N-Fab Steps, Rear Diff Breather Extension, F103N Fumoto Oil Drain Valve,
Debadged (partially), Bell Truck Trunk, Access Vanish Tonneau
Old 07-02-2009, 07:37 AM
Salty_Dog's Avatar
Moderator
Dealer : Toyota Of Stafford
2001 Toyota Tundra,
2002 Toyota Corolla
Last Online: Today 06:33 PM
Images: 577
Salty_Dog has done just about everything. Salty_Dog has done just about everything. Salty_Dog has done just about everything. Salty_Dog has done just about everything. Salty_Dog has done just about everything. Salty_Dog has done just about everything. Salty_Dog has done just about everything. Salty_Dog has done just about everything. Salty_Dog has done just about everything. Salty_Dog has done just about everything. Salty_Dog has done just about everything.
Send a message via Yahoo to Salty_Dog Salty_Dog's Photo Albums
Try measuring from the axle to the ground on either side of the differential. If the measurements are equal, the problem is with the suspension.
If the measurements are different then check your wheels and tires. Try temporarily swapping your Left-Rear and Right-Rear tires. Does the height difference move to the other side?
Salty Dog
JDM is the new Rice
Ride: 2001 Tundra SR5, 4WD, The Lean Mean Green Machine, Lift, Front: Bilstein 5100 Adjustable Shocks w/ Total Chaos Diff Drop, Lift, Rear: 1" Wheeler's Blocks, Wheels: Chromed Factory 4Runner Rims, 17", Tires: Bridgestone Revos, 285/70R-17, Performance: Unichip, Borla Exhaust, Optima Yellow-top Battery, Flux Capacitor, Interior: Dog Hair on Back Seat, Coffee Stains on Console, Bling: Ivan Stewart TRD Grille, Westin Nerf Bars, Clear Corners & Eurotails, Debadged, Audio: Kenwood DDX512 Head Unit, Polk Audio db6501 component speakers (Front), Polk Audio db651s speakers (Rear), Profile AP740 4-channel amplifier, Rockford Fosgate 8” Punch subwoofer (x 2) in Q-Logic enclosure, Profile AP700M mono subwoofer amplifier, Audiovox ACA200W Rear-view camera, Audiovox XM Express Satellite Radio Receiver, Shark Fin Antenna, Other: Viair 450C compressor, 2.5 Gallon air tank, Kleinn Pro Series 4-Trumpet air horns, Eye Candy: Hottie Wife in Passenger Seat, Security System: One Very Ornery Dog
Old 07-03-2009, 07:44 PM
Thanks for the advice guys. I have checked to make sure that all the nuts are torqued the same and that the same length of stud is showing on each side of each u-bolt. I'll be sure to do some more measurements to make sure it's the suspension that's out of whack and see what I find.
Old 07-04-2009, 07:40 PM
ThomasE's Avatar
Dealer : Piercey Toyota Scion
Last Online: Today 03:32 AM
ThomasE is on a distinguished road.
ThomasE's Photo Albums
That's normal, all the heavy stuff like the battery, gas tank, driver is on the same side. My truck has .5" difference between the driver and passenger side with a full gas tank. It get's almost even on an empty tank.
TRUCK: 2001 2WD V8 AC MODS: JBA headers! Magnaflow muffler, TRD 4x4 coils & shocks, Wheeler's AAL's, Truxedo bed cover, Bridgestone Dueler AT LT265/75/16, Surepull hitch, Drawtite convertor box, MAPP nerf bars, Toyota bed mat
Old 07-11-2009, 01:00 AM
Dealer : Toyota of Riverside
2003 Toyota Tundra
Last Online: 09-13-2009 10:35 PM
Pauly G is on a distinguished road.
Pauly G's Photo Albums
Mine measures about 1/4" lower on the left - before I get in it.
Old 07-13-2009, 06:47 PM
Thanks. That's not very encouraging, considering that driver weight will make it worse! Guess I'll have to deal with it.
