Old 10-07-2009, 05:50 PM
synystergates's Avatar
Dealer : Carson Toyota Scion
2005 Toyota Tundra
Last Online: 10-19-2009 03:16 AM
synystergates is on a distinguished road.
Send a message via MSN to synystergates Send a message via Yahoo to synystergates Send a message via Skype™ to synystergates synystergates's Photo Albums
Default Squeaking from front and rear when going over speed bumps
I searched the boards and found nothing on my issue.
So I have these speed bumps in my neighborhood and this afternoon I noticed that when going over them at anything but super slow I hear a squeak from the front and the rear. Could it be my shocks or something else? I have the TRD Off-road package on my Double Cab 05 Tundra. Any tips or suggestions on what to do or anything else I should look out for?
When I raise my flashing sword, and my hand takes hold on judgment, I will take vengeance upon mine enemies, and I will repay those who haze me. Oh, Lord, raise me to Thy right hand and count me among Thy saints.
Old 10-07-2009, 05:57 PM
Dealer : Hellman Toyota
2005 Toyota Tundra
Last Online: 11-22-2009 08:03 PM
Images: 4
sic402 is on a distinguished road.
sic402's Photo Albums
Default Re: Squeaking from front and rear when going over speed bumps
Try getting some like multi-purpose lube type of spray and getting the connections of the leaf springs, then in the front the lower ball joints are always my culprits. one quick spray and its gone for about a month+ depending on weather.
Old 10-07-2009, 06:18 PM
integraGSR's Avatar
2005 Toyota Tundra
Last Online: Yesterday 10:56 PM
Images: 14
integraGSR will become famous soon enough.
Send a message via AIM to integraGSR integraGSR's Photo Albums My eBay
not trying to be a dick but when your truck ages, it will start to squeak and rattle. you can't expect it to be super quiet, it's not a Lexus so turn up the volume.
but, it can be anything. most likely it would be your struts or rear shocks. visually check them and if they are not leaking, you should be ok. lubing up your rear leaf's will help too.
05 Salsa Red Pearl DC
01 Honda Civic
95 Acura Integra
Old 10-07-2009, 06:21 PM
2005 Toyota Tundra
What brand of multi-purpose lube do you recommend?
Old 10-07-2009, 06:55 PM
duffyatkinson's Avatar
Dealer : Toyota of Riverside
2002 Toyota Tundra,
2003 Toyota 4Runner V6 Limited 4WD
Last Online: Today 02:38 AM
Images: 17
duffyatkinson has much to be proud of. duffyatkinson has much to be proud of. duffyatkinson has much to be proud of. duffyatkinson has much to be proud of.
Send a message via Yahoo to duffyatkinson duffyatkinson's Photo Albums
Fronts: Chances are, it's a steering rack or sway bar bushing that's the culprit. If the bushings are still in good condition, regreasing them usually does the trick.
Rears: Squeaks here can really only be from two places, 1. leaf spring pack, or 2. upper shock mounts. To get the leaf springs regreased, lift the rear by the frame so the rear suspension droops, then get the largest screwdriver you can find, gently pry the packs apart and get some good grease in there. As far as the shock squeak, there was a TSB about the upper shock mount. Do a search in the Gen-1 forum to find the solution (essentially, just removing the upper shock mount, flipping the bushing, and reinstalling.
Hope this helps.
2002 Tundra V8 SR5 2WD AC | Silver Sky Metallic | Chrome Step Bars | Kobalt Low Profile Bed Box
Daystar 2.5" Levelling Lift, 1" Rear Block
Mobil-1 5W-30 | Magnefine ATF Filter 3/8" | K&N AF #33-2144 | NGK Iridium Plugs #BKR6EIX
Russell Speed Bleeders #639560 | Josh's Billet Wing Window Latch Upgrade
11/1/2009: 48,050 miles
* * * I highly recommend http://www.auto-rx.com/ for your engine and transmission! * * *
* * * O2 Sensor Replacement DIY: http://www.tundrasolutions.com/forums/1197269-post2/ * * *
Old 10-07-2009, 08:18 PM
Dealer : Funk's Toyota
2005 Toyota Tundra
Last Online: 11-23-2009 07:52 PM
Diego is on a distinguished road.
Diego's Photo Albums
I also had a squeak from the back end of my 05 Tundra when going over speed bumps and when driving slowly down very rough streets. I took my truck into the dealer and mentioned the TSB mentioned above about reversing the upper shock mounts. They performed the TSB and no more squeaks. That's something to check first, it just might solve the problem.
Old 10-07-2009, 08:32 PM
Dealer : Street Toyota
2003 Toyota Tundra,
1995 Toyota Camry
Last Online: 11-04-2009 07:22 PM
leelemmon is on a distinguished road.
leelemmon's Photo Albums
I also had a squeak from my front end and it turns out that one of the bolts that holds my metal skid plate on had gone missing as well as the retaining nut. went to Autozone and bought a bolt and nut with washers and replaced the missing set. Problem solved on the front end. About 3 years ago, I had a problem with the rear squeaking and had the rear shocks replaced. Problem solved on the rear end. It could be numerous things. You just have to troubleshoot and find the cause. It's usually a pretty quick fix.
'03, SR5 Access Cab, Salsa, Charcoal Int, 4X4, V-8, Toyota Lid, Westin Nurfs, Hood Protector, Front Tint, Drop In Liner
Old 10-07-2009, 10:03 PM
2005 Toyota Tundra
Images: 4
I just grab a bottle named exactly that from NAPA actually its only like $3
Old 11-03-2009, 01:06 PM
tundrunk's Avatar
2003 Toyota Tundra sr5 1wd
Last Online: Today 01:31 AM
Images: 18
tundrunk is a splendid one to behold. tundrunk is a splendid one to behold.
tundrunk's Photo Albums
i had the annoying squeek from the leaf springs. my chick was callin my truck THE CRICKET. i thought it was the shocks but it was the springs so i shot a little oil in there around the eye mounts, the tabs and in the shackles. never came back.
Old 11-04-2009, 01:00 AM
03_Tundra_Limited's Avatar
2003 Toyota Tundra
Last Online: Today 01:29 AM
Images: 22
03_Tundra_Limited is on a distinguished road.
03_Tundra_Limited's Photo Albums
other than the mentioned squeak culprits mentioned if your rear springs are out of line (like mine ha) that will do it, also the tailgate can cause squeaking when going over speedbumps its worth checking out and can be easily fixed with lube also. i prefer a silicon based lube. good luck in your quest to be squeak free! i have already given up on my battle haha
Tags
squeak
