Old 09-29-2009, 11:27 PM
stevebaum's Avatar
Last Online: 11-21-2009 06:51 PM
Images: 2
stevebaum is on a distinguished road.
stevebaum's Photo Albums
Question Which are the simpler horn upgrades?
OK, so I’ve read several posts about horns and I know I’d like to upgrade, but I do not understand something about installation. I will admit here and now that I am “electrically challenged” .
I want a simple upgrade of a much louder horn that I can use w/ my existing horn button on the steering wheel. Some folks have mentioned adding an additional button on the dash which I would rather not do. Many posts mention the addition of a relay, and I’m not sure if, or why, or where this would go (before the horn button or after?). Can anyone point me in the direction of a simple plug & play louder horn?
Your help is appreciated, stevebaum
P.S., I have no problem w/ fabrication of a bracket, etc. if that is required.
Old 09-29-2009, 11:31 PM
stevebaum's Avatar
Images: 2
Default Re: Which are the simpler horn upgrades?
Sorry, I forgot to add I have an '03 Tundra AC w/ V8 & 2WD.
Old 09-29-2009, 11:32 PM
ktaulbee's Avatar
Dealer : Signature Toyota
2008 Toyota Tundra 5.7 DC
Last Online: Today 10:01 AM
Images: 1
ktaulbee is a splendid one to behold. ktaulbee is a splendid one to behold.
ktaulbee's Photo Albums
Do a search for Stebel truck horn. There are pics of installs. It is basic wiring. Basically you use your current horn wire run to the relay, then run a wire from the battery to the relay, the ground, then horn. It is pretty simple. I just upgraded my gen-2 Tundra and it was no problem. The Stebel is loud, but some people use an air compressor, tank, and real air horns. Not to sure about those installs. Good Luck
2008 DC Radiant Red 5.7 4wd
Stebel 300hz Truck Horn
Black Nerf Bars
Pioneer AVIC-F900BT
Boyo Backup Camera
Advantage Tonneau
Old 09-30-2009, 11:09 AM
Dealer : Ed Shults Toyota
2003 Toyota Tundra
Last Online: Yesterday 11:39 PM
Images: 4
Cygnusx51 is on a distinguished road.
Cygnusx51's Photo Albums
I was having problems with my low note horn freezing in cold weather and not working. I replaced it with a FIAMM Freeway Blaster (low tone horn) that I had purchased at Adavance Auto Parts.
It is louder than the stock horn but obviously not like an air horn...good news though...it's super easy to install. Just unplug the connector and take off the stock horn. Bolt on the new horn to the included bracket, plug the stock connector to the new horn (just slide it onto the male connector) and then bolt on the new ground wire (included in package) and mount it to the radiator support. Done. Cheap, simple and takes 10 minutes.
Old 09-30-2009, 04:19 PM
longwoodklon's Avatar
2001 Toyota Tundra,
2005 Toyota Sienna
Last Online: Yesterday 07:47 PM
Images: 9
longwoodklon is a glorious beacon of light. longwoodklon is a glorious beacon of light. longwoodklon is a glorious beacon of light. longwoodklon is a glorious beacon of light. longwoodklon is a glorious beacon of light. longwoodklon is a glorious beacon of light.
longwoodklon's Photo Albums
Seems like the way to go, from reading others experience, is the steibel. A relay is not a big deal. The little wire going to the stock horns is not meant to carry a lot of current. So you tap into that line and it controls a relay. The relay is connected direct to your battery, so when you press the horn, the control signal(your stock horn wire) tells the relay to close, and the voltage/current sent to the horn comes from the battery directly. Of course, in doing this, you will also want to add an in line fuse(between the battery and the relay) in case something shorts.
/Mike
2001 2WD Silver Tundra: 4x4 TRD springs, Daystar 1", Carson AAL, red/blue Bilsteins, 265/75 Revo's, IS kit(minus bumper) and rims(hand polished), RF851X amp, Alpine HU, JL 6.5"XR comps, Qlogic with JL 8W3V2 subs. 185k miles and counting......
Old 10-04-2009, 05:11 PM
Goody51's Avatar
2002 Toyota Tundra LTD
Last Online: Yesterday 10:46 PM
Goody51 is on a distinguished road.
Goody51's Photo Albums
I installed Stebel TM80 Magnum twins (High & Low 139db & 115db) and used the stock wire and plug didn’t need to use the supplied relay just had to make a ground wire for the other terminal very easy. They are loud enough but I should of gotten the Black ones I’ll be painting them soon.
I got then from HornsPlus $26.45 delivered .
Here the link HornsPlus Automotive: Air horns for sport cars, motorcycles, boats, and emergency vehicles
Which are the simpler horn upgrades?-dscn1400.jpg   Which are the simpler horn upgrades?-dscn1403.jpg   Which are the simpler horn upgrades?-dscn1401.jpg
Old 10-05-2009, 02:32 PM
Greenie's Avatar
Dealer : Hoover Toyota Scion
Last Online: Today 09:46 AM
Greenie has done just about everything. Greenie has done just about everything. Greenie has done just about everything. Greenie has done just about everything. Greenie has done just about everything. Greenie has done just about everything. Greenie has done just about everything. Greenie has done just about everything. Greenie has done just about everything. Greenie has done just about everything. Greenie has done just about everything.
Greenie's Photo Albums
How do they compare with the stock horns?
More's Law: If more's good then too much is just right.
CBTMA member
Old 10-05-2009, 09:16 PM
Goody51's Avatar
A lot better than the stock, sounds like a truck should sound.
Old 10-07-2009, 02:09 PM
Greenie's Avatar
Since my last post I found Stebel's site and listened to a sound clip of the Magnum Combo. Thanks for sharing your upgrade and additional information. This will be my next mod.
CBTMA member
Old 10-07-2009, 05:16 PM
Last Online: 11-01-2009 03:56 PM
baddoglt is on a distinguished road.
baddoglt's Photo Albums
Is the stock electical system stout enough? Stebel says the horns draw between 3 and 6 amps each at 24 volt. My 2006 has a 10 amp fuse and a pretty dinky Denso relay. Not to mention the wires look like about 22 gauge rather than 16 or 18 gauge that 6 amps should probably have. If you do a long blast, does the wire or relay heat up?
I just ordered a pair for the truck and may get another pair for my wife's SUV. I almost ordered the Stebel Nautilus but lliked the lower tone (and cheaper price) for the Magnum twins.
2006 Tundra Double Cab 4x4
Debadged
Back seat in garage, dog in truck
LW 5th Wheel
Lots of scratches from the trails
Old 10-07-2009, 10:31 PM
Goody51's Avatar
I'll try to do that test tomorrow, ran out of time today.
I did go back and look at the instructions (needed a magnifying glass - old guy) and it calls for a 20 amp fuse for the 12 volt application. I'm no Electrician but it seems like over kill to me for a 6 amp draw, I have had no problems with my setup.
Old 10-09-2009, 09:12 PM
Goody51's Avatar
baddoglt
I leaned on the horn for 10 seconds and there was no change to the temperature of the positive wire.
Old 10-10-2009, 10:32 AM
Dealer : Apple Valley Toyota
Last Online: Yesterday 07:32 PM
400exboy2 is on a distinguished road.
400exboy2's Photo Albums
For the real air horns. www.hornblasters.com I wish i had the money to buy them.
Old 10-11-2009, 05:07 PM
Great! Mine came in the mail Saturday and I'll install them today.
Debadged
LW 5th Wheel
Old 10-12-2009, 12:09 AM
stevebaum's Avatar
Images: 2
Thanks everyone. Now I understand that a relay is just a sort of remote on/off switch that handles the heavier current (Thanks longwoodklon!). I've ordered my horn and plan to keep the two original horns piggybacked on the passenger side and the new Stebel by itself on the drivers side. If all goes well I'll try to post a picture.
stevebaum, '03 Tundra AC, 4.7 V8, 2WD, auto, 17" FJ rims & tires, debadged, Stebel compact truck horn, 14" Magnaflow w/ resonators in place. Coming soon...a rear swaybar.
Tags
simple horn
