LinkBack (3) Thread Tools Display Modes
  3 links from elsewhere to this Post. Click to view. #1 (permalink)
Old 08-07-2009, 11:50 AM
Dealer : Larry H. Miller Toyota
- Other -
Last Online: 01-27-2010 02:48 AM
SuperRunner is on a distinguished road.
SuperRunner's Photo Albums
Default Anyway to disable traction control in drive-by-wire
So I have done an engine swap but my throttle won't go ast 27% and I am guessing it is due to the traction control. Obviosly I don't have traction control so I need to get around it.
What do you guys recommend?
Old 08-07-2009, 01:07 PM
TheGryme's Avatar
Supportive Supporter
Dealer : Valley-Hi Toyota
2004 Toyota Tundra,
- Other - 1992 Toyota 4Runner
Last Online: Yesterday 07:54 PM
Images: 23
TheGryme will become famous soon enough.
TheGryme's Photo Albums
Default Re: Anyway to disable traction control in drive-by-wire
Can you give us more details? What years, what engines, etc.
TheGryme Ummmm Beer Good.....Whiskey Better!
'04 Tundra DC
Grey....V8 SR5 4X4 TRD Off Road Suspension, LSD, Towing Package, Toyo Open Country A/T 265 75 16 ~ 8 Ply's, Magnaflowed, UNIChipped, True~Flowed (w/ Secret AirBox Mods!), DeBadged, ScanGaged, XM'ed.....Yeah!
'92 4Runner
Black, V6, Downey / Rancho suspension F&R, 3 inch sus lift, 1 inch body lift, SAW T-Barz, 4:88's, ARB (rear), 32X12.50 BS Dualers on AR 8X15 Wheelz, Power Slots and Pads, Downey headers, MagnaFlo Muff, K&N FIPK, Ported heads, 1 piece stainless valves...way too much money in it!
'04 YZ250F
Dr.D Header and Can, JD Jetting, P38 AP, UNI Flame Proof Air Filter, No Back Fire Screen, Carbon Fiber Carb Heat Shield, Renthals, Maxxis Desert IT Tires, ASV Controls....
'87 Nissan Pathfinder......gone but not forgotten.
Old 08-07-2009, 01:37 PM
- Other -
2005 tundra motor. Not using the stock auto tranny so speed sensors are different.
Old 08-07-2009, 07:15 PM
JBH1989's Avatar
Dealer : Toyota of Santa Maria
2004 Toyota Sequoia,
- Other - 1991 Isuzu Trooper,
1999 Toyota Camry Tan w/ 1MZ-FE,
- Other -- 1993 BMW 525i
Last Online: 12-12-2009 03:38 PM
JBH1989 is on a distinguished road.
JBH1989's Photo Albums
You can try to unplug the skid control ECU and see if it solves your problem. If the truck isn't a Tundra (which is kind of what it sounds like) it shouldn't be a problem that it'll disable the ABS.
Big question, what is the motor in? What kind of truck are we talking about?
2004 Marlin Blue Pearl Sequoia SR5 2WD; 60k miles
1991 Isuzu Trooper 2.6L 5spd 4x4; 103k miles
1993 BMW 525i M50TUB25 auto; 286,500 miles
ASE Certified Brakes Technician / Automotive Electrical Specialist
Independent BMW Technician
Old 08-10-2009, 11:31 AM
- Other -
Haha, no skid control, no ABS.
I will either need to go buy a skid control ecu and use it to disable, or if it is possible have the dealer disable it. It seems that the skid control communicates through the OBD port, from the wiring it looks like that is the only possible way for communication. So there might be a way to permantly disable the skid control.
Old 08-10-2009, 05:13 PM
- Other -
So I called the dealer and verified that my ECU did NOT have VSC.
So it is one of 3 things.
Speed sensor
Transmission Selector
wrong Accel pedal(don't know if there were any with different resistance but I doubt it.)
Can any of you open the throttle 100% while sitting in park?
Old 08-11-2009, 04:31 PM
TheGryme's Avatar
2004 Toyota Tundra,
Images: 23
What are you using to measure the throttle position....something like a ScanGage?
I'll check mine tonight, but I don't think it'll open very much in park or neautral.
'04 Tundra DC
'92 4Runner
'04 YZ250F
Old 08-11-2009, 05:02 PM
- Other -
Just a Harbor Frieght scan tool.
So this is interesting, I hooked up the air injection and it made things work a little differently.
Now when I turn on the ignition, I can go WOT. But as soon as as start the engine 20%.
My codes are
P0037 - rear O2 - not hooked up yet
P0057 - rear 02 - not hooked up yet
P0230 - fuel pump control(resistor) - not hooked up yet
P0453 - evap - not hooked up yet
P0504 - stop switch - not hooked up
P0705 - transmission range sensor - not hooked up yet
P0748 - trans solenoid(mechanical transmission)
P0778 - trans solenoid(mech transmission)
P2716 - trans solenoid(mech transission)
Old 08-14-2009, 04:50 PM
- Other -
found the fix.
1. Air injection MUST be working
2. The ECU needs to know that the transmission is in gear, so no fre-revving these motors at WOT in neutral or park.
Old 08-14-2009, 06:01 PM
TheGryme's Avatar
2004 Toyota Tundra,
Images: 23
So what kind of beast are you building???
'04 Tundra DC
'92 4Runner
'04 YZ250F
Old 08-14-2009, 06:25 PM
- Other -
1991 FJ80 landcruiser
Here is a link over to IH8MUD
2UZFE swap into FJ80 - building - in progress - IH8MUD.com
Old 08-14-2009, 07:07 PM
TheGryme's Avatar
2004 Toyota Tundra,
Images: 23
That should be very cool!!!! I have a old 92 4Runner with the v6....I've always thought the v8 would be bad *** in there.......and you'll probably get 20 mpg!!!!
'04 Tundra DC
'92 4Runner
'04 YZ250F
Old 08-15-2009, 02:53 PM
JBH1989's Avatar
Strange, I know I accidentally freerevved mine to redline when starting with my foot on the gas.
Glad you found the fix though!
Old 08-15-2009, 04:04 PM
tundra05_trd's Avatar
Professional Driver
Dealer : Norm Wagner Toyota
2005 Toyota Tundra
Last Online: Yesterday 06:52 PM
Images: 10
tundra05_trd is a splendid one to behold. tundra05_trd is a splendid one to behold.
tundra05_trd's Photo Albums
My '05 will run right up to redline in park, so I dont think it has anything to do with being in gear, but if you got it fixed, It doesnt matter why! Looks like thats going to be a beast. I had to read the whole thread, very interesting.
2005 Stepside TRD AC- phantom grey, 2.5" cornfed lift, 285/65/18 Nitto Terra Grapplers on Pro Comp 18x9 9089's, Magnaflow 15820 cat back, K+N fipk, Pioneer dvd, 2 Infinity Kappa 8's under rear seat w/Directed 600d amp, all Infinity kappa components in doors, Escort Passport 8500 radar hardwired, Scangauge II w/ blendmount, clear corners,tint, Tonneaumasters tonneau cover, fog light mod, Silverstars, Hellwig 7700 sway bar, NEXT: SAW's or Toytec coilovers, maybe uniballs too $$$$
Old 08-16-2009, 05:53 PM
- Other -
you can run it up to redline but the throttle won't be open more than a little bit so it takes a little longer to get there.
Also if you bump it from a gear to neutrel it takes a couple second for the ECU to limit the throttle.
LinkBack to this Thread: http://www.tundrasolutions.com/forums/1gen-tundra/170817-anyway-disable-traction-control-drive-wire/
Posted By For Type Date
2UZFE swap into FJ80 - building - in progress - Page 6 - IH8MUD.com This thread Refback 12-20-2009 12:19 PM
2UZFE swap into FJ80 - building - in progress - Page 2 - IH8MUD.com This thread Refback 11-27-2009 04:51 AM
2UZFE swap into FJ80 - building - in progress - Page 3 - IH8MUD.com This thread Refback 10-02-2009 10:08 PM
