Old 10-20-2009, 06:51 PM
Dealer : Power Toyota Irvine
2005 Toyota Tundra
Last Online: Yesterday 11:31 PM
jimbh99 is on a distinguished road.
jimbh99's Photo Albums
Default Damage to LSD?
I have a 2005 DC with the LSD. The truck has 69K miles and is in mint condition, except for one issue. I get a 'shudder' in the rear end when taking off from a stop while turning either left or right. This mostly happens in the morning or after the truck has been sitting for awhile. I have felt this in the past and to correct I would change the fluid (Lucas 80-90W) and add a tube of Limited Slip additive. No more shudder/chatter. By the way, there has never been any noise or growl associated when this happens.
Well last week, after noticing the shudder, I changed the fluid, added the tube of additive, but this time the shudder is still present. Now to my questions:
Could there be some sort of wear or damage to the plates in the diff that need repair?
Should I try adding another tube of additive? Or would that do harm?
Should I try a different brand of fluid? Say Royal Purple?
I have read that Royal Purple is good, but it only comes in 75-90W. Is that OK?
My manual does not say to use synthetic rear end fluid, so I want to stay away from that.
I have 5,000 miles left on the extended warranty, and will take it to the dealer if I have to, but I would like to try a 'fluid adjustment' if you think it might cure the problem.
Thanks for any suggestions.
Old 10-20-2009, 07:46 PM
Dealer : Butler Toyota Co.
2004 Toyota Tundra
Last Online: 10-29-2009 10:16 AM
bill3508 will become famous soon enough.
bill3508's Photo Albums
Default Re: Damage to LSD?
What additive did you use. You could very well have too much in there if you added a whole tube and I'm assuming you bought the universal tube from Autozone,etc. I had to go to a ford dealership to get the right friction modifier as the Toyota dealer did not even use it.
04 TRD AC 4X4,JBA headers,True Flow intake w/K&N drop-in, Spintech Sportsman Street XL muffler, NGK TR6ix plugs, new Denso 234-4209 o2 sensors,Mobil 1 Syn 0W-40
Old 10-20-2009, 09:20 PM
Mr. Creosote's Avatar
Legendary Contributor
Last Online: Today 01:46 AM
Images: 4
Mr. Creosote is the One. Mr. Creosote is the One. Mr. Creosote is the One. Mr. Creosote is the One. Mr. Creosote is the One. Mr. Creosote is the One. Mr. Creosote is the One. Mr. Creosote is the One. Mr. Creosote is the One. Mr. Creosote is the One. Mr. Creosote is the One.
Mr. Creosote's Photo Albums
I wouldn't worry too much about damaging them, as long as the growling didn't go on too long and it is finally fixed. We used to deliberately leave out some of the friction modifier to get more miles on old Chevy posi rear ends when the clutches would almost wear out.
Attention environmentalists, reduce emissions from this:
Old 10-20-2009, 09:21 PM
Dealer : Ferris Toyota
2005 Toyota Tundra
Last Online: Today 12:11 PM
skinny2 will become famous soon enough.
skinny2's Photo Albums
Royal purple 75w-90 is what I used, not a big deal in my book. Straight 90 would probably be fine as well. It does not require an lsd addtive. I swapped mine out at 35k and have had no issues now approaching 60k. Royal purple is synthetic btw.
'05 Tundra DC 4x4 (my DD)
'05 Honda Odyssey (her DD)
'03 Ram 3500 Cummins 6-speed dually (for haulin)
Old 10-20-2009, 10:14 PM
2005 Toyota Tundra
The Royal Purple 75-90W is synthetic too? I thought only the 75-140 was. Can I put synthetic in my 2005?
Old 10-21-2009, 08:22 AM
2005 Toyota Tundra
I can't think of any reason why you couldn't run synthetic. The transmission comes from the factory that way and the differential might as well, I dunno. You do know that an LSD has a limited life span anyway? 100k isn't uncommon life for the clutches and such, depending how hard you are on them. Like I said, I've been running the RP 75w-90 for 25k hard miles and no issues. Incorrect fluid would have destroyed something by now. Also, considering your location the straight 90W would likely be a better choice. The book only calls for the 75W-90 if you're running the truck under 0°.
Old 10-21-2009, 11:38 AM
2005 Toyota Tundra
I went to many stores looking for the 90W oil that the book calls for and it is no where to be found. All the stores only carry 80-90W. I was not aware that the LSD had a limited life and have not heard or read on anyone here having the clutches replaced as routine maintenance, like a timing belt for example. Would the extended warranty cover the plates, since they are a consumable item?
If someone has had to have their LSD plates replaced, could you please give me an idea of how much you had to pay.
Thanks
Old 10-21-2009, 12:58 PM
2005 Toyota Tundra
Usually what happens is, over time you lose the effectiveness of the LSD. Doesn't necessarily mean the rear-end goes bad, just the ability to transfer power from a slipping tire. So at that point you basically have an open diff. Many folks probably don't even know if it's bad. Also, keep in mind LSD is not very common on Toyotas and was a later model option as well. I'm thinking 2003 or 2004 was the first year they even offered it. Autozone or any store should be able to order you the 90W Royal Purple. They don't like to stock that stuff as it's relatively expensive. I'm planning a longer drain interval since I'm using the synthetic RP fluid.
Old 10-22-2009, 09:10 PM
2005 Toyota Tundra
I decided to add another tube of additive to see if that would make the shudder go away. It did. The additive that is sold at my local Auto Zone is 7oz, so I now have 14ozs in the diff. While it may diminish the effectiveness of the LSD (and maybe not) I do not have to live with the shudder I was experiencing. So as some have said, the 4oz, or in my case the 7oz tube of FM is just a starting point, some diffs might need more and some less, and some none at all.
I was told that too much additive will not do any damage to the rear end components, just possibly reduce the LSD functionality.
Old 10-22-2009, 10:18 PM
Last Online: 11-20-2009 03:58 AM
Ravenslair is on a distinguished road.
Ravenslair's Photo Albums
Interesting. That is the same thing my "new" 2006 DC does. I just figured it was a result of the LSD. I just bought it a few weeks ago with ~62k miles on it. I think I will do a fluid change as a precaution. Sounds like Royal purple 75w-90 is the way to go with a tube or two of the additive.
Old 10-22-2009, 11:05 PM
2005 Toyota Tundra
Many claim no additive is necessary with the Royal Purple, and others use it. This for sure is no exact science. My 2005 DC manual says to use conventional oil, so I chose to stay away from the synthetic stuff. I was told that if your diff was not designed to be used with synthetic oil, it's use 'may' cause the seals to leak. I want NO part of that. I would start with no additive, if the shudder is still there, add a tube, if it goes away be done with it. If it remains, add another.
Old 10-25-2009, 11:36 AM
DJ_Tundra's Avatar
Dealer : Hertrich Toyota of Milford
Last Online: Today 08:41 AM
Images: 9
DJ_Tundra is on a distinguished road.
DJ_Tundra's Photo Albums
I just did my rear lsd diff oil change yesterday. I was thinking about using RP 75w90 synthetic because I run Mobil 1 synthetic in my engine (can't get mobil gear oil in germany) but my owners/service manual says to use a SAE 90 or 80w90 for the rear diff. I used 1 tube (7 oz) of a lsd additive the name brand is TRANS-X. I used Quacker state gear oil made for lsd. So far everything is fine, no issues. The dealer i talk to in the states says once you do the change find an empty parking lot and do figure 8's in forward and reverse to spread the oil around in the case. Hope this helps.
97 Opel Corsa/german specs(daily driver)
06 DC Tundra
07 HD Fat Boy (my toy)
08 mini cooper S (wifes ride)
Old 10-25-2009, 02:01 PM
duffyatkinson's Avatar
Dealer : Toyota of Riverside
2002 Toyota Tundra,
2003 Toyota 4Runner V6 Limited 4WD
Last Online: Today 01:04 PM
Images: 17
duffyatkinson has much to be proud of. duffyatkinson has much to be proud of. duffyatkinson has much to be proud of. duffyatkinson has much to be proud of.
Send a message via Yahoo to duffyatkinson duffyatkinson's Photo Albums
Question Re: Damage to LSD?
The last time my rear (open) diff was serviced, according to the service sheet the dealer loaded it with straight 90W conventional gear oil, which is probably what was originally called for back when the truck was produced. So...
Q: Would a switch to Mobil-1 75W-90 cause any problems?
The core viscosity is the same; it's just the cold weather capability seems to be enhanced. And I like the temperature-reducing characteristics of the synthetic over the conventional. I can pick up the Mobil-1 LS 75W-90 for $9/qt at my local Autozone.
2002 Tundra V8 SR5 2WD AC | Silver Sky Metallic | Chrome Step Bars | Kobalt Low Profile Bed Box
Daystar 2.5" Levelling Lift, 1" Rear Block
Mobil-1 5W-30 | Magnefine ATF Filter 3/8" | K&N AF #33-2144 | NGK Iridium Plugs #BKR6EIX
Russell Speed Bleeders #639560 | Josh's Billet Wing Window Latch Upgrade
11/1/2009: 48,050 miles
* * * I highly recommend http://www.auto-rx.com/ for your engine and transmission! * * *
* * * O2 Sensor Replacement DIY: http://www.tundrasolutions.com/forums/1197269-post2/ * * *
Old 10-26-2009, 05:21 PM
glock 37's Avatar
Dealer : Spitzer Toyota
2002 Toyota Tundra,
1996 Toyota T100
Last Online: Today 09:08 AM
Images: 1
glock 37 is on a distinguished road.
glock 37's Photo Albums
A Month ago i changed my Lsd gear lube with R/P and mine did the same as you described so i called royal purple and talk to a tech he told me to do figure 8's in parking lot real slow as tight as you can about 4 or 5 and I have no more shudder starting out even on cold mornings !
Old 10-26-2009, 09:46 PM
2005 Toyota Tundra
While I have no idea what doing the figure 8's would do to eliminate the problem, tonight I will be in a parking lot doing 4 or 5. I now have 14 ozs of additive in my diff with Lucas 80-90W Oil. Straight 90W (recommended in the manual) is no where to be found in Southern California. I thought the extra tube cured the 'shudder' but I did feel it a bit this morning. I am going to give the 8's a try.
Can anyone explain the reason for doing the figure 8's, and what it would do inside the diff to cure the problem?
Tags
chatter , lsd , rear end , shudder
