  #16 (permalink)
Old 10-15-2009, 06:24 PM
SuckersWalk's Avatar
2005 Toyota Tundra DC Limited 4x4,
- Other - 2007 Honda Accord V6,
- Other -- 2007 CR-V EX-L w/Nav
Last Online: Yesterday 12:46 PM
Images: 4
SuckersWalk is on a distinguished road.
SuckersWalk's Photo Albums
Default Re: Driveline Fluids All Changed...
^ sweet, thanks.
2005 Tundra Double Cab Limited 4wd - Phanton Gray Pearl
  #17 (permalink)
Old 10-16-2009, 09:51 AM
Greenie's Avatar
Dealer : Hoover Toyota Scion
Last Online: Today 02:26 PM
Greenie has done just about everything. Greenie has done just about everything. Greenie has done just about everything. Greenie has done just about everything. Greenie has done just about everything. Greenie has done just about everything. Greenie has done just about everything. Greenie has done just about everything. Greenie has done just about everything. Greenie has done just about everything. Greenie has done just about everything.
Greenie's Photo Albums
Good write up Beanly and thanks for the details on the filter bolts.
I think you'll be safe with just a pint over. If you don't feel comfortable about it just disconnect the lower cooler line connection and drain a little out.
More's Law: If more's good then too much is just right.
CBTMA member
  #18 (permalink)
Old 10-16-2009, 10:21 AM
Greenie's Avatar
Originally Posted by highlevel View Post
There is another thread going regarding the 05 - 06 tranny, and lack of dipstick. If you check some of the posts there are some maintenance suggestions and some PDF files from the service manual.
I have an 06 and will definitely change out the transmission fluid before I reach 90,000 miles. I am at 61,000 now.
2006 Tundra D/C Transmission Dipstick ?
Would a dip stick mod be practical for the '05 and '06 pans to facilitate fluid changes for the DIYer? There might be an aftermarket audience for this.
It would appear that Toyota is purposely over complicating service procedures and discouraging DIY maintenance on the transmission. My conclusion is that this vital maintenance service is being downplayed by Toyota under the hype of "lifetime fluid" possibly to the point of component failure. At this juncture the repair could be 30% or more of the vehicle's value.
CBTMA member
  #19 (permalink)
Old 10-16-2009, 10:42 AM
Dealer : Toyota of Killeen
2004 Toyota Tundra,
1999 Toyota Land Cruiser,
2008 Toyota Camry-Solara SLE Convertible
Last Online: Today 10:32 AM
labountyphoto is on a distinguished road.
labountyphoto's Photo Albums
i dropped the pan and cleaned the filter on my '04 at 60K miles. As stated before, removing the old gasket was a major PITA. I realized later I should have used a drill with a wire brush instead of a razor blade. However, the old fluid looked no different than the new and the gears didn't shift any better or worse than before i changed the fluid and cleaned the filter(screen). In the future I will only do a drain and fill. the only benefit in cleaning the screen was peace of mind.
  #20 (permalink)
Old 10-16-2009, 11:37 AM
highlevel's Avatar
life apprentice
Dealer : Magnussen Auburn Toyota
2006 Toyota Tundra Silver 4x4,
- Other - 03 Tundra - totalled
Last Online: Today 10:14 AM
Images: 25
highlevel is a glorious beacon of light. highlevel is a glorious beacon of light. highlevel is a glorious beacon of light. highlevel is a glorious beacon of light. highlevel is a glorious beacon of light. highlevel is a glorious beacon of light.
highlevel's Photo Albums
I was thinking of something similar. Don't know the answer to whether or not it would be practical (is raising our vehicles practical?) but a mod would be great. I don't agree with a "lifetime fluid" for a transmission. I don't run extended oil change intervals with syn oil either... but to each his/her own.
I have the extended warranty and would not feel comfortable doing a mod that would compromise that. I would probably wait until after 100,000 miles to work on one. Not sure if others would get on board, but I sure would.
Good points. Toyota obviously wants some more "service" dollars. I don't mind paying to have certain service procedures done by the dealership but they better stick with the attitude of years past. I had really good experiences several years ago. Recently (last year or more) it seems to me that their customer service has seen a decline. After my recent experience at the dealership they lost a lot of my service dollars by not stepping up and taking care of my leaking steering rack. They refused to warranty it by calling it seepage... even though the fluid level dropped. Sorry that doesn't fly. I won't be going back for the 60k service and handing them my money. I will be doing that one myself. I had already done most of the items on their schedule anyway.
As far as the transmission I am not sure I want to tackle that one on my own or not. I have no idea how long synthetic fluid will retain the properties needed for proper lubrication of a transmission. Under their maintenance guidelines they suggest 60k replacement for "special operating conditions". So looks like if you tow or drive your vehicle harder than most... get it replaced.
Rob K.
2006 DC, SR5, 4.7L, 5 speed, 4WD, LSD,
Silver Sky Metallic, Keyless Entry, Tow Package
Westin wheel to wheel step bars
Rackit (powder coated)
Leer 100 w/Windoors
Air lift Ride Control w/Quick Shot and Onboard Air
Pop & Lock
Bedrug
Slide Master bed-slide
Bilstein 5100s (middle notch)
Wheeler's AAL
Toyo 265/70/17 10 ply (back on stock wheels)
Scangauge II
Waiting to be installed:
MB Quart Speakers
Eclipse Amp
TC steering rack bushings
TC diff drop
Downey end links
Kartec CV boots
Wish List:
Spidertrax
SS exhaust system
HD front bumber (Reuenal or ARB)
Mile Marker Winch
Changing professions or purchasing a service truck so I can make this one all about fun!
Treat others as you would like to be treated
  #21 (permalink)
Old 10-18-2009, 08:52 PM
Rolando14's Avatar
Last Online: Yesterday 08:42 PM
Rolando14 is on a distinguished road.
Rolando14's Photo Albums
[QUOTE=labountyphoto;1348701] I realized later I should have used a drill with a wire brush instead of a razor blade. /QUOTE]
maybe you were better off, i've read that cleaning these old gaskets off needs to be done delicately, aluminum is sensitive or something a lot those lines?
one dog goes one way and one goes the other way, and this guy's like "what do you want from me?"
