Originally Posted by beer guy
Curious? Does running it occasionally to lube parts also apply to low range?
I'm pretty sure it does.
If you get under the truck, you'll notice that the fill plug on the transfer case sits above the front shaft output from the T-case, but well below the rear shaft output. Now, in my limited brain, it seems as though the T-case fluid level is well below the rear output,and unless you engage the front once in a while, the fluid probably doesn't get mixed up all that much.
My driveway is about 1200 feet long. Once a month or so, I put it in low range and just drive slowly, straight up the driveway. No turning the steering wheel or anything. So far (knock wood), so good.
