Air Conditioner Problem
+ Reply to Thread
Results 1 to 6 of 6
Thread: Air Conditioner Problem
  1. #1
    Join Date
    Jan 2003
    Location
    Danielsville, GA
    Age
    56
    Posts
    138
    Liked
    0 times
    Rep Power
    19
    Default Air Conditioner Problem
    My AC will work fine for a week or so and then out of the blue quits cooling. This usually will last a day. Cutting off Ac and back on, shutting off ignition, or not cranking for several hours has no effect. Crank the car the next day and have cold air for a week or so again. Already had coolant level checked. Any suggestions?
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Veteran Member shall36's Avatar
    Join Date
    Jul 2003
    Location
    Orlando, FL
    Age
    42
    Posts
    910
    Liked
    5 times
    Rep Power
    12
    Default Re: Air Conditioner Problem
    Could be many things...but let's start with the basics.
    1. When you turn on the AC (and it's not blowing cold), is the compressor kicking on. You can usually hear a "Click" sound and notice a change in the engine idle. If NO, then it could be a low system charge, or more specifically, a charge that is just low enough that when the ambient temp drops, the pressure in the system will drop just enough to not let the system turn on and vice versa when ambient temp goes up.
    2. Assume a NO to number 1, the cause could be a faulty pressure switch. Verify the connection is good. The switch goes to continuity between 28 and 455 psi.
    3. If/When the compressor does kick on, look at the site glass on top of the receiver/dryer. Is should be clear when the system is running. If you see bubbles in the glass, it usually indicates a low charge.
    4. You could have trash in the expansion valve that sometimes restricts proper flow and cooling.
    There's a ton of stuff to check. It's really about isolating a specific component using a decision tree then troubleshooting. To do it right, you need a set of gauges. If you can figure out the answer to Q1 above, we can give you more direction.
    Attached Files Attached Files
  4. #3
    Join Date
    Jan 2003
    Location
    Danielsville, GA
    Age
    56
    Posts
    138
    Liked
    0 times
    Rep Power
    19
    Thread Starter
    Thanks for the response. I will check out when it quits cooling again. Could it be something electrical. Talked w/ my stereo installer. There is a sirius box and bluetooth wired and cramped in space behind center console. Wonder if him being back there could have anything to do with it, ie loose connection, etc...
  5. #4
    Banned
    Join Date
    May 2008
    Location
    New Orleans, LA
    Posts
    1,364
    Liked
    31 times
    Images
    29
    Rep Power
    0
    If it stops blowing all together, it could be the blower motor.
  6. #5
    Join Date
    Jul 2003
    Location
    Orlando, FL
    Age
    42
    Posts
    910
    Liked
    5 times
    Rep Power
    12
    Quote Originally Posted by Raider Man View Post
    Possible but not likely. If it is cooling right now, go look in the sight glass on the receiver/dryer. That will give you some idea if the system is adequately charged.
  7. #6
    Supporter Henley32's Avatar
    Join Date
    Mar 2009
    Location
    Castle Rock, CO
    Posts
    66
    Liked
    0 times
    Images
    11
    Rep Power
    11
    My AC was acting the same way. After weeks of trying everything, I remember this problem began after I installed my new head unit. It turns out that the harness on the reverse side of my AC button/switch had a loose connection. Must of jacked it when I installed my new stereo . When my the circuit was opened the cold air would stop. Check your harness behind the AC light.
Quick Reply Quick Reply
Register Now
Log-in
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
