aquired a 02 with sensor problems
+ Reply to Thread
Results 1 to 6 of 6
Thread: aquired a 02 with sensor problems
  1. #1
    Rookie cynicalfaith89 is on a distinguished road.
    Join Date
    Sep 2009
    Location
    hesperia ca
    Posts
    2
    Liked
    0 times
    Rep Power
    0
    Default aquired a 02 with sensor problems
    hi guys
    my grandmother just recently gave me her 2002 tundra v8 that she took away from her son that was boonie bashin it. i took it in to get a diagnostic test (the CEL was on)
    P0135 Bank 1 sensor 1 and P0155 Bank 2 sensor 1 now i did do a search and came across alot of good information that i saved but i am almost positive that all 4 sensors are bad the place that did the diagnostics wanted an upwards of 400 dollars just to replace b1s1 and b2s1 after doing a little research i seen that rock auto has been recommended many times and that the sensors are Universal for the upstream but as i said im sure the downstream sensors are bad also and found that on rock auto they have them too but in my research i seen topics about how CA emission vehicles need special downstream ones to sync with the truck? it wasnt really discussed well enough for me to understand but if that is true then could somebody point me in the right direction of a good brand and a website to grab some from thanks!
  2. #2
    Senior Contributor Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P's Avatar
    Join Date
    Jan 2008
    Location
    Inland Empire, CA
    Posts
    7,174
    Liked
    2091 times
    Images
    47
    Rep Power
    126643
    Default Re: aquired a 02 with sensor problems
    Rockauto has had excellent prices. Some here have also had good luck with Amazon and eBay. If you have a CA emission vehicle, you will require the downstream sensors that are specific to the CA ECU. They are more expensive than the 49-state variety. Plug in your vehicle's info and Rockauto's website should point you to the appropriate unit.
    I strongly suggest that you only use Denso sensors. Note that it is NOT the 234-4154 unit!! If memory serves, it is the 234-900X series (but don't quote me!!!) I'd call your local service advisor and get the exact part number.
    Go here for the DIY: P0135 Check engine code, can I fix this ?
    2002 Tundra V8 SR5 2WD AC
    1C7-Thunder Gray Metallic | Bilstein 5100s | Wheeler's Progressive 3-leaf AAL w/ OL Leaf
    LT265/75R16D1 Nitto Terra Grapplers | Wheeler's Poly Sway Bar Bushing/Bump Stop Set
    eBay T304 SS Headers | Percy's #66080 Header Gaskets | Remflex #8015 Collector Gaskets
    13WL Caliper Upgrade | Hawk Quiet Slot Rotors | Hawk LTS Brake Pads are JUNK!
    Mobil 1 Syn 5W-30 | Mobil 1 Syn ATF | Mobil 1 Syn 75W-90 Gear Oil | Magnefine ATF Filter 3/8"
    Denso #K20R-U Plugs | Russell Speed Bleeders #639570 (7mm)
    Ham Radio: KJ6OPA | CB Radio/Handle: Midland 75-822/"Marksman"
    * * * I highly recommend Auto-Rx for your engine and transmission. * * *
    * * * O2 Sensor Replacement DIY * * *
  3. #3
    Supporter JTs02Tundra has blessed us with their presence. JTs02Tundra has blessed us with their presence. JTs02Tundra has blessed us with their presence. JTs02Tundra has blessed us with their presence. JTs02Tundra has blessed us with their presence. JTs02Tundra has blessed us with their presence. JTs02Tundra has blessed us with their presence. JTs02Tundra has blessed us with their presence. JTs02Tundra has blessed us with their presence. JTs02Tundra has blessed us with their presence. JTs02Tundra has blessed us with their presence. JTs02Tundra's Avatar
    Join Date
    Dec 2004
    Location
    Bronx, New York
    Posts
    235
    Liked
    1 times
    Rep Power
    41
    When I brought mine in for the recall a couple of years back , they replaced the entire manifold on both sides with nuts, gaskets, etc. It was a lot of work. I'm glad they did it under the recall otherwise that would have been big bucks out of my pocket. I know some here have been able to replace just the sensors, I tried that and was not successful at it.
    JT
    2002 SR5, Thunder Grey, Access Cab, 4.7, Off Road pkg, 4WD, Toyota Bedliner, Bed Extender, Limited Slip Diff, ABS
    Add Ons: Toyota Tube Steps, Leer 700 Lid, Curt Front Mounted Receiver Hitch, WeatherTech Window Vents, WeatherTech Front Floor Liners, Cabela's Aux Back Up Lights, Hellwig Rear Anti Sway Bar, Skid Row Front Skid Plate, Fumoto Valve, SP Rotors and Hawk Pads, SnowSport SnowPlow
    Have on workbench: Total Chaos Steering Gear Bushing kit, Autoxray 6000
  4. #4
    Join Date
    Sep 2009
    Location
    hesperia ca
    Posts
    2
    Liked
    0 times
    Rep Power
    0
    Thread Starter
    Awsome thanks for the info yeah I saw a sticker on the hood said that the vehicle complies with 49 states emissions standards including california I will have to look for the ca specific. Downstream sensors
  5. #5
    Junior Member diablito1975 is on a distinguished road.
    Join Date
    Apr 2006
    Location
    orange county
    Posts
    192
    Liked
    0 times
    Rep Power
    8
    let me know if you still looking for the sensors, i might be able to hook you up with a good price.
  6. #6
    Veteran Member longwoodklon has done just about everything...and then some. longwoodklon has done just about everything...and then some. longwoodklon has done just about everything...and then some. longwoodklon has done just about everything...and then some. longwoodklon has done just about everything...and then some. longwoodklon has done just about everything...and then some. longwoodklon has done just about everything...and then some. longwoodklon has done just about everything...and then some. longwoodklon has done just about everything...and then some. longwoodklon has done just about everything...and then some. longwoodklon has done just about everything...and then some. longwoodklon's Avatar
    Join Date
    Feb 2002
    Location
    Murrieta, CA
    Age
    40
    Posts
    1,756
    Liked
    15 times
    Images
    9
    Rep Power
    868
    You might also want to check sparkplugs.com, they had the best prices when I was checking several years ago.
    /Mike
    2001 2WD Silver Tundra: 4x4 TRD springs, Camburg Uniballs with adjustable Bilsteins, Carson AAL, red/blue Bilsteins in rear, 265/75 Yokohama A/T, IS kit(minus bumper) and rims(hand polished), Billet Wing Window Latch Upgrade, TC Steering Bushings, RF851X amp, Alpine HU, JL 6.5"XR comps, Qlogic with JL 8W3V2 subs. Stebel 300Hz Air Horn.
    202k miles and counting......
    2011 Honda Pilot EX-L, black with gray interior.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
