  #16 (permalink)
Old 10-12-2009, 12:22 AM
Mr. Creosote's Avatar
Legendary Contributor
Last Online: Today 02:52 AM
Images: 4
Mr. Creosote is the One. Mr. Creosote is the One. Mr. Creosote is the One. Mr. Creosote is the One. Mr. Creosote is the One. Mr. Creosote is the One. Mr. Creosote is the One. Mr. Creosote is the One. Mr. Creosote is the One. Mr. Creosote is the One. Mr. Creosote is the One.
Mr. Creosote's Photo Albums
Default Re: Which are the simpler horn upgrades?
Originally Posted by Goody51 View Post
baddoglt
I leaned on the horn for 10 seconds and there was no change to the temperature of the positive wire.
It can take longer than 10 seconds for temperature to stabilize on a copper wire, given the degree of insulation surrounding the wire, the mass of copper on either side of the test point, etc. A better test would be to measure the voltage drop from the positive battery terminal to the horn terminal. If the wires in between are too small, you will see the voltage reduce as you move along the wire from the battery to the horn while the horn is sounding.
Attention environmentalists, reduce emissions from this:
  #17 (permalink)
Old 10-24-2009, 03:16 PM
JMSinMD's Avatar
2008 Toyota Sequoia Platinum 4x4 5.7 V8,
2009 Toyota Highlander Sport AWD 3.5 V6
Last Online: Today 08:14 AM
JMSinMD is a splendid one to behold. JMSinMD is a splendid one to behold. JMSinMD is a splendid one to behold.
JMSinMD's Photo Albums
If anyone has their stock horns, particularly part 86520-0C030 I don't mind taking it off your hands
Maryland Owners click here ~>http://www.tundrasolutions.com/forum...nd+owners.html
Tags
simple horn
