vent visor glue removal
+ Reply to Thread
Results 1 to 14 of 14
Thread: vent visor glue removal
  1. #1
    Supporter Tundraman10's Avatar
    Join Date
    Sep 2007
    Location
    East Liverpool, Ohio
    Age
    28
    Posts
    1,077
    Liked
    0 times
    Images
    5
    Rep Power
    15
    Default vent visor glue removal
    Hey Guys, I removed my old vent visors that have been on my truck since 2002. Going to install a new set one of these days. I still have then remaining glue on the truck. How do I remove the vent visor glue? Tried some type of orange solvent and a razor blade and was able to remove some of the glue. But yeah got to be careful not to scratch or dig into the paint. Did that by accident.
    Is there an adhesive remover out there (stronger than what I have) on the market that would remove the glue?
    Also thinking about purchasing a heat gun to remove the rest of the glue.
    Chris
    2000 Toyota Tundra SR5 Access Cab 4x4 Black
    Cardomain Member
    Sold the Tundra for $5,000 without the wheels 12/10/2011
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Supporter bamafire's Avatar
    Join Date
    Apr 2007
    Location
    Alabaster,Al.
    Age
    43
    Posts
    782
    Liked
    7 times
    Images
    11
    Rep Power
    3403
    Default Re: vent visor glue removal
    Years ago, when I worked at a detail shop, we used to use a gasoline soaked rag to remove stuff such as this. It can be long, tedious, and messy, but with persistence, will usually remove about anything and not harm the paint. It will, however, remove any wax on the truck. Just use common sense and don't do something stupid like smoke around it or use it indoors, in front of your gas water heater. Try wd40 first, as I've used it to remove some pretty stubborn stuff too. The key is to let it soak in a few minutes before trying to rub off the adhesive. And I wouldn't try any of the above in direct sunlight.
    Your actions speak so loudly, I can't hear what you're saying.
  4. #3
    Join Date
    Sep 2007
    Location
    Age
    28
    Posts
    1,077
    Liked
    0 times
    Images
    5
    Rep Power
    15
    Thread Starter
    I also used to work in a detail shop. once in a while I would have to remove that cab bed adhesive. We used to use a heat gun, goof off adhesive remover and a razor blade. Yes I did scratch the rails of the truck but all of these trucks were the $6,500 and below so my boss didn't really care about them that much.
    Cardomain Member
  5. #4
    Join Date
    Apr 2007
    Location
    Alabaster,Al.
    Age
    43
    Posts
    782
    Liked
    7 times
    Images
    11
    Rep Power
    3403
    I didn't think about goof off. That might work. We used to use the gasoline on high dollar Lexus, Infinity and such. You just have to get it really wet, rub, and repeat. It won't scratch or harm it in any way-so long as you don't do it around flames or sparks!
  6. #5
    Junior Member Jugarum's Avatar
    Join Date
    Oct 2007
    Location
    Sacramento
    Posts
    56
    Liked
    0 times
    Rep Power
    8
    There's another product called Goo-Gone that's good with adhesives.
    2006 DC Limited 2WD Salsa Red Pearl
    Hellwig Sway Bar - Exterior LED's - Putco Chrome Handles - Imposter Chrome Grill Inserts - Lund Bug Deflector - UWS Low Profile Tool Box - BedRug - Multivex Mirrors - Scangauge II - Kenwood 5120 - Boyo Backup Camera - Parking Assist Front & Rear - Fog Light DRL's - Bilstein HD Shocks
  7. #6
    Join Date
    Oct 2007
    Location
    Missouri
    Posts
    6
    Liked
    0 times
    Rep Power
    0
    Found some stuff at wal-mart in the hardware area called Krud-Kutter. Worked great, wipe it on let it set for a minute and then it almost just completely wiped off the remaining adhesive tape.
  8. #7
    Join Date
    Sep 2007
    Location
    Age
    28
    Posts
    1,077
    Liked
    0 times
    Images
    5
    Rep Power
    15
    Thread Starter
    going to pick up a heat gun tomorrow along with some goof off and try that.
    Cardomain Member
  9. #8
    Junior Member reese917's Avatar
    Join Date
    May 2006
    Location
    Baton Rouge, LA
    Age
    28
    Posts
    76
    Liked
    0 times
    Rep Power
    14
    I got some 3M adhesive remover from my local body shop. That plus a towel, elbow grease, and patience will get it off. I also made a scratch when I thought I could "carefully" get it with a razor blade.
  10. #9
    Veteran Member ICON's Avatar
    Join Date
    Nov 2005
    Location
    Monson,ma
    Posts
    564
    Liked
    3 times
    Images
    8
    Rep Power
    266
    I've found the best thing to use to get it off is a rag wrapped around your thumb and apply as much pressure as you can and start peeling it off. I tried the 3M adhesive remover and it didn't do much cause that adhesive tape is soo thick it evaporated before it could get to the actual adhesive. It took about 3 minutes per side to remove using my thumb but worked flawlessly. No scratches and took it all off. It's just hard work and your thumb will be a little sore but it's the fastest, easiest, and less damaging way i've found. Then use something to clean the paint and apply new vents.
    '06 AC SR5 4x4
    '05 Honda Foreman 500S 4x4
    '04 Honda Shadow Sabre 1100
  11. #10
    Supporter ddiving's Avatar
    Join Date
    Nov 2006
    Location
    Maine
    Posts
    69
    Liked
    1 times
    Images
    5
    Rep Power
    9
    I found Marine-Clean worked great for this and the best bug and tar remover I have ever used. Spray/wipe it on. Wait a minute and rinse... gone. MARINE CLEAN-POR-15 Inc.
  12. #11
    Join Date
    Sep 2007
    Location
    Age
    28
    Posts
    1,077
    Liked
    0 times
    Images
    5
    Rep Power
    15
    Thread Starter
    I bought a bottle of goof off and a heat gun. I noticed that the goof off took some of the color of the paint off. Looks faded now but the adhesive is completely gone. Read the bottle and it said that it could remove some of the color on the vehicle. But I don't ever remember is removing the color off any of the other vehicles that I've ever applied it to. Going to put a coat of wax on that paint ASAP. Installed the vent visors to all by myself. One could tell a beginner did it.
    Do not buy the $22 Wagner heat gun model 1000 (yellow). The low switch quit working on me for a couple of minutes then it worked again. Going to take it back ASAP.
    Cardomain Member
  13. #12
    Join Date
    Jul 2009
    Location
    Buffalo,New York
    Posts
    39
    Liked
    0 times
    Rep Power
    6
    They do make plastic razor blades that wont dig into your paint. they wear kind of easy but saves the gouging of paint. You can also soak it in paint thinner rather than gasoline.
  14. #13
    Join Date
    Sep 2007
    Location
    Age
    28
    Posts
    1,077
    Liked
    0 times
    Images
    5
    Rep Power
    15
    Thread Starter
    I wasn't going to try gasoline because there have been several times in the past where I have accidentally spilled some gasoline which ran down the side of my truck causing the paint to look like crap.
    Cardomain Member
  15. #14
    Lurking Member DJ_Tundra's Avatar
    Join Date
    May 2007
    Location
    Germany
    Posts
    46
    Liked
    0 times
    Images
    9
    Rep Power
    9
    I have had good results with WD-40. I use it on everything, even removing window tint. Will not harm your paint or plastic.
    97 Opel Corsa/german specs(daily driver)
    06 DC Tundra
    07 HD Fat Boy (my toy)
    08 mini cooper S (wifes ride)
Quick Reply Quick Reply
Register Now
Log-in
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
