Old 07-04-2009, 11:32 AM
aaronch46e's Avatar
Dealer : Stevenson Toyota
2006 Toyota Tundra sr5
Last Online: 11-18-2009 09:29 PM
Images: 5
aaronch46e is on a distinguished road.
aaronch46e's Photo Albums
Default Help debadging 06 tundra
I have recently started debadging my tundra and have notice a residue left over on the area where the Iforce V8 badge was. Goo gone does not seem to be working so my question is what did you guys use to clear all residue off. Thanks
"Flying is Great, Landing is Better, Combat Aircrew"
2006 Sr5 DC Mods: Alpine 9886 H/U, Infinity 6.5 Componets in front, 6.5 Infinity 2 ways in rear. Alpine type R 10" sub(not currently installed) with Alpine Mrp-500.1 mono amp.Fosgate 200x4 rms 4channel amp. Delta Black diamond plate tool box. Black Carpet. 2.5 front,leveling kit, Fully debadged and side pieces painted black(no pics yet).......
Old 07-04-2009, 11:54 AM
highlevel's Avatar
life apprentice
Dealer : Magnussen Auburn Toyota
2006 Toyota Tundra Silver 4x4,
- Other - 03 Tundra - totalled
Last Online: Today 12:08 AM
Images: 25
highlevel is a glorious beacon of light. highlevel is a glorious beacon of light. highlevel is a glorious beacon of light. highlevel is a glorious beacon of light. highlevel is a glorious beacon of light. highlevel is a glorious beacon of light.
highlevel's Photo Albums
Default Re: Help debadging 06 tundra
I used denatured alcohol... it does take some time and patience to get all that stuff off.
Rob K.
2006 DC, SR5, 4.7L, 5 speed, 4WD, LSD,
Silver Sky Metallic, Keyless Entry, Tow Package
Westin wheel to wheel step bars
Rackit (powder coated)
Leer 100 w/Windoors
Air lift Ride Control w/Quick Shot and Onboard Air
Pop & Lock
Bedrug
Slide Master bed-slide
Bilstein 5100s (middle notch)
Wheeler's AAL
Toyo 265/70/17 10 ply (back on stock wheels)
Scangauge II
Waiting to be installed:
MB Quart Speakers
Eclipse Amp
TC steering rack bushings
TC diff drop
Downey end links
Kartec CV boots
Wish List:
Spidertrax
SS exhaust system
HD front bumber (Reuenal or ARB)
Mile Marker Winch
Changing professions or purchasing a service truck so I can make this one all about fun!
Treat others as you would like to be treated
Old 07-04-2009, 04:56 PM
Big_Al1's Avatar
veteran member
Dealer : Lake Charles Toyota
2005 Toyota Tundra,
2008 Toyota Sienna XLE
Last Online: 11-11-2009 09:53 AM
Images: 16
Big_Al1 will become famous soon enough.
Send a message via Yahoo to Big_Al1 Big_Al1's Photo Albums My eBay
Try a good clay bar the should work they will even take out some scuffs too.
Old 07-04-2009, 05:14 PM
goose8651's Avatar
Last Online: 11-16-2009 07:36 PM
goose8651 may have some regrets.
goose8651's Photo Albums
goo gone worked for me.
Old 07-04-2009, 07:38 PM
03tundy's Avatar
Dealer : O'Regan's South Shore Toyota
2003 Toyota Tundra
Last Online: 11-12-2009 08:06 PM
03tundy is on a distinguished road.
03tundy's Photo Albums
I have used a pinstrip remover rubber wheel ( cant remember what is called exactly) , its just a big round (3 inch) eraser mounted to a shaft you can put in a cordless drill...... available at auto paint supply stores
just be careful not to hold it in one spot too long, it does heat up....and it will take off some paint...ask me how I know.....
works very well
Old 07-05-2009, 08:39 AM
Dealer : Al Hendrickson Toyota
2005 Toyota Tundra
Last Online: 11-17-2009 03:30 PM
GORILLA is a splendid one to behold. GORILLA is a splendid one to behold.
GORILLA's Photo Albums
hi, try goof off.
but make sure you have a pail of soapy water, after the 3m tape comes off.
than just wipe clean than if you want to you can use 3m clear coat safe compound.
than polish seal & wax.
presto your done.
BUT what happen's many time's is you will still see the makes where the emblem/badge's were.
sadly there might not be anything you can do about them, except re-paint, or cover with a vinyl graphic.
the esayest way toremove the emblem.badges is fishing line, weed eater line, dental flaus.
than you only have the 3m double sides tape left.
that is eay to remove.
the only issue like i said it the outline of what was there.
good luck,
gorilla
