all three tailights failing, fuse is good, what would cause all three to go out at once?
Try the fuse first.
Water may have gotten into the assembly (not likely but possible). Wiring under the rear of the truck could have been hit by a rock or something. Also check in the same area under the bed by the bumper... a plug/connector may have come loose.
Rob K.
2006 DC, SR5, 4.7L, 5 speed, 4WD, LSD,
Silver Sky Metallic, Keyless Entry, Tow Package
Westin wheel to wheel step bars
Rackit (powder coated)
Leer 100 w/Windoors
Air lift Ride Control w/Quick Shot and Onboard Air
Pop & Lock
Bedrug
Slide Master bed-slide
Bilstein 5100s (middle notch)
Wheeler's AAL
Toyo 265/70/17 10 ply (back on stock wheels)
Scangauge II
Waiting to be installed:
MB Quart Speakers
Eclipse Amp
TC steering rack bushings
TC diff drop
Downey end links
Kartec CV boots
Wish List:
Spidertrax
SS exhaust system
HD front bumber (Reuenal or ARB)
Mile Marker Winch
Changing professions or purchasing a service truck so I can make this one all about fun!
I kept on blowing my taillight fuse for several months. Couldn't figure out what was going on. Finally my taillights went out completely. Brake lights worked fine. No other problems.
Dealer found that the wiring harness that exits the cab just below the drivers seat was rubbing against the frame. The wires were finally exposed shorting my fuse and they eventually cut through. They re-connected all wires, taped and then shrink wrapped the harness.
I have a 06 DB and a friend of mine had the same problem with his 05. Not sure if you have the same thing going on.
