Old 07-01-2009, 11:46 AM
toddbmobile's Avatar
2001 Toyota Tundra Hunter Green
Last Online: 11-08-2009 04:26 PM
Images: 5
toddbmobile is on a distinguished road.
toddbmobile's Photo Albums
Exclamation FOG LAMPS WONT WORK! Help!
Can someone please send me a copy of the fog lamp/lighting wiring diagram for a 2001 tundra w/ factory fog lamps? My fog lamps were working up until today ,and now they wont come on. I am in the low beam postion, because I have not moded my fogs, but still no lights. Can someone tell me where the fog lamp fuses are? I am aware of the driver's side fuse box, but nothing indicates fogs. Also where is the fog lamp relay? I have tried to find a post for this question, but the posts either don't have enough detail or don't apply to me.
Old 07-01-2009, 01:14 PM
Tankerhank's Avatar
Just Call Me Hank
2007 Toyota Tundra Salsa Red DCLB 5.7,
2002 Toyota 4Runner Limited, Silver
Last Online: Today 11:59 AM
Images: 45
Tankerhank is a name known to all. Tankerhank is a name known to all. Tankerhank is a name known to all. Tankerhank is a name known to all. Tankerhank is a name known to all. Tankerhank is a name known to all. Tankerhank is a name known to all. Tankerhank is a name known to all.
Tankerhank's Photo Albums
Default Re: FOG LAMPS WONT WORK! Help!
The fuse for the fog lights is in the fuse box under the hood. Diagram on lid. (middle of fuse box 20 amp next to 7.5 amp fuse)
Hank
2007 Tundra SR5 DC LB 5.7, Underseat storage, Sonar, Backup Camera, Prodigy brake contoller, Reese 16k 5'er hitch, Towing Mirrors, Michelin LT AT2 275/65R18/E, Hellwig Helper Springs 2,000 lbs, 7/75 Platinum Warranty from Handy Toyota.
Future mods:
Stebel 300hz Horn
Fog Lights
2000 Tundra (bought 9/9/99)
JBA Headers
Gone but not forgotten~
Old 07-01-2009, 01:15 PM
mxsjw's Avatar
Jedi Ninja in Training
Dealer : Toyota of Puyallup
- Other - 2003 VW Passat,
Images: 10
mxsjw's Photo Albums
thread moved
Beer please!
Old 07-01-2009, 07:09 PM
Images: 5
Exclamation Re: FOG LAMPS WONT WORK! Help!
Thankyou Tankerhank. I found the engine fuse box and checked the fuse with my voltmeter. The 20amp fuse is good. The fog relay is also there in the engine fuse box. I posted some photos in my album area of the engine fuse box and relay. I have not had a chance to test the relay yet. If the relay is good any other ideas on why the fogs won't come on? How common is it for the relay to go bad? I think this relay has been with the truck since its production date.
Old 07-01-2009, 07:55 PM
Tankerhank's Avatar
Just Call Me Hank
Images: 45
Don't know, my truck is a 2000 fog lights still work fine, never an issue.
Next thing to check after the relay would be power when the switch is turned on or off. I am guessing the relay reacts to the low beam being turned on as the fogs are tied to them.
Hank
Future mods:
Stebel 300hz Horn
Fog Lights
JBA Headers
Old 07-02-2009, 07:53 AM
Dealer : Doxon Toyota
2002 Toyota Tundra mica green trd
Last Online: Today 09:31 AM
sr5mike will become famous soon enough.
sr5mike's Photo Albums
If the relay is good it sounds like you going to be looking at the bulbs then the switch.
At least they have circled the problem.
Tags
2001 , fog lights , tundra , wiring
