Fan Speed Control Knob Broken
+ Reply to Thread
Results 1 to 12 of 12
Thread: Fan Speed Control Knob Broken
  1. #1
    Join Date
    Nov 2004
    Location
    Tuscaloosa, AL
    Posts
    294
    Liked
    0 times
    Rep Power
    11
    Default Fan Speed Control Knob Broken
    I've looked around on the internet and cannot find anything that is helpful. I have a 2003 tundra and the fan control knob just broke off the other day. The plastic square piece behind the knob was cracked, I glued it back together, but am unable to secure it in place. When I put the knob back into place it still has a lot of play and comes straight off when pulled. Any idea of a fix? Can you just replace the knob or do you have to replace everything? I would appreciate any advice.
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Supporter bamafire's Avatar
    Join Date
    Apr 2007
    Location
    Alabaster,Al.
    Age
    43
    Posts
    782
    Liked
    7 times
    Images
    11
    Rep Power
    3402
    Default Re: Fan Speed Control Knob Broken
    Are you talking about the square end of the knob, or the piece that actually sticks out of the dash? If it's just the knob, it's a very cheap Toyota dealer piece.
    Your actions speak so loudly, I can't hear what you're saying.
  4. #3
    Join Date
    Nov 2004
    Location
    Tuscaloosa, AL
    Posts
    294
    Liked
    0 times
    Rep Power
    11
    Thread Starter
    Its the square post on the backside of the knob. I believe I pretty much repaired the cracks, but I can't get it to fit back tight on the dash. If I can get a replacement part and it work that would be great, I'm just trying to make sure that it won't be loose like the current one. --Thanks
  5. #4
    Join Date
    Apr 2007
    Location
    Alabaster,Al.
    Age
    43
    Posts
    782
    Liked
    7 times
    Images
    11
    Rep Power
    3402
    I would try a new knob first, since it's like a 7 dollar part. The knob on my Celica kept falling off and would feel stripped if I turned it. 5 bucks later, I was in business. If it's the stud like part that comes out of the dash, I would think that's a different animal. All three are connected in one big box-like part. I still don't think it would be that hard to replace, but it might be expensive. If that's the case, you might want to check the boneyard.
  6. #5
    Join Date
    Apr 2007
    Location
    Alabaster,Al.
    Age
    43
    Posts
    782
    Liked
    7 times
    Images
    11
    Rep Power
    3402
  7. #6
    Join Date
    Nov 2004
    Location
    Tuscaloosa, AL
    Posts
    294
    Liked
    0 times
    Rep Power
    11
    Thread Starter
    Thanks, I'll try an new one
  8. #7
    Supporter Togman's Avatar
    Join Date
    Mar 2009
    Location
    Va Bch
    Posts
    413
    Liked
    5 times
    Images
    3
    Rep Power
    9
    There is a little metal clip that holds tension on the post agaist the knob to keep it from falling off.
    2003 Tundra SR5 4wd TRD Metallic Gray Paint
    Line X Bed Liner
    Hellwig Anti-Sway
    TC Poly Steering Rack Bushings
    Wheeler's Anti-Sway Kit
    K&N Drop in Filter
    Bilstein Shocks
    Hitch Scan Back Up Sensor
    Michelin LTX M/S2 Tires
    ARE Cab Hi Cap
    Firestone Ride Rite Air Springs
  9. #8
    Join Date
    Nov 2004
    Location
    Tuscaloosa, AL
    Posts
    294
    Liked
    0 times
    Rep Power
    11
    Thread Starter
    How small is it? That would be what I am missing. I looked around to see if I saw any additional pieces,--at least now I know somewhat what I'm looking for.
  10. #9
    Junior Member main70072's Avatar
    Join Date
    Aug 2007
    Location
    New Orleans, LA
    Posts
    202
    Liked
    27 times
    Rep Power
    1069
    It's a small little metal piece that fits inside the square hole on the knob. When I took my knob off, it fell behind the bezel and I had to remove the dash to get it. I found it on the white box below the A/C controls on the back of the bezel, put it back in and works fine.
  11. #10
    Junior Member Quentin18's Avatar
    Join Date
    Aug 2008
    Location
    St. George, UT
    Age
    24
    Posts
    318
    Liked
    0 times
    Images
    2
    Rep Power
    7
    Same thing happened to my truck. I just went into the dealership and got a new one for like 10 bucks. It was worth it since I didnt have to mess with trying to afro-engineering it so it could work for a week then just break again.
    but untill I got it I just switeched it with the temeture gauge ( red to blue haha ) so I could adjust the fan speed since It was always gonna be on the coldest setting durring the summer.
    Tundra with a little lift and 33's
  12. #11
    Rookie bobbyrocks's Avatar
    Join Date
    Jan 2009
    Location
    Tampa
    Posts
    18
    Liked
    0 times
    Rep Power
    0
    there is a small metal tab that sits in the channel that holds it onto the shaft. You are probably missing it. Your dealer can get if for you. I would get a whole new knob. I have already been through this.
    Bobby Wilcox
    Assistant Svc. Manager / Accessories Specialist
    Wesley Chapel Toyota
    bobbywilcox@wesleychapeltoyota.com
    813 407-5786
  13. #12
    Veteran Member escondidotundra's Avatar
    Join Date
    Jan 2008
    Location
    san diego, ca
    Posts
    1,194
    Liked
    411 times
    Rep Power
    9759
    a new one is 8 dollars at the dealer, I would know I bought one. shoulda bought some jb weld, would've saved like 2 bucks!
Quick Reply Quick Reply
Register Now
Log-in
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
