Old 07-13-2009, 10:23 PM
pirates712's Avatar
Dealer : New Country Toyota
Last Online: Yesterday 02:19 PM
pirates712 is on a distinguished road.
pirates712's Photo Albums My eBay
Default Stock vs. "Performance" filter
Which is better, and Airaid filter, or the stock filter. I don't want to hear about K&N, or any other manufacturer for that matter, because this is what I want to buy- Airaid Intake Tube.
I just want to know, will the Airaid yield better performance, mpg, or will it possibly damage the engine by allowing particles in?
I am going to ask the Toyota Technician, so whatever he thinks goes, But I would like to hear some other opinions.
Also, if Mr. Toyota says to stay with the stock filter, would anyone be interested in the airaid? (filter only, no tube).
Old 07-14-2009, 10:54 AM
pirates712's Avatar
Default Re: Stock vs. "Performance" filter
Any Ideas? Anyone interested in the filter?
Old 07-14-2009, 11:07 AM
kanielb1's Avatar
Dealer : Toyota of New Orleans
Last Online: 11-21-2009 01:24 PM
Images: 21
kanielb1 will become famous soon enough.
Send a message via Yahoo to kanielb1 kanielb1's Photo Albums
How is that tube any better than stock?? Sounds like you already have your mind made up.
2008 Silver Sky Toyota Tundra 4.7L V8 Double Cab
-Spray In Bed Liner
-Truxedo Truxport Tonneau
-Llumar Window Tint
-TRD Sway Bar
Old 07-14-2009, 11:49 AM
pirates712's Avatar
here, compare them yourself.
http://www.airaid.com/InstallationPDF/510-761.pdf
I am buying the kit which come with the filter, I haven't decided if I want to use the filter or not.
Old 07-14-2009, 12:47 PM
Dealer : Toyota and Scion Mall of Georgia
Last Online: 11-05-2009 10:50 AM
AllYotas is on a distinguished road.
AllYotas's Photo Albums
And that tube is different from the factory one how?
Old 07-14-2009, 12:56 PM
pirates712's Avatar
Did you even look at the comparison pictures at the bottom? The airaid doesn't have the huge box on it and doesn't have the corrugated section leading to the filter. Take a look yourself to see what I mean. It is also slightly larger and curves more gently to provide better airflow.
Old 07-14-2009, 01:14 PM
Originally Posted by pirates712 View Post
Did you even look at the comparison pictures at the bottom? The airaid doesn't have the huge box on it which makes it louder and doesn't have the corrugated section leading to the filter which makes the filter now harder to change because the lid isn't allowed to move . Take a look yourself to see what I mean. It is also slightly larger and curves more gently to provide better airflow. looks like the expensive one has more bends. And it can't be any larger on the ends so there's no real increase in air flow.
Reminds me of the guy that took his 4runner fake ram air hood and added 3 1" hoses and actually decreased the amount of air the engine could pull in.
3-1" hoses is not the same as 1 3" pipe.
Your money
Old 07-14-2009, 01:21 PM
Dealer : Doxon Toyota
2002 Toyota Tundra mica green trd
Last Online: Yesterday 08:13 PM
sr5mike will become famous soon enough.
sr5mike's Photo Albums
I dont think you will see any gains. But it is your money.
Old 07-14-2009, 01:24 PM
pirates712's Avatar
My question is about the filter, not the tube. If you have anything productive to say about that, fine. My reason for going with this kit in the first place is that a.) The factory tube HAS to be more restrictive. With the corrugated section increasing turbulence and resistance, it's no wonder the smother inside of the airaid tube delivers more air to the engine. When I said the tube was bigger, I don't mean overall because I know that won't do crap. It may be slightly larger on the curved portions to make more room for the air to flow. b.) A K&N system pulls in warm air from the engine compartment, while the stock box is a true CAI. The only place to improve is the tube. c.) Because it is less restrictive, it should boost power and mpg. Just cleaning you TB will yield an increase in power.
Old 07-14-2009, 01:33 PM
why not try both. Then you'll be the expert.
Old 07-14-2009, 01:54 PM
The only way you will see any gains is if the engine is starving for air. Their has been vacuum tests done on the stack system and that is not the case. The engine will only take as much air as it needs. You can put bigger and straighter pipe on it until the cows come home.
At least they have circled the problem.
Old 07-14-2009, 02:16 PM
Dealer : Butler Toyota Co.
2004 Toyota Tundra
Last Online: 10-29-2009 10:16 AM
bill3508 will become famous soon enough.
bill3508's Photo Albums
I wouldn't waste your money on an intake until you get headers on it. The first mod for this truck should be headers followed by everything else. Its the best bang for the buck you can do.
04 TRD AC 4X4,JBA headers,True Flow intake w/K&N drop-in, Spintech Sportsman Street XL muffler, NGK TR6ix plugs, new Denso 234-4209 o2 sensors,Mobil 1 Syn 0W-40
Old 07-14-2009, 02:41 PM
2005 Toyota Tundra
Last Online: Today 10:30 AM
cheapskate is on a distinguished road.
cheapskate's Photo Albums
So you are saying that the corrugated hose that Toyota put on from the factory is more restrictive than the smooth, one piece design of the aftermarket tube? Dont you think it would cost more money to make the tube that came stock with the truck? Since it has the corrugation and more bends it should cost more to make. So why would Toyota put an intake tube on your truck that was more expensive to make and more restrictive? That makes no sense at all. As far as open type CAI's pulling in "warm air" from the engine, how warm is that air? After all, if you are at wide open throttle, you're not doing that when you are standing still. If you are going to hammer on the gas you're probably going to be pushing a lot of air through the engine compartment as you move forward so that theory may not hold a lot of water. As far as the filter goes, why dont you hold it up to a K&N and compare for yourself. From the pictures they look exactly the same to me so are you sure there is even any difference between the 2? Like everyone else here has said, sounds like you already made your mind up anyway. Good luck with your $150 air filter.
Old 07-14-2009, 05:44 PM
TundraSkyline's Avatar
2001 Toyota Tundra 4WD
Last Online: 11-05-2009 03:27 AM
Images: 7
TundraSkyline is on a distinguished road.
TundraSkyline's Photo Albums
The corrugated section is really just to allow minor engine movement since the airbox is bolted to the body and engine will move side-to-side under load (accel/deccel). When a MFGR builds a car they don't invest to squeeze every HP out, they invest to build something that will last.
My unsolicited $0.02 on intakes: For whatever mpg a manufacturer claims to have increased by modifying the intake with "high flow" components, the sound everyone loves to hear at or near WOT negates every last one. So buying a performance product based on mpg never made sense to me. If you're looking to increase mpgs, check tire pressure every month and keep your truck stock, don't carry unnecessary items, and actually clean-out/replace your filter when you're supposed to.
AiraidJr:
This thing costs $146 and I guarantee any <$100 made in china intake from ebay that replaces the oem airbox will make more power. This retains the airbox so it's not going to give any heartier rumble, make any power, and the inlet pipe is still black which absorbs instead of reflects heat. I don't see what you get for $146. $146 buys a lot gas. I do think it looks pretty tough though.
Only reason to buy an intake IMO:
1. Because they (can) look cool and sound cool + a four-tenths % hp increase.
2. or because it's one part to a laundry list of other performance upgrades planned that require more airflow to make good power.
Old 07-14-2009, 05:55 PM
Images: 7
I'm not 100% sure here, but I think the recommendations for K&N are for their drop-in replacement panel filters. Which retains the "true CAI" you mentioned you wanted to keep. They're like $50
