Old 10-04-2009, 09:52 PM
Dealer : GO Toyota
Last Online: 11-22-2009 07:44 PM
ehooper is on a distinguished road.
ehooper's Photo Albums
Default Tire Rubbing
So, I have a 2006 DC 4x4 with 275/70/17 tires, Bilstein 5100's up front on their highest setting and a 1" block spacer in the rear. My front tires have a pretty significant rub on the upper control arms. I am looking for an easy way to move the tire out, but am only finding tire spacers which provide a minimum of 1.25". I only need to push the tire out about 1/2". I have searched the forums extensively and cannot find my exact problem where only a small amount of movement is needed. Does anyone have a solution?
Please see attached pics.
thanks for all your help!!
Old 10-04-2009, 10:07 PM
hofkamp83's Avatar
Dealer : Billion Motors
2005 Toyota Tundra
Last Online: Yesterday 08:38 AM
Images: 49
hofkamp83 will become famous soon enough.
hofkamp83's Photo Albums
Default Re: Tire Rubbing
those 1.25" spacers are the way to go, and they are not really spacers. they use the existing lugs to bolt on the adapter and then the adapter has lugs to bolt on the tire. those 0.5" or less ones are the cheap spacers that just push out the tire on the existing lugs so the nuts have less threads to secure the tire. I have the 1.25" spidertraxx adapters and have not had any problems with them. Make sure you get hub centric adapters and not lug centric, i used some lug centric adapters for a awhile and caused some vibration while driving down the road. good luck.
Andrew
2005 Toyota Tundra Access Cab Limited
Goodyear Wrangler Silent Armor LT285/70R17, Bilstien 5100's, 1" Rear Blocks, Rough Country Rear Shocks, RevTek Diff Drop, Total Chaos Steering Rack Bushings, Downey HD End Links, CV Boot Mod, K&N CAI, Borla Split Side Exit Exhaust, Removed Resonator, Summit Nerf Bars, Bullett Bull Bar, KC Highlights Long Range Slim Lights, 1.25" Spidertraxx Adapters, Herculiner Roll On Bed Liner
Full LED Conversion with HIDS, Panasonic CQ-VW100U, Panasonic CA-PANSC1U, Sirius SC-C1, Infinity 6022i, Infinity 6020CU, Q-Logic QL-C1TTX208, Kicker ZX400.1, Rockford Fosgate P2D28 x2, Cobra 9540, Scanguage 2
Old 10-04-2009, 11:17 PM
Dealer : GO Toyota
Andrew,
Thanks for the quick reply. Does it look bad to only use them on the front, or should I also buy a set for the rear?
thanks,
Eric
Old 10-05-2009, 08:24 AM
hofkamp83's Avatar
2005 Toyota Tundra
Images: 49
If you just do the rear, the front will be aligned with the fender while the rear will be tucked in. I don't think you need them on the rear, you can buy ones for the front and see how they look and then later on add the rears.
here is a picture down the side of my truck, you can kind of see that the tires match the fender well pretty good.
Andrew
Old 10-05-2009, 11:03 AM
barron64's Avatar
Dealer : Lynch Toyota of Auburn
2006 Toyota Tundra DC 4x4 SR-5,
1996 Toyota Tacoma LX Extra Cab 5-Speed
Last Online: Yesterday 03:46 PM
Images: 9
barron64 is on a distinguished road.
barron64's Photo Albums
What brand of tire are you running? I have 275/70-17's with no spacers and have no rubbing issues.
Doug Thorley ceramic coated headers, SOS high flow Y pipe, Doug Thorley cat back exhaust, K&N drop in filter, Rev-Tek 2.5" lift kit, diff drop, Goodyear Wrangler's 275/70-17's, Dynoed @ 245rwhp
Old 11-03-2009, 02:21 AM
tundrunk's Avatar
2003 Toyota Tundra sr5 1wd
Last Online: Today 01:34 AM
Images: 18
tundrunk is a splendid one to behold. tundrunk is a splendid one to behold. tundrunk is a splendid one to behold.
tundrunk's Photo Albums
maybe spacers have gotten better but they still scare me. if you put them on be sure to check your torque on them every so often.
Old 11-03-2009, 08:53 AM
hofkamp83's Avatar
2005 Toyota Tundra
Images: 49
Those adapters are not like the old spacers where you put a like a ring in between the wheel and lugs. these adapters actually bolt to the lugs then with another set of lugs is where the tire bolts to. Spidertraxx ones are machined very good and come with locktite, but every time yiou rotate your tires just give them a little bump you wont ever have problems.
Andrew
Old 11-03-2009, 11:19 AM
tundrunk's Avatar
Images: 18
ive seen them and thats the "gotten better" that im recognizing. i thought pushing your wheels out that far puts extra stress on your bearings and other parts too. i know a lot of people on this forum use the ones youre talking about so maybe its just old folklore.
