Three years ago mine cost $711.73 at the dealership.
The repair breaks down as follows:
Replace timing belt, water pump, and drive belt.
6.5 hours @ $440.00
Total parts: $271.73
PN: Toy 96761-24019 O ring $3.44
PN: Toy 96761-35035 O ring $3.74
PN: Toy 13568-09070 Belt, Timing $59.50
PN: Toy 16100-59275-83 Pump Assy, Water $137.57
PN: Toy 90916-A2003 Belt, V-Ribbed $47.25
PN: Toy 00272-1LLAC-01 Antifreeze, Gallon W $20.23
I probably could have done without the sepentine belt but since it had to come off for the repair anyway why not replace it and save the labor? Some folks don't replace the water pump either but that's a calculated risk.
Hope this helps.
About the same cost and time frame. Well worth the peace of mind
This is also a very good time to replace the cam seals and the crank seal. Only a couple bucks and your right there.
Good observation kenairmk. Since the whole front is now accessible why not address these items? It just makes sense to take advantage of the timing belt labor to cover these small details.
More's Law: If more's good then too much is just right. CBTMA member
My dealer told me $522 to just replace the timing belt. I heard it is always good idea to replace water pump if it may need it while they are changing belt. One garage quoted me about $900 if they had to also replace pump and tensioner.
My dealer quoted me $315 +tax, including the serpentine belt. I have a feeling this is one of those "while we were in there we noticed you also need...." things. Its common to give a low initial price to get your foot in the door, then tack on stuff you didn't want to mention for fear of scaring the customer away. Plumbers do it everyday.
tun,
Do you happen to have a friend that is a Service Writer? I know when i had mine done it costs me about that with tax. I had to pay for the water pump and timing belt and 30mins labor. I had a "cam seal leak" on mine that was covered under the extended warranty.
2005 Tundra Dbl Cab Desert Sand
20" Enki Deep Six w/ 305/55R20 Cooper Zeon LTZ A/T
Flowmaster 50 Series Cat Back Dual Exhaust
Airaid Cold Air Intake
Airaid Throttle Body Spacer
Alpine w505 InDash Navigation w/ Blackbird
Kicker Comp VR12 Solobaric in custom over seat box
Kicker 1000.1 ZX Mono Amp
ARE Fiberglass Topper
XenonWorks 8,000k UltraWhite H.I.D.'s.
Hertz Mille' MLK 2 Components Hertz Mille' ML1600's 6.5's
Bilstein 5100's set a 2.0" in front
Wheeler's 1" lift blocks, Rancho RS9000XL in rear
Recon Bed Lights
Timing belt, water pump done at Aamco for about $608. Totally worth it.
__________________ Check out my site: http://www.toyotaaftermarket.com/
2001 Toyota Tundra SR5 4X4 Flowmaster Super 40 Series Muffler K&N drop-in air filter Silver Star Ultra headlights Rhino Liner Bed Liner
every winter my dealer sends out a coupon for $320. I used it a year ago, with no nickel and diming.
The water pump is an additional $250 though.
First Gen > *
Short List: BFG AT, Demello HD round Sliders, Donahoes, TC UCAs, Rear ARB Air locker, wrap around rear bumper, HAM
Eclipse CD-7100 HU, Zed Audio Deuce, Dynaudio system 240MKII (active), Zuki Eleet 4 channel, Koda 10 sub.
Next up: ?
sizematters, I know the writers wife, but never brought it up to him. as far as he knows we're strangers. I feel weird going 'hey man I know your wife!" some guys might react funny to that.
that price doesn't include the water pump, tensioner, or cam seals. those all sound like good things to do while their doing it. The writer told me the price includes time belt, serpentine belt, and 4hrs time. sounds cheap, maybe too cheap... When I get ti done I'll let you know if they stick to it.
Dex told me he would charge around $600 and that would include the H2O pump, which should be replaced just because it is the same basic job.
I use and talk about, but don't sell Amsoil.
2006 Tundra replaced a
98 Dakota 3.9 automatic, long bed.
Retired with broken A/C, July 2008.
623,000 miles.
On original engine and transmission.
+Everybody knows something you don't know.
+Truth does not need to be 'balanced' and it ain't caused by voting or consensus or polls or yelling louder or silencing someone.
+Artists prove truth can be in forms you don't understand.
