Old 07-19-2009, 10:55 PM
Last Online: 09-03-2009 12:21 AM
donnydmjr is on a distinguished road.
donnydmjr's Photo Albums
Unhappy timing belt
2002 tundra 188,000 miles replaced timing belt.
drove for approximately 2000 miles ran fine. Check engine light came on. cylinder randomly missfiring 2,4,6,8. Removed cam timing covers.Crank and cylinder 1 lined up on top dead center marks but right cam timing mark was off tdc.
What could have happened?
Thanks
Old 07-19-2009, 11:41 PM
Last Online: 10-23-2009 01:27 PM
HntnFsh is on a distinguished road.
HntnFsh's Photo Albums
Default Re: timing belt
Sounds like you may be a tooth off.Others may have a better idea though.
Old 07-20-2009, 01:24 AM
integraGSR's Avatar
2005 Toyota Tundra
Last Online: Today 03:30 AM
Images: 14
integraGSR will become famous soon enough.
Send a message via AIM to integraGSR integraGSR's Photo Albums My eBay
jumped a tooth. would definitely give you a misfire code on one side only.
05 Salsa Red Pearl DC
01 Honda Civic
95 Acura Integra
Old 07-20-2009, 01:41 AM
Dealer : Kendall Toyota Scion
2004 Toyota Tundra
Last Online: 10-30-2009 10:06 PM
muvico is on a distinguished road.
muvico's Photo Albums
did you rev at high rpm before that happend ? If you drive at high rpm maybe the tensioner gave up and caused the belt to slip. Maybe needs a new tensioner.Did you replaced the old one when you did your tim. belt?
Old 07-20-2009, 01:51 AM
Yes muico I did replace tensioner with new belt installation.
Old 07-22-2009, 12:10 PM
Last Online: 09-21-2009 03:08 PM
Icecube is on a distinguished road.
Icecube's Photo Albums
You need to do this manually use the number one piston to check the timming. The crank shaft pulley might have slipped showing you its out of timing when it actually is.
