Gene, how much work is it to separate the cab from the frame?
Here is how I did my engine removal:
1. Remove front bumper cover
2. Drain Radiator, and remove it. Disconnect A/C condensor (don't remove it)
3. Disconnect front brake lines (on a frame)
4. Disconnect steering rod
5. Disconnect Shifter for Auto Trans.
6. Disconnect connections under drivers seat
7. Disconnect 2 rear brake likes under cab, right under drivers seat.
8. Remove power steering pump completely
9. Disconnect Heater (on a fire wall)
10. Disconnect ECU (right behind glove box), Wire harness into Engine bay.
11. Remove 6 bolts that hold cab, and lift your cab.
2006 Toyota Sequoia Limited 4x4 w/ lxr package, 7008 navi, rear entartaiment system, 20" x-sp enkei.
2001 Toyota Tundra SR5 4x4 - TRD 9+Psi Supercharged, JBA Ceramic Headers, Walboro 255LPH Fuel Pump, 1UZ Rods, 20" x-sp enkei wheels, 7009 navi w/custom JBL wire harness + OEM XM/Sirus radio, drive by wire, and many other mods.
That is quite the unique way of getting your engine out, but it almost seems simpler not to have to wrestle the engine out of the top..... I'm really looking forward to your next steps!!! I am definitely convinced now that a good stock-ish 5-6psi would be just fine for our engines reliability....
__________________ 2003 white limited stepside with a 5.7 in the engine bay!! 6 speed transmission. LINk G4 Extreme engine controller , PCS transmission controller with tip-tronic control and a couple more options , custom stainless steel true duel exhaust oh yea
It takes me long, since I am not a mechanic. Plus I work on it about 2 hours a day. Hopefully after I'll be done with it, it will work good. Anyways, here is my progress
It sounds like the stock motor held up well considering the circumstances. It makes me fell better about making the decision to get the supercharger when I bought my truck new. I need to drive another 300,000 miles to catch up with Gene! By the time I do that, he will be at the 1,000,000 mark! Good luck Gene, I hope it fires up with no problems.
03 Stratosphere Mica Stepside, 4.7 L, Supercharger, TRD Package, TRD Exhaust,
Scion Head Unit 08600-21802,
Custom leather heated seats 2 tone with TRD LOGO, Moonroof, ARE LID, ZR3 Laser Shifter, Denso IK22 .4mm Iridium Plugs, Scan Gauge 2,
Rhino Liner, Die Hard Platinum P5 battery 5.7 Killer
Thank you Henry, yes, I do drive a lot and I think that motor is in great condition for the mileage that is on it. I am doing all of the maintenance at this time also (water pump, timing belt, new gaskets, etc...)
I have a great idea, that I would love to do next (for my truck) and I will post later, most likely in new thread
Update on my engine: both heads are on, water pump changed. Next is timing belt, install supercharger, and buy all new hoses.
Sweet Thread! Tinik, you came very close to snapping that rod! I read somewhere that the stock rods would only handle around 350 to 400 rwhp before they fail. With the boost you were running, you were right there. I also have a set of sc400 rods for that future upgrade! Too many projects and too little time these days.
Doug Thorley ceramic coated headers, SOS high flow Y pipe, Doug Thorley cat back exhaust, K&N drop in filter, Rev-Tek 2.5" lift kit, diff drop, Goodyear Wrangler's 275/70-17's, Dynoed @ 245rwhp
I also have a 2002 Tundra TRD SC original owner from way back bought new Sept 2001. No problems at all, still running the TRD Controller. The only thing, 6-months after the truck was new, TRD recalled the controllers. They send me a new one and I had to returnt he old. The truck runs very good and doesnt ping like so many complain about. Just now and again on a very hot day. I am thinking about getting the UniChip unit to see if it can ran any better. Very solid truck. Its not my daily driver but I do use it weeks at a time for the fun factor. I like my O2 better than my 07.
What did you dyno to the wheels?
Mustang Dynamometer with corrected rotational loss factor. HP 386.6 and Torque 406.66 this was peak power at between 4600-4800 rpms. Not too bad, I think? Stock motor is rated at 245hp, gained just over 141hp. I will take it. UniChip is claiming I have another 30-hp in thier program. From a roll the truck gets it hard. Dont forget we all have trucks here and they do weigh a little.
Here is a question: If I am using heavier rods will my performance suffer?
1UZFE Rod: 628g (my new rods)
2UZFE Rod: 581g (original that came with truck)
47g (heavier) each rod
I doubt you will notice any difference with the extra weight. I wonder if the increased weight will affect the engine balance? You should be able to run more boost without fear of bending/breaking a rod though.
Anybody ever bolt a TRD supercharger to an 05 or 06? I know it would require some custom tuning to the stock efi system...Anybody tried it?
