Old 10-24-2009, 03:04 PM
toddbmobile's Avatar
2001 Toyota Tundra Hunter Green
Last Online: 11-08-2009 04:26 PM
Images: 5
toddbmobile is on a distinguished road.
toddbmobile's Photo Albums
Exclamation 2001 Toyota Tundra Fog light problem.
I just checked both my fog lights on my 2001 Toyota Tundar 2WD V8 and both were blown. I bought replacements ($18 bucks) and installed them, I just have not connected the wiring harness back as of yet. I checked the fuse under the hood and it is good. I think there is also a relay there for fog as well. Does anyone out there have an idea how I can test the relay short of buying another relay at the store. What bothers me is when I push in the fog lap button with the lights on and in low beam I get no voltage at the end of the harness (like 12volts DC). I just don't want to connect them again only to blow then due to another problem.
Ok the relay is now good, and lamps come on. I think I know what blew the lamps. I have moisture in the passenger side lamp. Can someone give me instructions or pictures on how to remove and waterproof the lamp?
Thank you,
Todd
Old 10-24-2009, 07:29 PM
Tundradrenalin's Avatar
Assistant Administrator
Last Online: Yesterday 09:35 AM
Images: 205
Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family.
Default Re: 2001 Toyota Tundra Fog light problem.
Moved you to the right forum for your question and fixed your other post.
Here's a free BUMP!
Under the Hood: AMSOIL Synthetic Lubes all around, AMSOIL Ea Air Filter, Doug Thorley Headers, Magnaflow Exhaust, Semi-RAMair airbox mod
Suspension & Tires: 285/75-16 BFG T/A'ko, Fabtech Coils, 1.5" Wheeler's blocks, Toytec Diff Drop, 1.25" Spidertrax [front], 1.5" Goeske Wheel Adapters [rear]
Handling: TC Poly Steering Rack Bushings, Downey HD End Links, Wheeler's Anti-Sway Kit, Hellwig 7700 Swaybar, Timbren Rear SES
Electrical: URD MAF Sensor Calibrator, Superlift Truspeed Speed Sensor Re-Calibrator, ScangaugeII, Full LED Conversion
Stereo: Alpine CDA-9886, Alpine & Phoenix Gold amps, Q-Logic box w/RF subs, eDead
Cosmetic: Line-X Bedliner, Custom N-Fab Steps, Rear Diff Breather Extension, F103N Fumoto Oil Drain Valve, Debadged (partially), Bell Truck Trunk, Access Vanish Tonneau
Tags
2001 , fog , fog lamp , fog lamps , fog light , fog lights , tundra
