Old 10-02-2009, 09:51 PM
TRD2wd's Avatar
Last Online: 11-02-2009 02:03 PM
TRD2wd is on a distinguished road.
TRD2wd's Photo Albums
Default Too much transmission fluid?
Hello, I have 2003 TRD and had the tranny fluid changed and see that 4.5 quarts was used for the 4.0 quart change. It does register high on the dipstick, should I drain this extra 1/2 quart? Not sure if it changes as smooth as it should but I may be comparing it to my wife's Avalon.
Thanks for your help!
Jimmie
2003 SR5 2WD; Cooper Discoverer CTS rubber; Amsoil 0w30 Signature Series; Amsoil Synthetic tranny fluid; Amsoil Ea Air filter; Access Vanish tonneau; Trail FX Nerf bars; 2nd owner; 89k miles and wishing I could hit 20 mpg....
Old 10-03-2009, 05:10 PM
Dealer : Al Hendrickson Toyota
2005 Toyota Tundra
Last Online: 11-17-2009 03:30 PM
GORILLA is a splendid one to behold. GORILLA is a splendid one to behold.
GORILLA's Photo Albums
Default Re: Too much transmission fluid?
hi, 1/2 a quart should do anything at all.
it's not like it's coming out of the dip stick tube.
gorilla
Old 10-03-2009, 06:59 PM
stevekx's Avatar
Dealer : Toyota of Newburgh
2003 Toyota Tundra
Last Online: Today 06:03 PM
stevekx is on a distinguished road.
stevekx's Photo Albums
Changing only 4 qts will not do much good for you, unless you do it all the time. I change my motor oil at 10K intervals and at every oil change I drain the tranny pan and add 4 fresh qts. If you have not done a complete tranny flush yet and only did 4 qts, it is not doing much for you.
bug deflector/side fender turn signal/went shades/back rack/tool box/rear strip light/nerf bars/top light bar/front alternating flashers/rear strobes in turn & stop lights/bedmatt & linert/all badges removed/Helwig sway bar
Tags
fluid , transmission
